Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: DummyLoad on May 10, 2020, 05:19:52 am
Title: mixed mode class A amp - e.g., anode and cathode outputs with gain.
Post by: DummyLoad on May 10, 2020, 05:19:52 am
fiddling with a mixed mode AF amp. this was taken from the fender vibroking, a design by bruce zinkey. the plan provides 2 outputs with a moderate amount of gain. the cathode output is in phase with the input and the anode output is out of phase with the input as we'd expect with a RC coupled grounded cathode amp. this one has a twist: both outputs have gain.
some observations:
works really well. impressed with the headroom. i used the values used in an original vibroking amp except for the anode (inverting out) coupling cap.
i grafted this input stage to the 6L6GC practice amp i posted recently out of convenience and because i wanted to hear what is sounded like. schematic attached with telemetry.
AV on the cathode (non-inverting out) is about 10. AV on the anode (inverting out) is about 24. Ibias is about 1.9mA with values indicated with ~280V B+.
in the pics in the link below:
1) input signal from low distortion osc. is ~1KHz @ ~100mV pk.
2) in pic 1 the lower trace is the input signal - Ch.1 set to 100mV (probe 1X). upper trace is cathode out - Ch.2 is set to 1V/div. (probe 1X) sweep at .5ms. trigger source Ch. 1. notice that both channel traces are in phase.
3) in pic 2 the lower trace is the input signal - Ch.1 set to 100mV (probe 1X). upper trace is anode out - Ch.2 is set to 2V/div. (probe 1X) - notice signal is hotter than cathode output and out of phase, as we would expect with a grounded cathode class-A amp.
https://www.dropbox.com/sh/haoolp69r5nowxs/AADGC6NzlEnTmTMTV258aBhMa?dl=0
Title: Re: mixed mode class A amp - e.g., anode and cathode outputs with gain.
Post by: SILVERGUN on May 13, 2020, 09:04:36 am
I have some interest in this because I've had a Vibroking build idea in the holster for quite some time now.
Looking at the schematic it appears that the signal off of the cathode would have a path to ground.
What am I missing?  :dontknow:
Post by: DummyLoad on May 13, 2020, 01:34:29 pm
it's a 270K load resistor: random value pulled out of the breadboard resistor tray. it's simply simulating a load. ;-)
Post by: SILVERGUN on May 13, 2020, 01:45:12 pm
Ahhhh….I see, said the blind man
Post by: DummyLoad on May 13, 2020, 03:16:06 pm
... as he picked up the hammer and saw.
