Amp Stuff => Misc Schematics and Layouts => Topic started by: squierstrat on August 29, 2020, 05:26:11 am
Title: First build layout advice - 5F1 in 80s Sidekick chassis
Post by: squierstrat on August 29, 2020, 05:26:11 am
First-time builder, first post. My plan is to build a 5F1 in the cabinet and chassis of my mid-80s Fender Sidekick. I would like to leave the front panel looking like the old amp with the on/off switch, volume, and inputs working there. The attached layout is to scale for the 14" x 7-1/2" horizontal chassis, with bottom mounted tubes. I have some nagging doubts that building a 5F1 in such a big chassis will cause issues I have not anticipated. So questions...
1. Is this chassis too big and I need to go back to the drawing board?
2. Assuming the chassis is ok, should I space things out as in my diagram or should I push some things closer together?
3. Any other layout issues to consider?
Thanks for the help. Sorry for not using DIY Layout creator, I had already started in OmniGraffle before I discovered it.
-Dan
Title: Re: First build layout advice - 5F1 in 80s Sidekick chassis
Post by: sluckey on August 29, 2020, 08:29:15 am
I think your layout is fine. There are several major wiring errors though.
Post by: squierstrat on August 29, 2020, 11:20:50 am
Thank you. I did some work on the layout and fixed several errors.
Post by: oosborne on August 30, 2020, 07:30:54 am
Hi Squierstrat,
there are some advantages if you solder the gridstoppers directly at the tube sockets. eg less danger of oscillations.
And I remembering that power earth should be soldered alone with one screw to the chassis for security issues.
Did you already start building it?
OOs
