Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: vratocaster on October 29, 2020, 09:43:47 pm
Hi guys... I'm starting with a tube preamp pedal based in sluckey marshall schematic. The output signal will be ok to work with a power amp/power amp in.
My question is: How I can get properly line signal to go from the preamp output to feed pedals? Do I need some pad attenuation? The 1 meg master volume pot will be enough to drive the properly signal level?
Probably gonna need a cathode follower after the master volume pot.
Thanks @sluckey! Please give some advice, Wich is better in this case ? Triode CF or Mosfet CF?
