Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: bibio on November 05, 2019, 08:01:45 am
Hello,
I recently finished building a 5F1 style kit amp for a friend. I upgraded some of the components but all values were kept the same.
It sounded great and worked perfectly.
After a few weeks, it started to develop this noise after around 15mins of use:
https://vocaroo.com/i/s1HtgRzWCPc6
As you can hear from the link there is a lot of hum and a popping sound.
Unfortunately, I'll be away for the next month so won't be able to inspect it.
The sound is quite unique, does this ring a bell with anyone?
Strange it only happens after 10-15 of use, sort of implies its heat-related????
When it was built it had all brand new components fitted. Cathode, screen and plate currents all verified and dissipation checked.
I'm quite confident it's not a dry joint or lose connection but open to all possibilities.
Could anyone hazard a guess at a potential cause of the issue?
All help much appreciated.
Might be bad tube or RF interference.
Yes, heat is a good guess.
Tube could be bad, but doesn't revel itself until after getting hot, grid/cathode/heater alignment could move with heat.
I know you think your solder connections are good but, could be bad solder joint, common for this to revel itself after heating up. Hum and popping are common symptoms.
Hi Guys,
Thanks for the response.
It's a difficult one to identify with the limited information.
Equally frustrating I can't start fault finding right now!
You know that feeling when you can't wait to solve a problem.......
Not exactly sleepless nights but lots of wondering, did I make a mistake????
sounds like arcing. is the 5Y3 healthy? cold solder joint?
