Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: punkykatt on June 04, 2020, 06:57:28 pm
Hello all, Im looking for a voltage chart or a schematic with voltages for the above amp. Can`t find anything on google. This amp has the 5 12ax7`s. Thank you in advance for any help.
Hoffman has the schematic but no voltages.
Yeah, I know, whats the big secret? Every where I look no voltages on the schematic. My concern is the plate and cathode voltages on V-1 B pin 6 plate and pin 8 cathode. My readings are 60vdc on the plate and .5 vdc on the cathode. Can that be right? The amp seems to play OK.
At 6:56 in this video he gives the poweramp voltages and maybe if you contact him he'll have the preamp voltages. https://www.youtube.com/watch?v=3i8BYwjIxOM (https://www.youtube.com/watch?v=3i8BYwjIxOM)
Never know, most of these YouTubers have to make themselves accessible so you will like and subscribe.
And, I ain't done lookin.
https://www.linkedin.com/in/craighollabaugh/ (https://www.linkedin.com/in/craighollabaugh/)
Look at reply #11 here:
https://music-electronics-forum.com/showthread.php?t=38597 (https://music-electronics-forum.com/showthread.php?t=38597)
:thumbsup:
Plate voltage will be low with a 470K plate resistor. And there's a diode across the cathode resistor that will prevent the cathode from exceeding .6V. I'd say everything is as should be.
Thanks for replies Steve and SG. I found a post from SG`s links where someone else had voltages similar to what I got. Like Steve says everything is as should be. Thanks again.
:thumbsup:
That’s a traumatic read, I remember it from the time :huh:
On that thread I scrolled all the way down and found another tread (Appleousa) that is where someone had posted voltages for V1b pin 6 & 3.
I found some chicken-scratched voltages for a 2210 that I gutted some twenty years ago. Same preamp as 2205. I have a stock 2205, but not here at home and I'm not fixing to go down to the studio anytime soon.
Not quite the same. Your chicken didn't use a 470K plate load and has no diode on the cathode. Makes a big diff in voltages.
My chicken didn't label the stages, but it did have them point in different directions. 83V on the plate and 0.52V on the cathode.
Oops! I jumped on the wrong tube.
Thanks 2deaf, much appreciated. I will print that and keep it in my records.
