Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Bash on November 18, 2020, 07:54:08 am
Title: Another Supro 6424 build (at least, when I have all the parts)
Post by: Bash on November 18, 2020, 07:54:08 am
Hi everyone,
Some time ago I build an AC18 (like a single channel 18 Watt AC15, without tremolo) and now I want to build a matching Supro DualTone amp.
Like some others here I would like to build a Supro 6424 amplifier, based on Steve Luckey's schematic and layout.
I changed the lalyout a bit, so it will fit all the turretboard and chassis that I have.
So, yes. It will be a vertically mounted amplifier.
Attached you can find the PDF with my updated layout. I thought it might be fun to add the possibility to switch between parallel and series for the preamp.
Will this be a good idea?
Is there any reason why I really should not do this?
BTW I updated the layout and removed the series option. It did not sound nice at all.
Title: Re: Another Supro 6424 build (at least, when I have all the parts)
Post by: bmccowan on November 18, 2020, 08:05:45 am
Hey Bash, I think you accidently put the handle and feet in the wrong place on that amp. :icon_biggrin:
Kidding aside, as it looks like very nice work, do you have a schematic drawing of that switch arrangement?
Post by: sluckey on November 18, 2020, 08:08:21 am
Sounds like a fun project. I'll be following this thread with interest. Nice looking amp in your pic.
Post by: SILVERGUN on November 18, 2020, 08:46:56 am
In an attempt to help you stay straight, what do you mean by "parallel and series"?
Sluckeys input switch is a great idea and there is no reason why you shouldn't try it. I'm assuming this is what you were referring to:
Post by: Bash on November 18, 2020, 08:57:56 am
No, I wanted to try something else.
The two preamps in the original Supro design (and in Sluckey's schematic) are used in parallel.
The input signal is split and handled seperately by the two independent preamps.
His switch makes it possible to use either preamp one, preamp two or both in parallel.
My idea is to offer two inputs. One will use only a single preamp.
The other will use both preamps. By default this will be in parallel, but I wanted to add a switching option to use them in series.
Hopefully this would provide more gain, and possibly you can use the first preamp's volume to define the gain and the second one to be used as some kind of master volume.
Post by: Bash on November 18, 2020, 08:59:41 am
Somewhere on a piece of paper, done with pencil.
I translated it quickly to a layout (see attachement in my original post).
Post by: bmccowan on November 18, 2020, 09:41:12 am
I have a hard time following layouts - but I think your layout has some mistakes - ex. look at pin 6 on your preamp tubes.
Post by: Bash on November 18, 2020, 10:00:21 am
Damn, you are right. I connected the OT to pin 6 instead of 9 (because the numbers are shown around the tubes on the schematic, my brain turned the sixes into nines).
Thanks.
I updated the PDF in the original post.
Post by: sluckey on November 18, 2020, 10:15:22 am
 :laugh:
Post by: Bash on November 18, 2020, 10:22:27 am
I am pretty sure it would not have sounded like that...  :BangHead:
Post by: Bash on November 18, 2020, 10:23:47 am
And Sluckey, I would also like to really thank you for your great and informative site (which I plundered a bit).
But, coming back to my original question: is there any reason not to try out connecting the preamps in series?
Post by: SILVERGUN on November 18, 2020, 10:33:44 am
Most of us would like to see a schematic drawing of how. It can be in pencil on some toilet paper, that would be better than trying to decipher the circuit from the layout.
Post by: sluckey on November 18, 2020, 10:40:49 am
Lot of people try to cascade one preamp into another. Might take a little fiddling around. The amp sounds pretty gritty as is but when you cascade the preamps, it's gonna sound hot and nasty. Go for it. Let us know what you think.
Post by: Bieworm on November 18, 2020, 12:00:17 pm
But be aware that the volume boosts hard in cascade mode... it ain't just more gain. Forget about switching that thinking it's the same volume level. I did that with my 18W and it's boom!! Muuuuch more volume
Post by: Bieworm on November 18, 2020, 12:01:49 pm
Good catch. The brown wire shoukd be at the nr9 lugs instead of nr6. For the preamp tubes that is..
Post by: bmccowan on November 18, 2020, 12:18:24 pm
The 18W TMB will maybe provide some ideas for the fiddling. I built a TMB and the cascaded channel is indeed hot and nasty. I'm too old for hot and nasty, so I fiddled with it a lot to tame that channel. I plan to convert the power amp to 6973s (just because I like to fiddle) and that will not be a lot different from what you are suggesting.
Post by: Bash on November 18, 2020, 12:38:35 pm
Well, by popular request: here it is.
Post by: Bash on November 18, 2020, 12:42:48 pm
Well, I am hoping I will get a bit of nasty.
If I don't like it, it is easily removed to "normal" configuration.
BTW I happen to own a real Supro DualTone (one of the new ones) so I am curious how it will compare.
Post by: SILVERGUN on November 18, 2020, 01:00:08 pm
From a thisgoesintothat standpoint your switching idea looks good, with a standard DPDT on-on switch
Post by: SILVERGUN on November 18, 2020, 04:54:03 pm
If you don't have an OT yet I would suggest snatching up one of these before they are gone. The manufacturer is going out of business.
https://tubedepot.com/products/classictone-output-transformer-40-18063
Post by: Bash on November 19, 2020, 02:31:14 am
@Silvergun Thank you for the tip.
Unfortunately it is nowadays a bit of a hassle to get stuff from the USA shipped to Europe (and shipping has become very expensive).
So, I'll first try the same output transformer I used in the AC18.
Post by: Bash on November 19, 2020, 07:30:07 am
On another forum (that is mostly in German, which I can read reasonably) I got the following tips:
1. 6973 has Grid #1 connected to Pin 3 and 6, I would bridge these pins to avoid having one side "floating"
2. same for Grid #2 , 6973 has Grid #2 connected to Pin 1 and 8, I would bridge these pins to avoid having one side "floating"
If I look at the schematic I see this as well.
Just not in the layout nor photographs.
I made the adjustment to the layout and added them to the first post.
Post by: sluckey on November 19, 2020, 07:52:57 am
Say what??? No, no, no! The pins are bridged together ***INSIDE*** the tube. Take those external jumpers off the sockets.
Post by: Bash on November 19, 2020, 08:20:04 am
I will immediately...
Thanks.
Post by: sluckey on November 19, 2020, 09:16:43 am
Haha. Just kidding. I just wanted to make the point that the jumpers already exist inside the tube. External jumpers are redundant but they wont hurt anything. I found a photo that may interest you. Pins 1 and 8 are jumpered on the socket. That's redundant but perhaps there is some reason that I don't see. But pins 3 and 6 are interesting. Notice that the grid resistor is on pin 3, but the coupling cap is on pin 6. I suspect this is just a convenience for the point to point wiring. Anyhow, lot's of ways to skin a cat.
BTW, I just now verified with my eyes and my ohm meter that the jumpers are really inside the tube.
Post by: Bash on November 19, 2020, 09:24:29 am
I figured as much. Just shorting a short  :think1:
I found that information as well (should have done that beforehand)
The only reason I can find to jumper 1 and 8 is for using a 6CZ5 instead of a 6973.
For now, I have no intention to do so.
Post by: bmccowan on November 19, 2020, 10:27:17 am
Jumping 1&8 allows using 6CZ5 as you state, and also 6CM6 which is closer to the sound of a 6V6. I have 3 6973 amps and added that jumper to all. The reason - the NOS stock RCA 6CZ5s sound better than new EH 6973s. I have bought both RCA and Sylvania 6CZ5s. The Sylvanias do not physically resemble a 6973 and do not sound as good. But as near as I can tell, and I have, out of curiosity, compared the RCA 6973s and 6CZ5s with a magnifying glass, the structure is identical except for the pin connection. Yes they supposedly have a lower voltage rating, and some claim they sound different; but I say they are twins; structure and sound.
RCA 6CZ5s are still available on ebay for $10. Half the price of the EH. Unless the seller knows the above, then they double the price.
So I say connect the pins and try those tubes.
Post by: Bash on November 19, 2020, 10:49:14 am
Thanks bmccowan.
That is a good thing to keep in mind.
Unfortunately 6CZ5's are a bit less common in Europe.
Or people know what they are and ask high prices.
Post by: bmccowan on November 19, 2020, 12:05:54 pm
Ah, you are across the pond. I hope things are going ok in your location. Things are a bit crazed here!
Post by: Bash on November 19, 2020, 01:00:23 pm
Well, concerning Corona: things are slowly improving over here.
Still, no restaurants, no live music, etc.
Luckily, Dutch politics are mostly boring (which usually is a good thing).
Post by: Bieworm on November 19, 2020, 01:46:45 pm
Lucky you! Here in belgium it's still prison. No practices.. that's the crap man!!! Brand New amp built and no chance to really try it out...
Post by: Tirol29 on November 19, 2020, 06:07:17 pm
Thanks bmccowan.
try here :
https://electols.com/shopping/fr/audio/68095-6CZ5.html
https://electols.com/shopping/fr/tubes/96774-6973.html
Post by: sluckey on November 19, 2020, 09:28:13 pm
Y'all peaked my interest in the 6CZ5 so I started looking. Right off the bat I see that the RCA tube manual says pin 8 is internal connection. Do not use. But why? RCA doesn't elaborate. So, why would you want to put a jumper on a 6973 socket to operate a 6CZ5?
Seems to me that if the 6973 socket has pin 1 wired for the screen and nothing on pin 8, the 6CZ5 should drop right in.
     https://www.tubesandmore.com/sites/default/files/associated_files/6cz5.pdf
     https://www.tubesandmore.com/sites/default/files/associated_files/6973.pdf
Post by: Tirol29 on November 20, 2020, 03:43:27 am
RCA RC-30 1975 receiving tube manual says pin1 and 8 connected to G2 (p 491)  :smiley:
Post by: Bash on November 20, 2020, 06:00:50 am
try here :
Thanks. I will have a look.
Post by: sluckey on November 20, 2020, 08:57:28 am
We know. Not talking about the tube. Talking about the socket.
Post by: bmccowan on November 20, 2020, 09:06:35 am
Steve brings up interesting points which made me go surfing. Found this:
http://www.bustedgear.com/repair_Valco_62-90_tube_6973_3.html (http://www.bustedgear.com/repair_Valco_62-90_tube_6973_3.html)
When I put the jumpers in my amps - two Valcos and one I built. I blindly followed advice on the Web (always a good idea, right?) and found many amp users who were successfully using the jumpered sockets. Since jumping my amps, I have used 6973s, 6CZ5s, and 6CM6s in them with no negative issues. The 6CM6 lists no connection for pin 8.
But it appears that by using pin 1 on the sockets, that achieves the result? I do not recall which way the PT sockets are wired in the Valcos I own. Guess I'll need to open them up.
Datasheets for 6CZ5 indeed state "internal connection" - to what? is my question. Interesting discussion that is venturing beyond my vacuum tube knowledge level. :w2:
Post by: sluckey on November 20, 2020, 09:52:24 am
That link backs up my point perfectly. Valco had the screen wires on socket pin 8, which works perfectly well for 6873s, since pin 1 and 8 are jumpered together INTERNALLY. But in order to use the 6CZ5, the guy had to move the wires from pin 8 to pin 1, since the 6CZ5 screen is internally connected to only pin 1. Now you can use either tube in the socket.
Still don't know what 6CZ5 pin 8 is internally connected to. Since you have some could you take a close look? And use your ohm meter to see if there's continuity from pin 8 to pin 1. In fact, see is there is continuity between pin 8 and any other pins.
I ran into a similar situation with some old 6BQ5s (EL84s). Tube manual shows pin 1 as internal connection Do not use. But in fact my old 6BQ5s had pin 1 jumpered to pin 2. Modern 6BQ5s or EL84s don't connect pin 1 to anything so it can be used as a convenient tie point. In fact Hoffman uses it to mount a grid stopper resistor in his Stout amp. Works fine with most new tubes, but the jumper in my ols 6BQ5s wouls simply short out the grid stopper in the Stout.
Post by: bmccowan on November 20, 2020, 10:46:06 am
I will look and meter.
6BQ5s - I have several old Baldwin and Hammond labeled 6BQ5s. I'm wondering about those?
Post by: sluckey on November 20, 2020, 11:42:46 am
Here's my 6BQ5. You can easily see that pins 1 and 2 are jumpered together.
Post by: bmccowan on November 20, 2020, 01:30:52 pm
I looked under a lighted magnifying glass at Sylvania, Tung-sol, and RCA 6cz5s. Pin 8 has no connection. It just stubs up through the support disc and dead-ends. To be sure, I metered - no continuity with any other pins.
Looking very closely, the Sylvania and Tung-sol clearly came off the same production line - not too unusual. The RCA has some distinct differences. A pic of the RCA is attached.
I have not looked at the old Baldwin and Hammond 6bq5s yet - first I need to find them :icon_biggrin:
Post by: Tirol29 on November 20, 2020, 04:11:02 pm
sorry, should have read more and keep silent  :rolleyes:
Post by: Bash on November 24, 2020, 08:34:46 am
I am still waiting for all the parts to arrive.
Still no chassis or turret board, which makes it a bit hard to start.
Also found out that it has become impossible to get Supro-like tolex. So instead of making it blue, the amp will become exactly the same as the AC18 combo.
I am still on the lookout for a good speaker to put in the DualTone.
For now I think I will go with a WGS G12 C/S.
Any other suggestions?
Post by: sluckey on November 24, 2020, 08:52:04 am
Put some long legs on the cab so us old farts don't have to think about bending over.   :l2:
Post by: Bash on November 24, 2020, 09:07:42 am
I am nearly 51 myself, so maybe I should start taking these things into account.
It also makes it look even more like an ancient television set.
Post by: shooter on November 24, 2020, 09:15:35 am
just toss a rope over the stage lights and adjust height as needed  :icon_biggrin:
Post by: SILVERGUN on November 24, 2020, 09:19:06 am
If you're trying to nail the Jimmy Page tone I would suggest the Jensen P12Q based on the fact that the Sundragon amp wound up using that speaker. See 2:00 in this video.
https://www.youtube.com/watch?v=HNCIAZYS8yc&feature=emb_logo (https://www.youtube.com/watch?v=HNCIAZYS8yc&feature=emb_logo)
And, this fancy little pontificator of tone came up with the Jensen C12R:
https://www.youtube.com/watch?v=9nwBSqSREfg (https://www.youtube.com/watch?v=9nwBSqSREfg)
Post by: Bash on November 24, 2020, 12:21:01 pm
Yay! The parts arrived today.
Finally, I can start.
The Jensens are on my list as well. I will first build the amp and just see how it sounds through the speakers I have at hand (Celestion Gold, Supro DT12 and an Eminence Red Fang).
BTW I am not necessarily looking for sounding like Page.
NO matter what I play, I always end up sounding like myself anyway.
Post by: Bash on November 29, 2020, 10:17:57 am
Finally had time to use the soldering iron (a fulltime job and 3 kids tend to get in the way).
I've finished all connection to the pots and the power connection to the preamp tubes and power amp tubes.
Also found a mistake in my layout drawing (connected the 270k resistor to the wrong lug of volume 2), which I have updated in the first post.
Also started hammering away to get the turrets on the board.
Post by: Bash on December 02, 2020, 03:35:06 pm
Very little time to make any progress, due to preparations for the St. Nicholas festivities upcoming weekend.
So, mostly loose wires still.
Luckily I was able to find a worthy replacement for the blue Tolex (Pewter Trout Slub Bronco, that really is the name), which still has to be imported from the states.
So I will end up with a blond/charcoal pair of amps.
Post by: bmccowan on December 03, 2020, 09:03:51 am
That's nice Tolex. I like it. Where did you find it? I only see it from Canadian suppliers. I see /13 is using it.
Post by: Bash on December 03, 2020, 02:24:26 pm
Just found another mistake (more like an omission).
I forgot two wires at the reverse side of the board, so I updated the PDF.
During soldering I was wondering why two capacitors would lead to a dead end.
Post by: Bash on December 03, 2020, 02:28:14 pm
The manufacturer is Kayline. They list it as "Pewter Trout Slub Bronco".
Mojotone sells something called  "Blackened Tuna Tolex", which seems to be the exact same material.
In Europe TubeTown is one of the dealers. The color is new, so they do not have it yet. Should arrive in February.
That is a long time to wait, but at least gives me enough time to finish the amp and figure out which speaker is the best match.
Post by: bmccowan on December 03, 2020, 05:02:30 pm
Thanks - found Kayline - great selection. The Vintage Amethyst Bronco looks interesting too for a Valco build. They are in New Jersey but oddly the only dealers that list it are in Canada. I contacted Kayline. Mojo's Blackened Tuna does indeed look like the Trout stuff.
Post by: Bash on December 04, 2020, 03:45:08 am
I found that one too, but it is a bit too purple for my taste.
Post by: Bash on December 07, 2020, 01:45:57 am
Finally had the time to progress a bit.
The board has been populated and all the wires attached to it.
It is mounted inside the chassis, but I still not to connect all the wires from it.
Again, found a few mistakes (resistor values), so I have updated the pdf.
Also reduced the number of ground wires that are needed, by adding a few shorts on the board.
Updated the colors of the wires to match the actual colors that I used (not useful for anybody but me).
Post by: Bash on December 09, 2020, 05:29:25 am
Finally finished the amp.
In the end I removed the series/parallel option.
The amp really did not sound nice in series and it made some of the wiring needlessly complex (I updated my layout file in the first post).
So now the amp has two inputs:
-Input one is both preamps
-Input two is only the tremolo preamp
My first impressions.
I tried it out using two speakers:
-A Supro DT12, which came in my reissue Supro DualTone
-A Celestion Alnico Gold, which is installed in the AC18 shown in the first post
I really had the chance to compare it to the reissue Supro DualTone, and in my home-build one sounds better. And  I always really loved the reissue.
The reissue has more bottom end, but can be bass heavy. The difference is not that big.
The biggest difference is in the highs. The home-build one has plenty of highs, but does not sound shrill. The reissue can become a lot more piercing in the high end. Certainly at higher volumes.
As a results the home-build DualTone sounds a lot better using fuzz pedals. It really sings in a nice and creamy way that the reissue simply doesn't do.
I don't think that difference can be completely attributed to the difference in tubes. The reissue has all EHX tubes, my home-build one has JJ's for the preamp and rectifier and RCA 6CZ5's for the power tubes (I also tried it with EHX 6973, but that did not really make a big difference).
That was when using the speaker from the reissue DualTone.
When switching over to the Alnico Gold the first thing you notice is volume. Damn, that speaker is loud. A lot louder than the DT12. More bass as well.
It doesn't sound bad at all, but for me the Alnico Gold is not the right speaker for the DualTone. It simply doesn't fit very well.
To me it sounds as if it is trying to make the DualTone like a Vox amp, which feels a bit like Mel Gibson trying to sound Scottish.
Hopefully I have some time to record the amp (will post clips).
Overall I am really pleased with the amp so far.
The reissue will be leaving soon, I guess.
One question
The range of the tremolo speed is very limited. It goes from rather fast to fast. No slow or very fast options.
Any idea how to enlarge the range?
Post by: sluckey on December 09, 2020, 08:45:17 am
First, you have a 270K resistor on the INT pot. That should be 2.2M.
You can replace the 1K resistor that's connected to V3-8 with a red LED (anode to the tube). This will greatly increase the tremolo oscillator output and "allow" a larger speed range. You'll likely need to increase the size of that onboard 1M resistor that connects to the FS jack to decrease the tremolo signal to prevent overdriving the preamp.
Now you can experiment with the speed. There are two things you can do. Increasing the value of any of the three feedback caps (.033, .022, .01) will slow the speed. I'd experiment with one cap at a time. I'd replace the onboard .033 with a .022 to increase the speed. Then use a SPST switch to connect the removed .033 in parallel with that new .022 to give you a slow speed range. This may be all you need to do. Here's an example. Look at page 2...  http://sluckeyamps.com/RCA/Ampeg_J12B.pdf
Another thing to try... Replace the 100K onboard resistor (the one that connects to the speed pot) with a 47K. This should increase the speed. Now replace that ground jumper on the speed pot with a 470K resistor to slow the speed. If you like this, then put a SPST switch across the 470K so you will have a Fast/Slow speed range.
30 minutes of experimenting should give you some joy.
Post by: Bash on December 09, 2020, 09:41:52 am
Hi Slucky.
Thank you very much. I can't state sufficiently how grateful I am for your input and original work.
I will start experimenting (hopefully) this evening.
Post by: Bash on December 09, 2020, 01:37:30 pm
I experimented a bit.
First replaced the 270K resistor for the correct 2.2M one.
That mostly decreased the depth of the tremolo. So I changed it back, so the tremolo can become a bit choppy (almost on/off).
Also replaced he 100K resistor for a red LED. Did not need to change the other resistor. The preamp does not overload at all.
After a bit of experimenting I found that the best speed range for me was putting a 22nF paralle to the 10nF one.
Post by: sluckey on December 09, 2020, 03:10:55 pm
100K??? I hope that's a typo. The LED should replace the 1K resistor that's connected to V3 pin 8.
I did a bit of experimenting on mine too. I already had the red LED in mine so I'll use that as my baseline.
The baseline speed range is 3.46Hz to 6.24Hz. Not very wide.
Changed the .033 to .022. Speed range now 3.9Hz to 7.2Hz. Better fast speed.
Connected the .033 in parallel with the .022. Speed range now 2.84Hz to 5.16Hz. Much better slow speed.
Put the .033 on a switch to provide a slow and fast speed range. Now the total range is 2.84Hz to 7.2Hz. Very usable for me. This is how I left mine.
Post by: PRR on December 09, 2020, 10:43:39 pm
The LFO uses a 3-section network with one R variable 100k to 600k.
To a fair approximation the frequency will shift third-root of R or about 1.817.
Checks:
3.46Hz times 1.817 is 6.29 (measured 6.24Hz)
0.022... 3.9Hz times 1.817 is 7.1 (measured 7.2Hz)
0.055.... 2.84Hz times 1.817 is 5.16Hz (measured 5.16Hz)
IMHO the range "should be" over 2:1 so you can octave-transpose to meet your beat. But this is rarely done.
It is possible the SPEED pot could be 1Meg for 2.22X variation of rate. 22% more, a little, not a lot. But this is similar to Fender.
Changing _2_ of the Rs to pot-sections (a dual-gang pot) would give (for 500k+100k) more like X^(2/3) 3.3:1 ratio of speeds.
Post by: Bash on December 10, 2020, 02:22:01 am
Yes, that was a typo. I replaced the correct one.
I am not entirely sure what you mean by this.
Do you suggest replacing the 100K + 500K potmeter by a dual gang pot?
Post by: sluckey on December 10, 2020, 08:19:43 am
Yes. One pot would be wired just as it it now. The second 500K pot plus 100K would replace the 1M.
Sunn used a triple ganged pot to change all three resistors in the feedback loop.
     http://sluckeyamps.com/sunn/sunn_sceptre_1971.pdf
Post by: Bash on December 10, 2020, 10:36:57 am
OK. Clear.
Now I wish the tremolo pots and the resistors and capacitors were a bit closer together in my layout  :BangHead:
Good luck finding one of these...
Well, I don't have any dual-ganged pots around (or many other parts for that matter).
So I'll have to go shopping in the weekend before I can experiment a bit more.
Post by: sluckey on December 10, 2020, 01:10:06 pm
I tried PRR's suggested dual 500K pot. Also changed two caps. Speed goes from too slow to too fast. See pic...
Post by: Bash on December 11, 2020, 03:26:46 am
That looks great, indeed.
Will try that this weekend.
Updated my layout accordingly.
BTW I really recommend reducing that 2.2M resistor that is connected to the intensity pot, for that "How soon is now" sound.
Used 270K myself.
Post by: sluckey on December 11, 2020, 08:34:09 am
I'll give it a try while I have the amp on the bench.
Post by: Bash on December 11, 2020, 02:57:03 pm
Just performed all the changes.
Yes, it does work like a charm.
Nice range for both the intensity and the speed.
Thank you for all the help and tips.
Post by: Bash on December 13, 2020, 04:08:26 pm
Made a few quick recordings of the amps.
The ones labelled DualTone are from  my own-built amp.
The ones labelled Supro are from my reissue Supro DualTone.
Played everything on a Telecaster with a maple neck and Lindy Fralin pickups.
All tracks with a little bit of delay from a delay pedal. At the end of the first track I switched the boost part on of a JDM Tonemaster (=Germanium boost).
With the second track I use a homebuilt Solasound One Knob Fuzz copy.
The last track is just comparing the tremolos of both amps.
For all recordings I used a TwoNotes Torpedo Captor X with the exact same setting for the speaker emulation. That way I was sure I was really comparing the two amps and not possible differences in microphone placement.
I chose not to use a looper pedal for the recordings, but simply play everything twice.
In the past I have used a looper to that, but I noticed that I changed my playing slightly, based on how the amps reacted.
Dual Tone track 1:
https://soundcloud.com/user-489882423/dualton-1?in=user-489882423/sets/dualtone-recordings (https://soundcloud.com/user-489882423/dualton-1?in=user-489882423/sets/dualtone-recordings)
Supro track 1:
https://soundcloud.com/user-489882423/supro-1?in=user-489882423/sets/dualtone-recordings
Dual Tone track 2:
https://soundcloud.com/user-489882423/dualtone-2?in=user-489882423/sets/dualtone-recordings
Supro track 2:
https://soundcloud.com/user-489882423/supro-2?in=user-489882423/sets/dualtone-recordings
Dual Tone track 3:
https://soundcloud.com/user-489882423/dualtone-3?in=user-489882423/sets/dualtone-recordings
Supro track 3:
https://soundcloud.com/user-489882423/supro-3?in=user-489882423/sets/dualtone-recordings
Post by: vampwizzard on December 13, 2020, 04:17:53 pm
sounds great! especially the fuzzy tones.
Post by: Bash on December 13, 2020, 04:19:30 pm
Thanks. That amp really likes old-school fuzzes and volume boosts.
Post by: SILVERGUN on December 16, 2020, 11:58:39 am
Thanks for all of those samples.
That tremolo on the Dual Tone Track 3 is strong. Pretty close to the 'How Soon is Now' effect. (I like the Supro version also)
Post by: Bash on December 17, 2020, 03:38:45 am
That is what happens when you make the mistake to use a 270K instead of a 2.2M resistor.
For now I like it.
It can sound closer to the Supro, by either turning the intensity down a bit, or mixing in channel two.
Post by: Bash on April 09, 2021, 02:29:12 am
Damn, getting that Tolex took ages.
So finally I have the cabinet done.
Really pleased with the result.
In the end, I settled on using a Celestion A-type in it, which sounds really nice.
Also tried the Jensen P12Q in it, but that was really overly bright for my taste.
Post by: TIMBO on April 09, 2021, 03:48:05 am
AWESOME!!!!
Post by: Bash on April 10, 2021, 03:13:01 pm
AWESOME!!!!
Thanks.
And they sound really great together. They really complement each other.
Post by: dbishopbliss on April 12, 2021, 02:25:52 pm
Coincidentally, I just recovered my Silvertone 1482 in Blackened Tuna so it will have a similar look to your amp with the vertical chassis. I'm working on covering the baffle later tonight. I also just built a 1x12 (really big) for my VOX AC15 and I'm working on the head cabinet that will also be covered in tuna.
My question is, where did you get your face plates made? They look really sharp!
Post by: Bash on April 20, 2021, 03:01:31 am
I had them made in Germany at tube-town.de
Since I live in the Netherlands, that was the best solution.
I am now going to use the same Tolex for covering a speaker cab with a Yamaha Ja1701a inside (the rotating speaker unit from old Yamaha organs and Ra-200 amps).
Post by: Bash on April 25, 2021, 02:03:41 pm
I decided to add a permanent power soak on the second output of the amp.
That way I can turn up the volume more, without going completely deaf, and the volume of the internal speaker (when I connect it to the second output) is in better balance with the volume of the rotating speaker (which is less efficient than the Celestion A-type).
I used a TRS input to make sure that the 8 Ohm resistor is not messing thing up when there is no plug in the second output.
I used two pairs of 20 Watt resistors in parallel to be sure they could handle the power (even though the amp is just 18 Watt).
Post by: Bash on July 12, 2021, 02:03:21 am
And finally I had the time (and all the parts) to finish the matching cabinet, for the Yamaha rotary speaker (salvaged from an old organ).
I am rather pleased with the results.
Post by: Bash on July 12, 2021, 02:04:24 am
And the final results.
Post by: Willabe on July 12, 2021, 12:37:10 pm
Very nice!!!  :bravo1:
Post by: Bash on July 28, 2021, 09:16:50 am
Thanks.
I added an additional layer of speaker cloth on the inside (that flimsy black Hifi type of stuff) so the speaker is less see-through.
Also finished the foot switch with three options:
-On / off
-Slow / Fast (speed set by the knob on the back)
-Momentary switch that always ramps up to maximum speed, no matter how the other switches are set.
Here you can see it on top of the DualTone (the other foot switch is for its tremolo and tap-tempo for my delay pedals).
