Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: daveyajd on June 14, 2019, 08:55:24 pm
Title: 6.3 v outside of the chassis
Post by: daveyajd on June 14, 2019, 08:55:24 pm
I am going to try to add a backlit name-badge on this latest build. Ala- Matchless, Badcat, Morgan,etc.
My plan was to take a connection from my terminal strip inside and instead of going to my usual Fender style indicator just going through a grommet hole in the chassis. My question is whether it is that simple or if there is a better approach. Anything I should look out for that might cause additional noise in my build?
Aaron
Title: Re: 6.3 v outside of the chassis
Post by: sluckey on June 14, 2019, 09:51:09 pm
Just tap into your regular filament string at some convenient place near the PT or power tubes. It'll be fine.
Post by: daveyajd on June 14, 2019, 10:07:41 pm
Perfect. Thank you.
Aaron
