Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: wsscott on February 06, 2021, 10:01:50 am
Title: 1965 Gretsch/Valco 6165 noise
Post by: wsscott on February 06, 2021, 10:01:50 am
I've had this amp since 1965 and its not had a lot of use over the years.  Anyway, it has some noise now that's noticeable on Channel 1. I tested by turning the Volume on Channel 2 all the way Off.  Then when I adjust the Volume pot on Channel 1, the noise intensity changes, but there's no impact with adjustment to Treble or Bass pots on that channel.  If I turn the volume on Channel 1 all the way off, then there's some background noise remaining which I would expect.  So with Volume on Ch. 1 off, if I then increase the Volume on Channel 2 there's very little change.  Pretty quiet.  So it seems to be associated just with Channel 1.  I'm attaching the schematics for the Pre-amp section and the PS section.
My question is what should I check out to see if I can locate the source?  I assume its in the pre-amp section prior to the volume control?  Its never been worked on except to replace 1 filter cap several years ago.  Everything else is original except for a 3 prong cord I have installed.
Also, does this circuit have the "death capacitor" that I should remove?  It doesn't look like its an issue here since the 3 amp fuse is before the caps and the rest of the circuit. Am I correct?
Thanks as always.
Title: Re: 1965 Gretsch/Valco 6165 noise
Post by: shooter on February 06, 2021, 10:14:35 am
Identify the kinda noise
sssssssssssssssshhhhk
fizzzzzzzzzzk
sizzchk
huuuuummmmmmm
use your tools, clean sin wave, prob the signal path
pull preamp tubes one at a time starting at V1 (1st tube), stop at PI (phase invertor)
Post by: wsscott on February 06, 2021, 12:46:27 pm
Shooter-Attached is a recording of the sound--(Well the forum wouldn't let me upload a m4a file that I recorded in Windows 10).  Anyway its like a ssssssshhhhhh sound along with a hum.
Post by: shooter on February 06, 2021, 02:41:46 pm
the ssshhhh noise it typically carbon plate resistors
the hum, tube, 120hz ac on DC, old leaky caps.
the ssssshhhhh sound should show itself as spiky, noisy stuff riding on a clean sinewave
the hum should show itself as a slow rolling sinewave superimposed on a clean sinewave
Post by: Williamblake on February 06, 2021, 02:54:03 pm
I have a tube that generates oretty stiff schsch.
Post by: wsscott on February 06, 2021, 03:07:53 pm
Shooter, thanks for your leads.  What are your thoughts about the "death capacitor" question?  Thanks.
Post by: shooter on February 06, 2021, 04:28:01 pm
typically they are on the AC primary side, I didn't see one there.  since you've owned this amp long time now, and we're still communicating.... :icon_biggrin:
Post by: sluckey on February 06, 2021, 04:50:31 pm
Look on the preamp schematic. There are two caps, one across the line, the other from line to ground. My fix would be a three wire power cord and replace those two caps. Use one class X and one class Y.
Otherwise, just snip both the caps and use a three wire power cord.
Post by: wsscott on February 07, 2021, 09:18:50 am
Thanks.  I changed it over to a 3 prong plug several years ago, but didn't do anything with the caps.  So I may just leave it as is for now, or put in the X and Y safety caps at some point.  Are those two .02 caps there for noise filtering purposes or something else?  Are they tying into a neon power light bulb?
Post by: sluckey on February 07, 2021, 10:18:38 am
Caps act as a line filter. They have nothing to do with the neon indicator lamp.
Post by: wsscott on February 08, 2021, 04:40:59 pm
I was looking at the schematics on this amp that I uploaded, and the B+ to Channels 1 & 2 comes off the end of the filter caps, and then splits and goes to the 2 channels.  Am I correct about that?  Since the noise is very low on Channel 2 even when it's volume is turned all the way up and Channel 1's volume is off, but on the other hand is very noticeable on Channel 1 and intensifies as its volume is increased with the volume of Channel 2 off, this leads me to believe that its not in the Filter caps or the 6L6's.  It also is not affected by adjustments to the Reverb or Tremolo--no effect in noise with intensity, speed, or on/off.  So it seems I can eliminate those 2 circuits also.  Since both Channels also tie into the PI section of the circuit, and only Channel 1 exhibits the noise, that would eliminate that part of the circuit.  This leads me to focus on the Channel 1 pre-amp section.  So does this make sense?  If so, then that's where I'll start exploring issues of resistors, tubes, etc.   Thoughts?
Post by: shooter on February 08, 2021, 05:03:03 pm
makes sense, an easy start though, identify the hum frequency, 60hz = filaments, nearby power noise.  120hz = unfiltered/poorly filtered DC power, so PS filter caps, possibly bias caps, cathode caps.
Post by: wsscott on February 09, 2021, 02:16:36 pm
Okay, so I checked the pre-amp tubes today.  I took each one out to see if the noise stopped or changed.  When I removed the 12AX7 for V-4 the noise cleared up.  When I put it back in, the noise returned.  I also pulled V-5, and when I did that no sound at all came through.  Am I correct that V-5 is the Phase Inverter part of the circuit, and it would make sense that there would be no sound if it is removed?
All the other tubes were fine.  One of the 6L6GC tubes has some microphonics.
So what does the V-4 tube do, and any thoughts on checking that part of the circuit?  Thanks.
Post by: wsscott on February 09, 2021, 03:25:30 pm
I forgot to mention that I replaced the 12AX7 in V-4 with another tube to see if it was the tube, but no luck.  Makes the noise even when a different tube is put in V-4.
Post by: wsscott on February 10, 2021, 03:19:23 pm
Sluckey/Shooter-I replaced the 2 prong plug with a 3 prong several years ago, and tied its green ground wire to the chassis via one of the screws on the transformer for the Reverb.  I was wondering if this circuit needs two (2) 100 ohm resistors installed somewhere to cut the hiss/noise?  Thoughts?
Post by: sluckey on February 10, 2021, 04:20:58 pm
No. Your PT heater winding already has a center tap.
Post by: wsscott on February 10, 2021, 04:50:01 pm
Yes, I should have looked at the schematic, I just didn't know if changing the plug so it had a separate ground would have an impact.
Post by: shooter on February 10, 2021, 04:59:07 pm
cut the hiss/noise? [/quote]
I would replace V4s plate R's with 1W metal film
clean n tension the pins
Post by: wsscott on February 14, 2021, 12:23:13 pm
Shooter--This is an unrelated question for a friend's 1977 Princeton Reverb.  He's had issues with it being slow to heat up and he checked the filament voltages on the 12ax7 tubes at pins 4 & 5 & 9, and each pin read 3.3 VAC.  I thought they had to read 6+VAC each.  Am I wrong?
Post by: wsscott on February 14, 2021, 12:27:26 pm
Sorry, I realized I was reading to GND and should have been reading between 4 & 9 and 5 & 9.  In that configuration they're reading 6.6.  So okay.
Post by: wsscott on February 26, 2021, 03:51:49 pm
I know this is going to sound pretty dumb, but I'll ask anyway.  I was going to check the bias on my Gretsch amp and wanted to know if I have to have the 6L6's installed when measuring the plate to cathode voltage?  The power supply of this amp is on a separate chassis that is bolted to the bottom of the cabinet, and I would have to take it off if I have to measure the voltage from the pin side of the tube sockets.  If I don't have to have the tubes installed, then I could just put the probes into the 3 and 8 sockets from the top.
Post by: shooter on February 26, 2021, 04:46:22 pm
won't work,....... sorta
current need's to flow, current is "set" by the tube + cathode R + OT
voltage is based on that current, using a meter as a tube "substitute" (by setting it to read amps) really isn't valid at this "level"
you can just measure plate VDC at the PS tap and call it good. If you do pull it to measure, grab the screen and cathode VDC also
Post by: wsscott on February 27, 2021, 07:59:36 am
Shooter, thanks-I went ahead and pulled the PS chassis and did the readings on both 6L6GC's, and then used Rob Robinette's Tube Bias calculator program.  Attached are the results.  How do they look to you?
The cathode resistor is shared by both tubes and it's actual reading is 198.1 ohms vs. 200.
The Plate Currents are 69.6 ma and 67.1 ma.
The Screen voltages are 396 and 395 VDC.
The Cathode Voltage Drop is 28.47 VDC.
The Plate to Cathode Voltages are 372 and 371 VDC.
Thoughts?
Post by: shooter on February 27, 2021, 08:31:30 am
you didn't complete the problem  :icon_biggrin:
372vdc X .0696A = 26W/tube
i believe that's within reason for a 6L6, although it might be close.   :dontknow:
Post by: wsscott on February 27, 2021, 08:40:34 am
I thought the 6L6GC was a 30 watt tube.
Post by: wsscott on February 27, 2021, 08:50:18 am
Sorry, I guess the calculator would want it to be around 80-81 and I guess its around 83?  I could put in a new cathode resistor.  Maybe 220?  Or just leave it be?
Post by: sluckey on February 27, 2021, 09:08:02 am
The majority of cathode biased push/pull 6L6 amps ever made use a shared 250Ω cathode resistor.
Post by: wsscott on February 27, 2021, 09:15:22 am
I guess given the age of this amp, ie. 1965, the 200 ohm 7W resistor would have done it. So I guess with current line voltage around 120 that's the difference.
Post by: shooter on February 27, 2021, 09:50:53 am
my brain is competing with pain so;
Assuming the calculator took care of "common" cathode R :dontknow:
if so;
i'd let it ride, tweaking Rk does work, but it comes with "tonal consequences"
Post by: wsscott on March 13, 2021, 09:17:08 am
I put in a NOS 6L6 about 2 weeks ago to replace the original one that had gone microphonic and was noisy.  The new tube seems fine and has much better plate current reading than the old one that was replaced.  In any event, the amp seems to pop and snap now a couple of times during an hour for a second or two, and then everything is fine after it stops popping, until it does it again. I'm not saying it only happens during the first hour of playing, but that's about how long I'm running the amp when I turn it off.  It occasionally did that before I replaced the tube, but now it does it each time I run it up.  It doesn't do it until its been running 20-30 minutes.  The old tube that remained does seem to glow brighter than the replacement.  Its not that big a deal for me, but a friend uses it sometimes to record and obviously that's a big issue if in the middle of a recording you hear this loud pop/snap.  Suggestions?  Thanks.
Post by: shooter on March 13, 2021, 10:21:28 am
loud pop/snap.
typical is something went momentary open, or something arc'd
so bad solder joint, dirty/sloppy socket.
quality time powered down on the bench with bright lights hunting, or powered on, signal playing and chop-sticking, taping, wiggling.
Post by: wsscott on March 13, 2021, 11:22:57 am
Thanks Shooter for the lead.  I'll see what I can find given the direction you've suggested.
Post by: wsscott on November 07, 2025, 10:32:18 am
Still having these symptoms after all these years.
I just wanted to ask a question referenced in my post #12:  What does the V4 Tube that immediately precedes the V5 Phase Inverter tube do in this circuit?
Don't want to be "poking a sleeping bear"!  Thanks.
Post by: SEL49 on November 07, 2025, 11:17:44 am
V4 mixes channel 1 preamp with channel 2 preamp.
Post by: wsscott on November 07, 2025, 11:40:30 am
So that mixes the #2 Bass Channel with the #1 Standard/Effects Channel to create the "Dual Input Jack" in Channel 1?
I notice that the lead connecting on V4, at Pin 7, Grid, goes to another 500K potentiometer, that has no label.  That pot is not on the control panel of the amp.  I haven't looked inside the chassis recently, but might that pot be found inside and wired into the circuit?  If so, how would it be controlled and what would the setting for the pot be?
Post by: SEL49 on November 07, 2025, 02:34:59 pm
NO. V4 mixes the outputs of Channel 1 and Channel 2 preamps together and sends the combined channel signals to V5 phase inverter.
That pot is used to match the volume of Channel 1 to the volume of Channel 2. Just set it and forget it. In fact, it's probably already set so just forget it.
I've attached a marked up schematic that should demystify this circuit for you. One odd thing I noticed... The Reverb Int pot actually adjusts the dry signal rather than the wet signal. Valco had some weird thinking engineers!  :icon_biggrin:
Post by: shooter on November 07, 2025, 03:09:52 pm
 :laugh:  they got fired from Gibson for smoke'n in the boys room
Post by: wsscott on November 07, 2025, 04:02:03 pm
Thanks for your help and explanation.  Best.
Post by: Platefire on November 08, 2025, 07:32:34 pm
I bought a new Gretsch 6164 Variety in 1965 for $350. That was a step up from my ST 1482. Instead of an Accordion channel, mine had a bass and lead channel. So I played bass sometimes and lead others, so that worked out well. The plain Variety didn't have reverb, only tremolo. You had to get the Variety plus to get reverb. I wish I had held on to mine as you did.
Post by: wsscott on November 09, 2025, 08:14:24 am
Yes, the 6165 has a Lead Channel and a Bass Channel.  The Lead channel, #1, has the tremolo and reverb.  It has 2 inputs, one of which is Normal and the other is Dual mixing it with the Bass Channel, #2.  I've normally used the Dual Input.
Post by: wsscott on November 09, 2025, 09:53:35 am
I took a look inside the chassis this morning to see where that 500K pot that's shown on the schematic in the Reverb circuit is located, and I found it!  It's strapped onto the back of the Channel 1 Volume Pot, so as the Volume for that channel is changed, so is the value for the other "hidden" pot. So that is a "double pot".   It's wired in the circuit just like the schematic shows it connecting on V4 and V7 on their Pins 7, Grids.
Post by: Platefire on November 09, 2025, 05:05:22 pm
Boy! I took a look at the schematic to see what you was talking about, don't know if I was looking at the right pot or not. I'm so use to Fender styles schematics I find Gretsch Sch hard to follow. They were definitely marching to the beat of their own drum on circuit design and schematic style.
When I had my Gretsch 6164 I knew nothing about tube amp electronics. I just used it and it never broke down. Never pulled a tube or even looked at the circuit.After keeping it several years I ended up trading it in on my first fender amp.
The weird thing about it, several years later this country singer/guitar player contacted me to play bass for him when he was playing in my area. I told him I had a bass guitar but no bass amp. Well he said he had a amp I could play over, so I agreed. Guess what? when I showed up for the gig, the amp he had for me to play over was my old Gretsch 6164. How I recognized it was I had removed a couple of those chrome knobs and put them on my Jazzmaster and put some other knobs on the amp. I didn't think I would ever see that amp again. Attached is the only picture I have of it
Post by: HotBluePlates on November 11, 2025, 08:06:58 pm
Got a scope?
SEL49 already marked up the schematic so you know what's what in Channel 1.  "Divide and Conquer":  Cut Channel 1 in half, and poke the scope probe there first.
"Halfway between the Input Jack and Volume control" appears to the the 0.01µF coupling cap that's the output of the 2nd gain stage of V2.  Attach the probe after the cap, and listen for noise.  When the noise happens, do you see corresponding squiggles on the display?
  - If "No" the noise is happening after this point, and before the Volume control.  Divide this portion of the circuit in half, and probe after the 0.005µF coupling cap at the first stage of V3.  Check again for display-squiggle when the noise happens.
  - If Yes, you will still need to figure out which stage of V2 is making the noise.  Probe right after the coupling cap of the 1st gain stage of this channel and repeat.
Once you've isolated the gain stage making the noise, there are 2 or 3 main possibilities:
  1.  Noisy tube.  Hopefully you've already tried a tube-swap
  2.  Noisy resistor.  Could be a broken component lead, could be noise due to DC Volts across the resistor.  There is test gear to test the latter, but you could just swap with a new resistor (though you are hoping the new one is not noisy, and would have confirmed that with the test gear).  "DC Volts" tends to be more-volts = more-noise, so plate load resistors are the typical problem.  If that doesn't work, a cathode resistor could be the noise source since most of these are unbypassed (a bypass would tend to bypass the noise as well.
  3.  Noisy cap.  Unusual, unless a cap lead is broken, or the cap causes popping noises by leaking DC volts.
Post by: wsscott on November 12, 2025, 06:24:33 am
Thanks for the directions on probing.
I haven’t been able to get it to reproduce the noise for the last 4 days!  And I’ve just let it run for 4-5 hours each day and no noise.  I don’t know if just removing and reinstalling V1-V3 cleaned a dirty socket or not.
So I’ll keep your notes handy if it starts up again!
Post by: wsscott on March 22, 2026, 03:28:23 pm
Just an update.  I think I've got the crackling, popping fixed.  I wound up replacing the 270K carbon comp. plate resistor and its .02 coupling cap on V4 which connects to the PI 12AX7 on V5.  It's been running for several hours with no noise.
After I removed those original components, I checked their specs, and they're still showing OK, but since this was an intermittent problem with the noise, maybe the resistor or even the cap were in the failing process.
So fingers crossed at around 60 years of age she's living for another day!
Post by: wsscott on March 23, 2026, 07:57:56 am
This amp is interesting-something I just noticed yesterday, and confirmed it by looking at the schematic this morning.  It has 2 sets of filter caps, not just 1 like most other amps that I'm familiar with.  It has a set like most tube amps coming off the rectifier tube, but in the Gretsch, those caps just filter the DC voltage going to the Output Tubes and the Output Transformer.  In other amps, these would also filter the DC going to the various nodes in the circuit feeding the preamp tubes.  Then there’s a 2nd set of filter caps that takes the DC coming straight off the Rectifier tube, and before those initial filter caps, and that set filters the DC feeding the preamp tube nodes.  That seems to be to be a pretty unique, and more expensive, design than you’d see in any other amps.
