Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: yorgle on October 21, 2020, 02:59:15 pm
On all of my builds so far, I've used #4-40 machine screws and nuts to bolt tube sockets to the chassis. Once I'm satisfied that I don't need to take things apart again, I put a dab of superglue on the exposed threads/nut and that has worked well for my limited, living room use. But I wonder how that would hold up if the amp were being dragged/banged/kicked/dropped about to and from gigs. What do the grey-beards here use?
I use 4-40 but I just tap the chassis. I don't use a nut. And I don't abuse my amps by playing them! :l2:
But, if the amp were being dragged/banged/kicked/dropped about to and from gigs, I would put a drop of Loctite thread-locker on the screw threads then put a kep nut on the screw. Probably a good idea for every screw in the amp, especially on transformers.
I have a big grey beard so I guess I have to answer - I use kep nuts throughout the chassis. #4s for 9 pin sockets and 4s or 6s for octals, 8s for trannies. My amps stay home, but if I did tote them around I'd prefer the Loctite. I've used that on bicycles and motorcycles for years with good success. One of my bikes is a vintage Triumph - that thing needs lots of Loctite. :icon_biggrin:
I thought you used rivets. Maybe my memory is gone.
Oh no. Never used any rivets.
http://sluckeyamps.com/supro/supro_02_big.jpg
I use bolt, lock washer and nut,
Never rivets.
I started with nuts n bolts n washers....bought rivets, gives it that '40s feel :icon_biggrin:
...I use kep nuts...
+1.
Kep nuts here also.
It's include kep nut in my answer 'cause they are nut with lock washer.
In other word, bolt and nut is not enough to stay tight over years
I use a lock washer, and locknuts. No loctite, and always worked great.
I started doing this after I read a document from Rod Elliot about earthing:
https://sound-au.com/earthing.htm
For tube socket, wich is the subject ;
It's like using a belt and suspenders to hold your pants no ?
If you want to use locknut, regular flat washer is enough to hold any mechanical stuff.
Teeth or lock washer is a must for electrical connection to "bite" into the metal and ensure a good contact and to hold nut always tight.
Regular flat washer is enough.
hehe Yes, I guess you are probably right. I connect my mains safety earths like this, see attachment, so I guess I got used to use both locknuts and lock washers.
Your pic looks like a locknut and flat washer?
Too much hardware for small job,
If you built a bridge this way it would cost so much that no country could afford it and it would be so heavy it would collapse.... :l2:
Yes, it looks like flat but it's a lock washer. See how it's not flat touching the chassis, but stays somewhat above while the teeth are biting it
Hahaha, yeah too much hardware for a tube socket I suppose.
Safety earth connection is another story, though, and regulations vary from country to country.
for the 7 & 9 pin miniature sockets, i use 4-40 hardware with keps (k-lock) nuts and an internal tooth washer on the bolt head end.
for octal i use 6-32 with the same washer/keps nut/ compliment.
Yes, Elliot recommends just that while acknowledging this earth ground setup as overkill. But FranciscoPerez is off topic: Elliot says this ONLY for the ground connection and not to be used for components such as a a tube socket, the topic under discussion: "Do not use the earth connection as mounting for any other panel or component - it must be dedicated to the task of providing a safety earth point. If a component mounting bolt is used, at some stage it may be disconnected by a service (or other) person, which means that the apparatus is unsafe until everything is (hopefully) put back where it belongs - this does not always happen."
I use M3 fasteners for most all my 9-pin sockets, and standoffs.
It may seem a bit pedantic, but I think its far superior to 4-40. Im an American, and I think all metric threads are for the most part.
For small insulated turrets and terminals, they often have 2-56 threads, so I’ll usually tap the chassis to mount them directly using thread locker.
+1 with Sluckey
When I have had to repair/replace sockets, and they have been riveted, can be a pain to drill out the rivet neatly. It was a common practice in Australia for a couple of manufacturers in the 60's and 70's to use rivets.
We're Metric in Aussie so I use an M3x6 with Locknut but it's fiddly. Don't mind the screws in Noval Skts as long as the chassis thickness is sensible.
Soulfetish "Pedantic" is good :laugh: :l2:
Regards
Mirek
