Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: silat on May 06, 2020, 10:53:53 pm
Title: Can I use this Pt for the Sluckey's Dual lite build?
Post by: silat on May 06, 2020, 10:53:53 pm
Can I use this Power Transformer for the Dula-lite the 25 V red wires are throwing me off.
https://www.mouser.com/datasheet/2/177/290CZ-1841470.pdf
Title: Re: Can I use this Pt for the Sluckey's Dual lite build?
Post by: DummyLoad on May 07, 2020, 06:13:49 am
no really. not keeping s. lucky's plan as there's no 5V winding and with SS rectifiers, you'd have just over 400V B+. yes, you could use 6V tube rectifier but with a 6CA4 you'd have around 375V B+. 6BW4 (EZ80) around 350V.
hammond 270EX or the classictone 18W set would be better choices. mojone sells heyboer parts 18W PT is laydown only like the original.
https://www.hammfg.com/files/parts/pdf/270EX.pdf (https://www.hammfg.com/files/parts/pdf/270EX.pdf)
http://www.classictone.net/40-18056.pdf (http://www.classictone.net/40-18056.pdf)  upright version.
http://www.classictone.net/40-18035.pdf (http://www.classictone.net/40-18035.pdf)  laydown version.
https://www.mojotone.com/amp-parts/Power-Transformers/British-Style-18-Watt-Power-Transformer (https://www.mojotone.com/amp-parts/Power-Transformers/British-Style-18-Watt-Power-Transformer)
Post by: silat on May 07, 2020, 12:02:43 pm
Thanks DL,
I ordered the Hammond 207EX . I do not know what I was thinking, my Dyslexia must have kicked in? I did not even see the 25 volts until  later on  when I started putting it together..  I must have seen 5 Volts instead of 25.  It was giving me fits.
 :BangHead:
