Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Cramer1 on March 12, 2020, 10:17:56 am
Title: Help my BDRI
Post by: Cramer1 on March 12, 2020, 10:17:56 am
My Blues Deluxe Reissue has severely low output when running through inputs 1 or 2 (1 on a scale of 1-10). If I run into the “Power amp in” input, I get full volume. If I swap V1 and V2 I get no sound, swapping V1 and V3 gets me sound but not even a 1 on the scale. I don’t hear any microphonics, they all glow. They appear to be the original groove tubes and the PCB is dated 2004. And tips or tricks? TIA.
Title: Re: Help my BDRI
Post by: sluckey on March 12, 2020, 10:33:55 am
Connect preamp output jack to another amp. Any sound?
Check voltages on V1 and V2. Check voltages on U1. Trace signal from input jacks to input to TP22 using a scope or listening amp.
Post by: Cramer1 on March 12, 2020, 10:42:43 am
I haven’t tried preamp to a different amp, but I did jumper preamp to power amp in. I checked some voltages last night around V1 and V2 based on test points on the fender schematic and they were severely off, showing V readings when it should have been mV.
Post by: sluckey on March 12, 2020, 11:03:09 am
Voltages shown in the ovals are SIGNAL voltages and are only valid when you inject a 4mVAC test signal into J1. You need a scope to trace the test signal through the amp. The voltages I'm interested in are DC volts on the tube pins.
Post by: shooter on March 12, 2020, 11:09:17 am
guessing this is the animal you have?
https://el34world.com/charts/Schematics/files/Fender/Fender_blues_deluxe_deville_reissue_vintage_.pdf
Post by: d95err on March 12, 2020, 11:12:26 am
If there’s a significant difference when swapping the preamp tubes around, one of them is probably bad. Swap each one with a new (or known good) tube and see if it fixes the problem.
Post by: sluckey on March 12, 2020, 11:14:44 am
I never heard the word "deville". I'm looking at this schematic...
     https://el34world.com/charts/Schematics/files/Fender/Fender_blues_deluxe.pdf
Post by: pompeiisneaks on March 12, 2020, 12:23:17 pm
Knowing the exact one is important, but the only difference I recalled from the blues deluxe vs the  blues deville was 2x6L6 vs 4x6L6 and 1 vs 2 speakers no?  I think the rest is pretty  much identical?
The problem is that there are no like 3 or 4 generations of the BD, so just saying RI is a bit confusing for sure.  Which generation is it?
~Phil
Post by: shooter on March 12, 2020, 12:39:14 pm
"deville".
I was looking for the word "re-issue"  :laugh:
the PCB version I worked on was a C-made mess!
sloppy solder, connectors that an amateur could flip n "make" fit.  I got the one I looked at working - with a 5 minute warranty n NO call-back :icon_biggrin:
Post by: sluckey on March 12, 2020, 12:46:03 pm
I think "Blues Deluxe Reissue" is a red herring!  :icon_biggrin:
Post by: shooter on March 12, 2020, 01:29:23 pm
I like anchovies, herrings are for bait  :icon_biggrin:
Post by: DummyLoad on March 12, 2020, 01:40:51 pm
check tubes as stated, also, check the +/-16V power supply rails - that amp uses Zener regulation for those two power supplies - lots of IC chips in that amp in the signal path that use +/-16V.
Post by: Cramer1 on March 12, 2020, 03:36:28 pm
Yes that’s what I have. It seems at this point that tube swapping may be my best course of action?
I know these amps have gremlins, but it was literally given to me because the previous owner didn’t want to mess with it, surely I can fix it for less than it’s worth lol.
Post by: Cramer1 on March 12, 2020, 03:39:03 pm
Can you give me an example?
Post by: Cramer1 on March 12, 2020, 04:05:24 pm
I did see last night that the top side of R78 is discolored, but I could not find it on the schematic to reference what the voltage should read across it. I’ll try and upload a picture.
Post by: DummyLoad on March 12, 2020, 04:31:46 pm
R85 & R86 in the schematic. if you do not see either +16V or -16V rail then the op-amps would not be working.
Post by: shooter on March 12, 2020, 05:11:46 pm
worth is in the eye of the beholder  :icon_biggrin:
like Pete said, the low volts, then the tube volts will go ALOT farther than swapping tubes.
WITH NO POWER;
A complete visual of BOTH sides of the board, use a chop stick and thump on parts, especially bigger Ecaps, you're looking for "loose teeth".  look for "browning" around and inside connectors and check the for looseness
and;
your friend is wise  :icon_biggrin:
Post by: Cramer1 on March 12, 2020, 07:51:37 pm
WITH NO POWER;
and;
Don’t sugar coat it lol
Post by: Cramer1 on March 12, 2020, 10:17:36 pm
Op-amps?
Post by: DummyLoad on March 13, 2020, 12:14:41 am
https://www.google.com/search?q=op+amps.&rlz=1C1SQJL_enUS887US887&oq=op+amps.+&aqs=chrome..69i57.1735j0j8&sourceid=chrome&ie=UTF-8 (https://www.google.com/search?q=op+amps.&rlz=1C1SQJL_enUS887US887&oq=op+amps.+&aqs=chrome..69i57.1735j0j8&sourceid=chrome&ie=UTF-8)
forget how to google stuff?  :laugh:    :BangHead:
take with levity please.
see attached.
Post by: Cramer1 on March 13, 2020, 08:08:36 am
Hey man I really appreciate it.
Also what did you mean by +16V or -16V rail? (I did try and google that one lol)
My background is in industrial I/E but when I start digging into actual electronics it’s a different animal. The learning is fun though.
Post by: shooter on March 13, 2020, 09:14:01 am
try "basic series and parallel electronic circuit understanding"
Op amps typically use a dual PS hence + and - 16vdc.  the schematic shows where it should be, is it?
Post by: Cramer1 on March 13, 2020, 09:17:48 am
see attached.
Is that the schematic for an original BD or a reissue?
Also, I see mentions of the “big white rectangle” resistors being R85/R86. But on my drawing they are labeled R78/R79 unless I am missing something. Again, thanks for all the help.
Post by: shooter on March 13, 2020, 11:17:44 am
do you have 2 power tubes OR 4?  there are 2 different schematics, both "close enough"
here's a visual, you have one of these, the RED circles APPLY to both, the names are changed to protect jobs, not confuse techs.
Post by: Cramer1 on March 13, 2020, 12:18:41 pm
2 power tubes. Thanks man! That gives me something to chase down after work.
Post by: shooter on March 13, 2020, 12:43:50 pm
while you're at work wasting the bosses money :) download the pdf I linked in reply 4
READ pages 4 n 5 til you can recite them in your sleep, then print-out the schematic and study it til ALL you see is symbols that make sense.
If none of that seems fun, trade it for a something fun on crags list  :icon_biggrin:
Post by: Cramer1 on March 13, 2020, 01:34:22 pm
:laugh:Will do!
Post by: Cramer1 on September 19, 2020, 08:00:52 pm
so I finally pulled the board and the joints at R78/R79 look crappy as. R79 measures 540 ohms which is out of tolerance for a 470 rated resistor. My question is could that level of deviance drop signal out?
It looks like a previous repair to me, but who knows.
I am considering pulling the board completely and having it retrofitted with real wiring.
Post by: Cramer1 on September 19, 2020, 08:02:36 pm
Pic
Post by: sluckey on September 19, 2020, 08:14:31 pm
no
Post by: Cramer1 on September 23, 2020, 08:39:43 pm
I replaced R78/79 and reflowed any questionable looking joints on the back of the board the reinstalled the board.
TP readings are as follows:
TP37 445V
TP38 444V
TP39 413.8V
TP40 385.4V
TP45 +16.63V
TP46 -16.5V
Same symptoms as before; Low
Output through the preamp, full volume using the “power amp in” input.
Ideas?
Thanks everyone for the help.
Post by: shooter on September 24, 2020, 06:41:50 am
Same symptoms as before; LowOutput through the preamp, full volume using the “power amp in” input.
so pre OUT to a good amp - low output?
power amp IN (from a good pre-amp) - low output?
Post by: Cramer1 on September 24, 2020, 08:20:44 am
if I plug directly into the power amp in input, I get volume from my guitar, I have not run from another amp into it. I have not run preamp out to another amp, but I have jumpered between preamp out and power amp in and still get low output.
Post by: tubeswell on September 24, 2020, 09:05:34 am
The way those 5w cement resistors are situated and mounted on the PCB are a known design problem and a common cause of problems in the Blues And Hotrod Deluxes (including random channel switching). It causes heat problems that ultimately cook the board traces and the nearby components for the +/- 16V dual rail power supply (16v Zeners and the e-caps). It can also affect the op-amps that run on the 16v PS. You may need to replace everything there (but even if you do, the board may be cooked beyond repair, in which case the only worthwhile course of action is a rebuild with a different type of board).
The IC filter caps are also a common cause of problems, so inspect them carefully for bulges and leaks.
Post by: Cramer1 on September 24, 2020, 09:38:10 am
I replaced the resistors and reflowed the connections on the diodes. I checked and affected tracing for continuity and everything rings out. I don’t see any other visual concerns.
Is there a way to test the op amps without imputing a test signal? What about a method of checking tube pins?
Post by: shooter on September 24, 2020, 10:10:54 am
we still have NO clue if it's pre or power amp, so jack the pre out to PA in
otherwise, pick up a scope and trace a signal, your VDC's check out at the PS
not sure "in circuit", like bias volts, current through pa tubes
guessing you swapped tubes
Post by: sluckey on September 24, 2020, 10:21:26 am
...If I run into the “Power amp in” input, I get full volume...
I understand this to mean the power amp is fine.
Post by: Cramer1 on September 24, 2020, 10:59:39 am
If I jack pre out to PA in I still get low volume output.
I have swapped tube positions but have not replaced tubes.
“ your VDC's check out at the PS
not sure "in circuit", like bias volts, current through pa tubes”———-I don’t understand what you mean.
Post by: tubeswell on September 24, 2020, 11:08:48 am
Are you sure the Zeners are working properly? Check the voltages for a period of time. They need to maintain around +/-16V. If they stray to over 17V or under 15V, suspect them.
The board might 'look' okay but be cooked around the traces. Take the board out and shine a torch through the board. What do you see? Brown stuff everywhere? Those 5W resistors need to be mounted at least 5mm off the board IMO. Or as soon as they heat up, the heat will keep throwing everything else off nearby (including the Zeners).
Post by: shooter on September 24, 2020, 11:35:59 am
 :laugh:
I took it to mean, put cable from pre out to pa in  :dontknow:
Post by: Cramer1 on September 24, 2020, 11:45:43 am
How long should I check the 16V?
Yes I stood the new resistors off of the board to prevent further heat damage.
Post by: Cramer1 on September 24, 2020, 11:46:23 am
:laugh:
I did that. No improvement.
Post by: shooter on September 24, 2020, 12:50:42 pm
that IS a test, just not for your problem, you need a second amp, an mp3 player, a phone, that you can take audio from and stick it into PA in  (whatever device you pick, pick one with volume, "line out" would be great)
Post by: Cramer1 on September 24, 2020, 01:00:40 pm
I have an Orange combo, so run it into my PA in?
Post by: shooter on September 24, 2020, 03:01:51 pm
ONLY IF it has a "pre amp out", (possibly FX out might work) then plug "that" into your broke PA IN
Post by: Cramer1 on September 24, 2020, 05:01:00 pm
Guitar into Input on orange amp, line out of orange into PA in on BDRI achieves full volume.
Guitar into input on BDRI, pre am out to line in on orange amp achieves no sound.
Test point voltages at tubes:
TP3 2.015 VDC
TP6 2.005 VDC
TP9 0.0 VDC
Post by: tubeswell on September 24, 2020, 05:23:46 pm
... your broke PA IN
 :l2:
Post by: tubeswell on September 24, 2020, 05:28:21 pm
Anything that's around those resistors has probably had heat damage. Belts and braces would be to replace the Zeners (and the dual rail PS caps) - if the board between the traces/pads isn't arced (in which case you need to do something about that). Change in the supply voltage on this dual power rail will trip the channel-switching transistors - also mucks up the reverb
Post by: shooter on September 24, 2020, 05:37:04 pm
TP 3,6,9 based on the schematic in reply 15 are AC - signal.  you need a good meter or scope AND a constant signal.
Now we can focus on the pre-amp  :icon_biggrin:
put your foot switch in, plug in guitar, stomp FS on n off, listen to see/hear if relays are a clackin
Post by: Cramer1 on September 24, 2020, 05:39:41 pm
I thought ovals required signal and rectangle TPs were voltages that could be measured without.
Not arguing just trying to understand it all.
Post by: shooter on September 24, 2020, 06:30:58 pm
different seats at the same movie
ovals are AC, must have a signal in THAT matches schematic notes
rectangles are DC, no input required
TP3 2.015 VDC          TP6 2.005 VDC          TP9 0.0 VDC
tp3 is DC, my bad, 6 & 9 are AC(IF we're both using schematic in reply 15)
Post by: shooter on September 24, 2020, 06:37:11 pm
let's stay easy for now
do you hear relays clicking when you switch, does the led lite/nolite??
Post by: Cramer1 on September 24, 2020, 06:37:47 pm
https://www.thetubestore.com/lib/thetubestore/schematics/Fender/Fender-Blues-Deluxe-Reissue-2004-Schematic-Rev-A.pdf
This is the one I am using.
Post by: shooter on September 24, 2020, 06:47:19 pm
TP9 = 0
so find V2A and figure out what PW2 is, cable?  tube socket? .......
Post by: Cramer1 on September 24, 2020, 09:37:38 pm
Ok so I can hear clicking when I use the foot switch, the red light comes on with channel select, and if I crank reverb I can hear it also, but at the same low volume.
Post by: Cramer1 on September 24, 2020, 09:44:48 pm
TP9 = 0
PW2A and B are the Ribbon cable connections going from the main board to the tube board for V2. So P2 would be the ribbon cable? TP9 is on the main board side of that ribbon.
Post by: shooter on September 25, 2020, 07:30:43 am
so TP9 on main board>cable>tube socket ?
pull V2, ohm from socket pin 3,(probe where tube pin 3 was), to chassis ground
Post by: Cramer1 on September 25, 2020, 10:42:13 am
I will try that. If pin 3’s socket to ground is good, could I swap V2 and V3, then run preamp out and if I get sound then, assume that V2 is bad?
Post by: shooter on September 25, 2020, 12:27:01 pm
 :laugh:
it's a PCB amp, IF I make ANY assumptions, it's a poorly constructed cable/solder/foil/socket, probably one of that last things I'd assume is a preamp tube
Post by: Cramer1 on September 25, 2020, 04:47:31 pm
So I haven’t gotten my meter back out, but I did swap tubes 2 and 3 and now my preamp out works.....
Post by: shooter on September 25, 2020, 04:54:25 pm
then you should have a working amp since the PA checked out yesterday, you still have bad doggy solder connection, or possibly sloppy socket pins
Post by: tubeswell on September 25, 2020, 07:45:44 pm
Maybe run the amp for an hour or two with 2 x meters clipped on the 16V dual rail PS. Look for changes in rail voltage if the channels start switching/reverb cuts in and out
If you shine a torch through the board its easier to see where the heat affects other parts - here's a BD I fixed a while back (Charring is from before I replaced the resistors) note the zener 'looks' fine except for heat burn around the trace pads which only visually showed up with the torch test
Post by: Cramer1 on September 27, 2020, 09:36:20 pm
Pin 3 to TP9 rings out. TP9 also has 2 VDC with the tube swap.
