Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on June 14, 2019, 08:26:42 am
Are the 6EU7 and the 6Н2П the same (spec) tube ?
6Н2П
http://www.tubes.ru/techinfo/HiFiAudio/6n2pev.html (http://www.tubes.ru/techinfo/HiFiAudio/6n2pev.html)
6EU7
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/6EU7.PDF (http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/6EU7.PDF)
They dont appear to be identical but they do appear to be pretty close. Max dissipation is higher on the 6EU7 for instance.
6EU7 is just a 12AX7 with a different pinout, supposedly optimized for low noise. Call it a 7025 if you want.
If you're going to rewire the socket (60's Gibson?) you might as well rewire for 12AX7.
