Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Nicale19 on April 02, 2020, 07:13:05 am
Hi Guys,
Any suggest is appreciated
It s the btdr-1hm...
from all the WEB stuf I read, Belton gets good marks for a box verb
Any suggest where can i insert circuit?
In the FX loop is the obvious place.
Which place exactly, do you think?
umm, try FX out to verb in, verb out to FX in maybe
What Do you think here?
does your Belton have jacks for in/out or a glob of wires? maybe post the datasheet for the brick :dontknow:
I was recently messin with one of these.
Search this forum for Belton reverb.
There are a couple good threads that helped me out.
Last
looks like you can just solder up 2 1/4 mono plugs, one for in, one for out, wire up your power and plug them into the FX loop on your amp FXout--->belton in Belton out--->FXin and give it a test run. I would use shielded wire, or cut a guitar cable in half and solder it up.
I found this one in my favorites bar:
https://el34world.com/Forum/index.php?topic=23554.0
:icon_biggrin:
I saw you there!!
I think I have that one archived, but I was busy :laugh:
Thank Guys.. I ll give a look.. Today ill receive the rvb1..i hope ( coronavirus here in Italy is a tragedy)
Connecting the Belton module between FX send and return should work. The problem as I see it (though this is a matter of taste) is the mixer circuit. The dry signal will be reduced as the Reverb (or FX) level is turned up. With the Reverb/FX knob at max, you have zero dry signal.
I would want the dry signal to remain at a constant level, regardless of the Reverb/FX level. The reverb knob should blend in reverb signal, but not change the dry signal level.
I noticed you are right
I connected "by fly" reverb
Pin 7 +5v pin 5 -ground (from external trasformer)
Pin 4 signal in ( send input from fxloop)
Pin 3 ground from fx in e fx out 6.3mm jack
Pin 1 signal out (return input from fxloop)
No reverb
When i turned up loop level, no sound
It seems reverb is not correctly connected however 🙄
--edit--
1Jack was fault...
Reverb works... But after noon setting (12oclock looop pot) effect is too much... Maybe i ve to use some resistance..
Someone have schematic to use?
Don't know if it would help but this is how it's wired into a pedal.
