Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Travis8 on July 14, 2020, 04:02:06 am
Title: Mesa Boogie Recto-Verb Twenty-Five Problem
Post by: Travis8 on July 14, 2020, 04:02:06 am
Itīs doesnt work, itīs dead.
When I changue the fuse itīs work but he stop working fast.
Some time ago a technical changue the transformer becouse the problem was the same.
2 years later again I must changue the transformer???
Some help please?
Title: Re: Mesa Boogie Recto-Verb Twenty-Five Problem
Post by: tubenit on July 14, 2020, 04:54:35 am
Do you know how to safely work on tube amps?  IF not, please consider taking it back to an amp technician.
IF you do know how to safely work on a tube amp, then:
1)  post high resolution pictures of the chassis interior
2)  post voltage readings on the tubes
3)  describe exactly what the problem is prior to blowing fuses.  When did it stop working?  And are you aware of anything
     that happened prior to it not working?
Have you tried new tubes?
Do you know how to set the bias of the tubes?
IF all the tubes are removed from the amp, does it still blow fuses?
It would be unusual to have to replace a power transformer. It's possible to need to do that but I would guess something else is the problem.
Post by: Travis8 on July 14, 2020, 05:05:08 am
Yes im used to repair amps, but never a mesa boogie... I will take some pictures later.
Post by: SILVERGUN on July 14, 2020, 08:00:51 am
I had one of these fail and it was because a trace on the board had become intermittently open.
It was the filament circuit and I could see it happening because the indicator lamp would blink and then go out after the amp started getting hot.
When I opened the amp up I could see where the trace was burnt and lifted. I got lucky and was able to repair the trace by using some wire to jump across the affected area.
Post by: Travis8 on July 14, 2020, 11:45:50 am
Here is some photos
Post by: Travis8 on July 14, 2020, 11:51:29 am
The fuse is ok now but it doesnt work, it doesnt take on
Post by: dpm309 on July 14, 2020, 12:00:12 pm
You need to use a light bulb limiter. If you don't have one, they are very easy to build and you will find instructions on this website. That way, you will  not keep blowing fuses and can narrow down where you might have a short etc.
Post by: Travis8 on July 14, 2020, 12:06:40 pm
But the fuse is ok, sorry I said bad in the first post.
The problem with the fuse was in the first reparation when the other technical changue the transformer.
Now its doesnīt work but the fuse itīs ok.
Post by: Latole on July 14, 2020, 12:28:02 pm
I agree with Tubenit to ask if you know how to fix.
Read transformer 's secondary voltages and you will know about transformer.....
 I can't find this schematic. I'll use the 22 Calber for voltage.
https://el34world.com/charts/Schematics/files/Mesa_boogie/Boogie_22cal.pdf
Post by: tubenit on July 14, 2020, 01:50:49 pm
Please answer the following questions so we can help you.
Have you tried different tubes?
Have you tried a different speaker?
Have you tried a different guitar and guitar cord?
Are you getting any noise from your speaker?
Have you taken voltages on the tubes plates, grids and cathodes?  Can you share those please?
What was it doing prior to not working?  Was it making any noises?  Was there some intermittent problem?
Please look at these helps on this website for trouble shooting:
- in ARCHIVES    https://el34world.com/Forum/index.php?topic=21999.0
- https://el34world.com/Forum/index.php?topic=19361.0
Post by: Travis8 on July 14, 2020, 01:53:49 pm
Just I doesnt work, is not the speaker or valves.
The light doesnt turn on, I will read values from tubes later
Post by: Travis8 on July 14, 2020, 01:55:47 pm
Also when I turn ``onīī the tubes doesnt get voltage, becouse they all off.
Post by: Latole on July 14, 2020, 02:01:18 pm
You mean NO heaters voltages ? Tubes don't glow ?
Read voltage at transformer secondary
Post by: SILVERGUN on July 14, 2020, 02:07:42 pm
Amp is dead:
1) Is there power to the power switch?
2) Is the power switch working?
3) Is 120V making it to the PT? (check tightness of ribbon cable connections) I would be very suspicious of these
4) What voltages do I have on the secondary of the PT?
5) Etc...
6) Etc...
Post by: Latole on July 14, 2020, 02:25:41 pm
About transformer and power supply ; all amps are same.
What you write, it is a basic issue. The problem is Mesa amps are a nightmare to work on
Post by: Travis8 on July 15, 2020, 02:45:29 am
Amp is dead:
5) Etc...
6) Etc...
Let me look and I answer this questions
Post by: Travis8 on March 22, 2021, 03:46:36 am
Sorry I can't do It before.
The transformer it's not working.
Do you know Where can I buy one from Europe?
I don't know how to find the original transformer. Thanks. :)
Post by: Latole on March 22, 2021, 04:16:58 am
8 months later......Welcome back.
You are sure you have some 240 volts going in the primary ?
You may read some output voltage at heater or B+
Or primary winding is open ????
Read ohms at each winding , you must find a open one or more than one.
Finding a Mesa PT in Europe ???? You may order one from a Mesa dealer ?
Picture for winding only ;
Post by: Travis8 on March 22, 2021, 04:20:55 am
Primary doesnt works
Post by: Latole on March 22, 2021, 04:23:41 am
Do you read ohms ? How many ?
Post by: Latole on March 22, 2021, 04:26:27 am
Some dealer in Europe for Mesa B parts
https://www.banzaimusic.com/search.php?mode=search&page=1&keep_https=yes
Post by: Travis8 on March 22, 2021, 04:39:12 am
The primary is broken, my friend is so good with amps he open and saw that the problem is in the winding.
So I must replace it but I donīt know how to buy the original one.
Thanks :) I will take a look from banzai
Post by: Travis8 on March 22, 2021, 04:56:46 am
Mesa Boogie said this to me: The part number of the Recto-Verb 25 220-240V power transformer is 561841
Can I use this one? https://www.tubeampdoctor.com/en/mains-transf.-for-mesa-boogie-transatlantic-ta15
Post by: Latole on March 22, 2021, 05:00:18 am
I don't know, you have to find the specs of the original one.
Do you have the schematic ?
Tubesamp doctor PT is the same Mesa Boogie part number, he must fit. How can we be 100 % sure ?
