Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: warioblast on April 01, 2020, 12:52:37 pm
Title: Dual Relay
Post by: warioblast on April 01, 2020, 12:52:37 pm
Hey guys,
How can I mod this Tube-Town dual relay switcher https://www.tube-town.net/ttstore/kit-double-relais-switcher-6-v.html  (https://www.tube-town.net/ttstore/kit-double-relais-switcher-6-v.html)to work with a mono pedal footswitch.
It looks like one of the pin of the stereo cliff jack is connected to ground. My idea is to link the pole below (cf my awesome ms
paint drawing.)
 :dontknow: :w2:
Title: Re: Dual Relay
Post by: nandrewjackson on April 01, 2020, 02:50:31 pm
Are you wanting both sets of relays to switch at the command of one switch?
Connect these 2 points circled in blue if so.
Post by: nandrewjackson on April 01, 2020, 02:53:58 pm
And, if that's the case, remove either S1 or S2, and add your footswitch to whichever is remaining.
Post by: warioblast on April 01, 2020, 07:24:03 pm
Thank you.  :occasion14:
Yes that's what I want. I'd like to use an old marshall 1 button (mono) footswitch that I have.
This switcher kit is already built. I'd like to use the stereo jack that is already in place.
Post by: warioblast on April 03, 2020, 10:33:15 am
I would really like to use the stereo cliff jack that is already there.
As for now, with no mods, if I use my 1 button (mono) Marshall footswitch, it only switches Relay 2. Relay 1 stays on all the time.
I think I need to cut some traces
Post by: warioblast on April 03, 2020, 11:17:29 am
I'm thinking I should cut the trace that goes from the ring (?) to the - pin of the relay 1.
And from the - pin of the relay 1, going to one of the tip pin. It should be 50-50, right !?
Post by: warioblast on April 03, 2020, 11:45:18 am
It's working  :wav:
Post by: sluckey on April 03, 2020, 11:48:29 am
An easier solution is to just put a stereo plug on your footswitch cable. Connect the tip and ring together.
