Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: munkeyboy on January 17, 2020, 10:38:32 am
Not sure the name of these type of nuts, but I have 2 on my old silvertone 238. I need to replace 1 and would also find them useful for mounting a chassis behind a 3/8 baffle. Does anyone know the name and/or where I can find some that fit regular sized cts/alpha pots? The one in the attached pic is only for M7 pots.
Hi Munkey you might try searching for tee nuts Have you tried McMaster Carr?
https://www.mcmaster.com/tee-nuts
Thanks Jonas. I'll search more on tee nuts, but the ones on McMaster aren't really the ones needed.
Tee nuts are nothing like what you need.
have a machinist make that part? deep pockets for that. if you did find a 3/8" T nut, then 3/8-32tpi likely will not be available. use a 3/8"-32 nut and a piece 3/8" ID tubing?
I thought about that. I could try breaking out my mig welder, but i'm pretty bad at it and would probably burn thru it if the tubing isn't thick enough. Heck, if I thought I could do that, i'd just repair the split one I have.
