Amp Stuff => DIY Layout Creator and Custom Boards => Topic started by: EL34 on April 10, 2020, 03:28:16 pm
Title: Converting my old board design program to a .diy file
Post by: EL34 on April 10, 2020, 03:28:16 pm
DIYLC = Do It Yourself Layout Creator
I discontinued the old custom board program
That program can be found here
https://hoffmanamps.com/php/TurretBoard/CustomBoard.php (https://hoffmanamps.com/php/TurretBoard/CustomBoard.php)
If you have previously created a custom board using the program above, go to the link above and convert your custom board to a .diy file.
You can download the .diy file to your computer and save it for future use.
You can then use the .diy file analyzer program to add your custom board to my shopping cart
The analyzer program is here
https://hoffmanamps.com/php/DIYLC/DiyFileAnalyzer.php (https://hoffmanamps.com/php/DIYLC/DiyFileAnalyzer.php)
If you do not need to edit your old custom board file, you do not need to install DIYLC
If you want to edit your old custom board file, you will have to install DIYLC
DIYLC runs on JAVA and works on all computer systems including MACS
You can then open your .diy file in DIYLC, then edit it and save it again
Read some of the other DIYLC topics in this board for more info
You can also watch some of my DIYLC videos for more info
Here's the link to the DIYLC board on my forum with many DIYLC topics
https://el34world.com/Forum/index.php?board=26.0 (https://el34world.com/Forum/index.php?board=26.0)
