Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jasonvilla on January 18, 2020, 04:32:16 pm
Title: Stout TMB with Blues JR. Iron
Post by: jasonvilla on January 18, 2020, 04:32:16 pm
I'm making a Stout TMB from a Blues JR Power and Output transformer. So far I just have the power section hooked up. The power transformer doesn't have any center taps. So Im using two 100ohm resistors to ground for the heaters and 4 1N4007 diodes to make a full wave rectifier for B+. When I turn the power on, it works, but Im only seeing 243vdc at the end of the rectifier and the heaters are reading 7.3vac. Is something wrong or do I need to hook up the first filter cap to see a higher voltage reading?? Thank you for any help.
Title: Re: Stout TMB with Blues JR. Iron
Post by: sluckey on January 18, 2020, 04:52:11 pm
yes
Post by: jasonvilla on January 18, 2020, 05:26:36 pm
yes
Thank you
Post by: PRR on January 18, 2020, 09:31:20 pm
No cap: 0.9
With cap: 1.4
So for 270VAC:
No cap: 243VDC (huge ripple!)
With cap: 378VDC
Post by: Willabe on January 20, 2020, 11:13:43 am
......and the heaters are reading 7.3vac.
No tubes in, unloaded?
The heater voltage will drop with the tubes in.
Post by: jasonvilla on January 20, 2020, 01:05:41 pm
No cap: 0.9
With cap: 1.4
So for 270VAC:
With cap: 378VDC
Thank you! That's helpful, everything looks right so far.
Does anyone know if there is a more traditional board layout for the Stout TMB? Where the tubes are below the board and controls above? Thank you
Post by: sluckey on January 20, 2020, 02:03:26 pm
Hoffman's layout will work very well for what you want.
Post by: jasonvilla on January 20, 2020, 11:58:32 pm
This is what I came up with... I hope everything is going where it's supposed to! :)
Post by: jasonvilla on January 24, 2020, 09:50:58 am
I just realized the Hoffman Stout layout diagram shows a 120k feedback resistor but the schematic shows lists an 82k. Does anyone know the correct value. I'm pretty sure I have an 82k in there now. Thanks!
Post by: sluckey on January 24, 2020, 10:24:50 am
I would use the 82K. Only Hoffman knows for sure. Send him a pm so he can correct the docs.
Post by: jasonvilla on January 25, 2020, 01:16:17 pm
Thank you sir.
It works great. All the voltages are about 20-30 lower than the schematic states. Im going to swap out the 10k dropping resistor for a 5k to try to bring V1 and V2 up a bit. I am also going to reduce the bypass cap on the power tubes as it's a bit too dark right now.
Oh and the heater voltage is still high- 7.03VAC
Post by: EL34 on January 26, 2020, 06:53:56 am
The schematic shows a 82K feedback resistor
https://el34world.com/Hoffman/files/Hoffman_Stout.pdf (https://el34world.com/Hoffman/files/Hoffman_Stout.pdf)
Not sure where the 120k feedback came from?
Copy and paste error probably
I uploaded New PDF's for Stout and Stout TMB
You may have to clear your image cache in chrome if it does not download the new files
Post by: jasonvilla on January 26, 2020, 03:07:06 pm
Thank you
I added 2 1N5408 diodes in reverse parallel on one side of the heater supply and that reduced the voltage to exactly 6.3vac. So Im happy about that.
I've gone down the rabbit hole with this amp (surprise surprise). Blues Jr transformers were NOT a good choice. I kind of understand why the Blues Jr circuit has so much going on. But Im getting there :)
