Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: tubenit on August 14, 2020, 09:13:29 am
I am often wrong and could be on this also?
It appears there is a discrepancy in some of the schematics and layouts showing the vactrol wiring for the trem-o-nator?
Can someone help me get this straightened out in my thinking, please?
My trem-o-nator works fine in my amp, I am just trying to get my documentation to be consistent.
Thanks, Tubenit
That part of the Vactrol is just a resistor. And like a resistor, it makes no difference which way it it connected. I'm guessing this is related to the thread on TAG?
I wondered if that was the case. Yes, the TAG thread prompted my reviewing of what I had in documentation.
THANKS! Tubenit
Somewhat related to this- even though it's just grounding the signal, should wires in that path be shielded? I ask because in my latest build, I'm getting a slight buzz that varies with the trem speed and disappears altogether when the resistor side of the vactrol is disconnected from the volume pot.
Or minimized.
It's gotta be a high-impedance point. So the more wire you hang off it, the more crap it will pick up. The LDR can perhaps be right AT the audio path; the LED wires can be long.
