Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Tonewolfamps on April 21, 2020, 03:38:02 pm
I made this from a schematic for a guy who wants to build a "clone" of a Matchless Chieftain Reverb and use a board. A real Matchless is entirely point to point, uses 1 watt carbon comp resistors and heavy duty power resistors on the supply and power tubes. Those parts are difficult to source so it isn't a true clone. Thought I share my layout to check my work and also get some feedback.
Here's the full size layout:
https://drive.google.com/file/d/1fSteoeLyykP_doaHeZbxwXEpmTEQ6vP5/view?usp=drivesdk
Here's the schematic I used:
https://www.thetubestore.com/lib/thetubestore/schematics/Matchless/Matchless-Chieftan-Schematic.pdf
If you want help, it would be very helpful to post a schematic for your build.
Too hard to figure out what's right/wrong possibly from a layout drawing.
My mistake.
Seems that a schematic link Is on the post
IMO, OP wish we check if his layout is a copy from the schematic.
Yes schematic is on the post.
I found the original schematic very difficult to read. I've tried to redraw it in a manner that is easier for me to follow.
Assume there may be errors and compare to the original schematic.
Much better Tubenit .
Nice Tubenit. Point B in the power supply needs C2.
* Corrected above. Good catch! Thanks
