Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: gja on June 03, 2020, 08:02:42 am
Title: 2e30 tube
Post by: gja on June 03, 2020, 08:02:42 am
Hi everyone,
Sorting out my stuff I found 4 x 2e30 tubes which I salvaged from a radio found in  a dustbin .
Can’t remember what the rest of the tubes were because it was all rusty so I just kept the tubes.
They are 7 pin sockets so before I actually buy the sockets andtry anything with them I was wondering if anyone had any experience, thought I’ d try them in a self split el84 amp which I like a lot.
Any thoughts?
Cheers
Title: Re: 2e30 tube
Post by: DummyLoad on June 03, 2020, 09:17:44 am
at first glance, they seem similar to the US 6AQ5/6005 - except that they have a heater center tap. 6AQ6/6005 use pin 1 & 7 for control grid - the 2e30 uses pin 7 for the heater center tap.
if you decide to try and install them in an amp built for 6AQ5/6005 you need to make sure that amps' pin 7 are NOT wired as a control grid.
for a new build, graft them into any plan that uses 6AQ5/6005 and you shouldn't have any issues - i wouldn't try to bias them as EL84s.
Post by: PRR on June 03, 2020, 05:00:40 pm
Note no uni-potential cathode. This complicates biasing and heating, so much it hardly makes sense.
The real-good application is the original: a mobile transmitter. Can idle cold and heat-up fast on PTT.
https://frank.pocnet.net/sheets/096/2/2E30.pdf
Post by: DummyLoad on June 03, 2020, 06:23:25 pm
i missed that. directly heated, ugh! no need to wonder why there's a CT for the heaters. otherwise electrically it does seem to favor the 6AQ5.
Post by: gja on June 04, 2020, 12:12:34 am
Thanks for your posts, true I forgot about the cathode part...
I’ll keep them for some future, or sell them if anyone’s interested.
Thanks again!
