Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Cloud10 on November 13, 2019, 03:14:28 pm
Title: Spitfire Turretboard Layout - Suggestions?
Post by: Cloud10 on November 13, 2019, 03:14:28 pm
I'm using an old layout in JPEG format to make a custom turret board on the Hoffman Amps design page. I took a screenshot of my attempt at a layout and attached it as well. Can anyone take a look and suggest any changes you would make? Areas that could use extra room? This will be my first amp build and I want to avoid botching it from the beginning. Thank you.
Title: Re: Spitfire Turretboard Layout - Suggestions?
Post by: PRR on November 13, 2019, 04:11:32 pm
Some are spot-on, some close-enough. But I see missing dots column 18-19 and 24, 27. Under the big caps I see a big resistor on a small spacing, or else a pin where no pin is needed.
