Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on February 24, 2020, 04:25:41 am
My laboratory (Garage) is still cluttered with materials due to the home renovation that I have done,
so, waiting for it to be free and that it can use it, I am thinking of something to give a try
Some time ago, from a Stereo Grundig Radio, I recovered a pair of SE OT (used with one ELL80 but fine for a pair of EL95) with Speakers and PT with around 2.18A current for filaments
My idea is to use this components for a small power Stereo SE Guitar amp with different channels (one 5F2A ond one 5C1 - both with some mod)
On the 5C1 (6ak5 tube as V1 and EL95 as Power Tube), I would like to use a TS (may be a James), to do that I can use a CF or a SF
(https://i.imgur.com/81Np4E9.jpg)
but I would like to try to put more 6AK5 in parallel, I've a lot of this tubes (also to have the advantage of paralleled tubes vs noise), as far as I can know using more pentodes in parallel will permit me to drive enough the Power Tube also if the TS drop the signal
the configuration that I think to use (for the single tube) is borrowed from a project I've seen in the web, as you can see plate resistor has a relatively low value as to avoid microphonic effect on the tube, so less output signal
(https://i.imgur.com/IatpSrK.jpg)
My question is .... Two or Three tubes in parallel to be able to use the TS without excessive Signal Loss ?
(https://i.imgur.com/ZqnPRZp.jpg)
For the same reasons I've think also to use 2 tubes (2 x 6N2P = 4 triodes) on the 5F2A putting the triodes of each tube in parallel
Have you councils / warnings for me ?
Many thanks
p.s.: I've a lot of 6AK5 - 5654 tubes and a good quantity of 6N2P tubes
Hi Franco,
How did this project finish? I also have a lot of these tubes.
... I also have a lot of these tubes.
Use one for a triode-connected CF to drive the TS
Hi friends
I finished a lot of projects (big and small) and I'm going on with some others, but all Is about my house and my son's house
My laboratory Is full (letterally) and I enter there not easily, the more my healt Is not so good and for this reason all Is going slowly
I have more than a project ready to reach the bench, but the bench Is covered with materials to be used on the setting of the laboratory at the house of my son
