Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: TurboGuitarMelton on July 17, 2019, 05:13:13 pm
Title: Princeton Reverb Blackface tonestack bypass
Post by: TurboGuitarMelton on July 17, 2019, 05:13:13 pm
Hi,
I want to add the tonestack bypass mod or "raw" switch. However, the gain jump is so large that I can't even turn the amp up past 2 or else its overly loud and has a very nasty Overdrive.
I am aware that I can put a 100k resistor on the switch to help with gain but I feel like at that point the tonestack is still influencing the sound and sucking gain.
In the 5e3 there are two bypassed gain stages and the OD isnt crazy. Is the third gainstage after the reverb the reason there is such a crazy amount of gain?
If I lifted the cathode bypass cap on the second or the third gainstage do you think it would balance better?
Whats the purpose of the 3rd gain stage? Is it the reverb recovery? Or another bump before the phase inverter. The Princeton nonreverb amp doesn't have it.
Title: Re: Princeton Reverb Blackface tonestack bypass
Post by: sluckey on July 17, 2019, 05:33:31 pm
Put a 250K pot ***AND*** a switch between the tonestack and ground. Set the raw gain for what you like.
Post by: shooter on July 17, 2019, 07:18:51 pm
once you have what sluckey said working n smiling;
gain manipulation is a fun  to play with, scope n signal source are prerequisites though.  I like the simple Vac out / Vac in = Vgain.  gets fun when you can make it asymmetrical, compressed, kinked, on the scope, then test image with loud guitar
Post by: jjasilli on July 17, 2019, 08:23:26 pm
See, e.g.: https://reverb.com/news/a-nerds-guide-to-the-fender-princeton-reverb (https://reverb.com/news/a-nerds-guide-to-the-fender-princeton-reverb)
Post by: d95err on July 18, 2019, 02:24:43 am
The 5e3 has a 12AY7 for the first gain stage, which has about half the gain of a 12AX7. So, if you lift the tonestack on the PR, you get more gain going into the second stage than on a 5e3.
On a 5e3, the whole amp (poweramp and probably the PI) will be clipping by the time the second gain stage starts to distort. On the PR with a tonestack lift, the distortion will probably mainly be from the second gain stage.
To get better distortion, I would experiment with cutting bass when activating the tone-stack lift. E.g. having the switch also change the cathode of the first gain stage to e.g. 2k7/0.68u (á la Marshall).
Post by: MFowler on July 18, 2019, 07:09:14 am
Like Slucky said the 250k pot as shown here:
Post by: TurboGuitarMelton on July 18, 2019, 11:41:18 am
Thanks guys! The 250k pot really helped! Love it!  :icon_biggrin:
