Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Vlada on March 29, 2020, 03:25:27 pm
Title: Input grid resistor
Post by: Vlada on March 29, 2020, 03:25:27 pm
Hi guys, I am building high gain tube preamp and was wondering about V1a grid resistor. Some say lowering this resistor can reduce hiss while others claim that this can lead to overloading input when using overdirve pedals. I am thinking of using 10k resistor with capacitor from tube grid to ground to get the same cutof as with 68k resistor. Are there any other thing to consider? And should I wory about input overloading?
Title: Re: Input grid resistor
Post by: kagliostro on March 29, 2020, 03:41:13 pm
Not very much to say (from my part)
only to remember that a high W rated resistor has the tendency to insert less noise
and ... use a metal film resistor instead of a carbon composition resistor
this will result in less nois at same resistence values
BTW, Mesa, in some amp, didn't used a resistor, they used a ferrite bead, no resistance added and no noise
Post by: PRR on March 29, 2020, 08:09:00 pm
> overloading input when using overdrive pedals
Um, so it distorts when you use distortion pedals?
The experiment costs pennies. Just try it.
Post by: pdf64 on March 30, 2020, 05:05:56 am
Tube guitar amps typically use input grid leak resistors and input mixer / grid stopper resistors.
Ok, from the context it’s apparent that this thread is in regard of the grid stopper, but it’s always best to try to avoid folk having to assume relevant info.
To be clear, it’s essential for tubes to have a dc path between their control grid and cathode, with the max resistance of that dc path usually being specified in the tube info.
Post by: d95err on March 30, 2020, 06:01:08 am
Merlin has a good article on the subject:
http://www.valvewizard.co.uk/gridstopper.html
I use his duggestion with a low value input resistor and a capacitor. Works fine and does reduce hiss a bit.
