... for a firefly amp, I come up with 2 different tube possibilities. The 12BH7 and the 6FQ7/CG7 ... The 12BH7 has a max ... per plate of 3.5 watts, or 7 watts, both plates driven.
The 6FQ7 has a max ... of 4 watts each, but only 5.7 watts both plates driven. ...
You may want to think about whether it's desirable to make the Firefly louder: there's already many ways to build a 4+ watt amp.
A different way to think of the problem is, "How loud do I want the amp to be?".
Imperfect as it may be, the guys on That Pedal Show have a dB-meter (https://www.youtube.com/watch?v=eoKs-X7I6zs&t=1190s) in the right corner of the room. The response is slow, it's off-axis from the speaker(s) and more than 1-meter away, but it does provide an indication of relative loudness. 30-40 watt amps just starting to compress & distort in their videos tend to register ~105-110dB, and would read higher if the meter were moved to the usual measuring position. 60-70dB SPL is on the quiet(er) end of things, depending on your living situation & preferred hour to practice. See the graphic below.
The chosen speaker has as much or more impact than amp-power, and sensitivity ratings (dB SPL at 1w, measured 1m away) tend to vary from ~93dB to 100dB (or slightly more).
dB SPL when Amp-Power is Known:
dB SPL = 10 log (Amp Power / 1 watt) + Speaker Sensitivity for 1 watt
Amp-Power needed when dB SPL & Speaker Sensitivity are Known:
Amp Power = 10[(dB SPL - Speaker Sensitivity)/10]
If I want my amp's power tube(s) to distort at 75dB SPL and have a 98dB speaker (https://www.jensentone.com/vintage-ceramic/c12n), then
Amp Power = 10[(75dB - 98dB)/10] = 10[-2.3] = 5 milliwatts (!)
CHECK: dB SPL = 10 log (0.005 watts) + 98dB = -23 + 98dB = 75dB SPL
- Pipsqueak amps are louder than you'd expect with sensitive speakers.
- Amp-power reduction has less impact than you'd expect.
- Insensitive speakers for guitar aren't easy/cheap to find.
https://georgeantonios.com/wp-content/uploads/2017/05/volumelevels.jpg (https://georgeantonios.com/wp-content/uploads/2017/05/volumelevels.jpg)
