Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: pbman1953 on March 23, 2021, 04:29:14 pm
Title: How long should grid resistors last?
Post by: pbman1953 on March 23, 2021, 04:29:14 pm
In 2015 you all helped me convert , in a Traynor YBA-3 (not Super) , EL34's to 6550's. Ed always put a bug in my ear that if you hear noise like bacon frying , that could be bad grid resistors. Any opinions?
Also, when filters caps go, is the hum even with the volume off? What does it mean if you get hum when you increase the volume & gain controls?
Title: Re: How long should grid resistors last?
Post by: shooter on March 23, 2021, 04:43:19 pm
typical is bad solder joint, sloppy sockets
the problem is usually "left" (before) those pots
Post by: pbman1953 on March 23, 2021, 05:03:41 pm
This is upsetting if it's a cold solder. I purposely held each connection to the terminal and watched them solidify before letting go. Plus last year I installed all new Beldon sockets.
Post by: shooter on March 23, 2021, 05:50:40 pm
the frying bacan is pretty easy;
bench the amp, plug in a signal, and chop-stick, wiggle jiggle, thump, rotate knobs quick, and the gremlin can't resist showing itself
hum, Identify if it's 60 or 120hz 1st
60 is filaments, 120 is PS
Post by: pbman1953 on March 23, 2021, 05:52:07 pm
will do!
Post by: pbman1953 on March 23, 2021, 05:55:46 pm
Just from memory it's a 60 cycle. Sounds like a low bass tone
Post by: shooter on March 23, 2021, 06:27:02 pm
If so;
start at 1st tube, (V1) Pull, hum, if yes, next tube.  STOP before the PI.  That should eliminate stuff and point you to the right ballpark
Post by: pbman1953 on March 23, 2021, 06:35:24 pm
With V1 out, no noise
Post by: pbman1953 on March 23, 2021, 06:48:54 pm
I'm noticing a low level 120 hz hum too, all tubes in
Post by: shooter on March 23, 2021, 07:10:50 pm
roll a few tubes into V1, check heater wires at the socket
for the 120hz, parallel an E-cap (~~~47uf 450vdc) with each "tap" Ecap, walk it down the line, so PA, PI, Pre
CAUTION, shock hazard, caps stay charged so make sure you bleed 'em down
Post by: pbman1953 on March 23, 2021, 07:34:22 pm
This morning I listened closer to the 120 and it's only slightly noticeable with the volume and gain at zero. I think we could move on and hone in on the hum.
I installed a couple more tubes with the same result. The hum goes up and down with the volume
Post by: pbman1953 on March 24, 2021, 07:20:52 am
I measured the heater wires. They start out at 6.32 volts at the standby and at V1 it's reading 6.02. The line starts at V7 and V1 is last in line.
Is the drop  a concern?
Post by: shooter on March 24, 2021, 09:32:21 am
are all the filaments glowing in both standby and operate?
Still the same?
if so;
look there, all the wires, the solder connections, the tube socket pins, components, ground connections, input jack, shielded cables......
post a schematic so everyone's on the same page
Post by: tubeswell on March 24, 2021, 09:33:58 am
Check all solder joints around V1 carefully (closely) for cracks or improper contact. Sometimes a joint can look soldered but if you grab the wire with needle nose pliers (with the power off) and wriggle it, and it moves, hey presto!
Or maybe a loose tube socket pin clamp on V1 (retension clamp - with power off).
Or could be a dogdy plate resistor on V1 (chopstick these)
Post by: pbman1953 on March 24, 2021, 10:16:52 am
All tubes light up.
Post by: proaudioguy on March 26, 2021, 10:33:29 pm
I have a similar issue on a DRii.  V5 is humming on the plate side, but if I probe the actual positive of the capacitor feeding that (and other) tube, its clean and quiet.  I grounded the grid and it made no difference.  I disconnected the NFB and it got a little louder as well as the noise.  Humdinger is set for minimum hum.  Pulling V1-V4 makes no difference.  Pull V5 and the amp gos silent, so the PI itself is clean and quiet.  Tube rolling has had no impact.  So I’m looking forward to your solution although its probably something different since yours happens before the volume and that triode is really high gain.
Post by: pbman1953 on March 27, 2021, 06:36:18 am
Sorry to sound ignorant, for tube rolling. Do you mean swap out different tubes :w2: :l2:
Post by: HotBluePlates on March 27, 2021, 08:18:04 am
... if you hear noise like bacon frying , that could be bad grid resistors. Any opinions? ...
Maybe you moved on from resistors, but any of them could be bad/noisy.  It helps if you use a signal tracer or scope to find the location of spurious noises.
Below is a demo of the Noise Test found on some old signal tracers (generally best done on parts not in-circuit).  Apparently when voltage is applied to resistors, some will really act up.  There is a complete amplifier after the resistor being tested.  Skip to 1:45:12 in the video; the bookmarked time is not rendering when posting a video here.
=6312
Post by: acheld on March 27, 2021, 09:23:16 am
PBMan, yes tube rolling is swapping various tubes into the circuit.
Post by: Willabe on March 27, 2021, 09:33:50 am
Are you sure he didn't say plate R , not grid R?
Plate R's are usually the culprit for going bad and making bacon frying noise, hiss/snap/crackle/pop sounds.
Post by: pbman1953 on March 27, 2021, 09:49:11 am
You have a point here. Maybe Ed would be watching this. Which pin is the plate?
EDIT... fixed quote, sluckey
Post by: sluckey on March 27, 2021, 10:50:25 am
Which tube? The answer you seek can easily be found here...
     http://tdsl.duncanamps.com/tubesearch.php
Post by: shooter on March 27, 2021, 11:03:13 am
Post by: PRR on March 27, 2021, 03:15:57 pm
The code is not handling the time parameter sensibly. You can try to hide it:
click me for the movie! (https://youtu.be/uGXQc-zanWg?t=6310)
(I shifted back to 1:45:10 to allow for opening a new window and getting the eyes in gear.)
Post by: pbman1953 on March 27, 2021, 03:39:38 pm
     http://tdsl.duncanamps.com/tubesearch.php (http://tdsl.duncanamps.com/tubesearch.php)
Great resource! thanks!
So is Willabe referring to the preamp tube plates? Because the power tubes don't have a resistor connected to them. Each side of the power tubes #3 is connected to the OT.
Post by: HotBluePlates on March 27, 2021, 03:57:04 pm
So is Willabe referring to the preamp tube plates? ...
Ed was probably talking about a plate resistor.  It has upwards of 100v or more dropped across it, which happens to also align with the ~100v placed across the resistor for the signal tracer's Noise Test.
The implication is that while grid reference resistors have higher resistance & might be noisier due to one cause, they generally have little or no d.c. volts across them.  Probably why there's the general suggestion of "replace plate resistors" when encountering noise.
    NOTE: a member here wound up finding his cathode resistor was noisy, when the noise remained after swapping the plate load resistor.
Post by: shooter on March 27, 2021, 03:58:15 pm
How did you get to the power amp tubes since V1 stops the noise????
were there bad solder joints, loose socket pins, swap the plate R with a new one, 10 minutes
Post by: pbman1953 on March 27, 2021, 04:04:27 pm
Ok, I'll retract the power section of my reply. The sockets are new. The original socket were old and loose. Months ago I spent time replacing all of the sockets. The worst ones were the power tubes. I used 7 new Beldon sockets. Everything is nice and tight!
Yes, I will replace both plate resistors.
Post by: pbman1953 on March 27, 2021, 04:32:23 pm
I replaced both resistors for pins 1 & 6 on V1. Seems a little better. The I made more tests. I removed v2 and it was the same result zero noise. I removed v3 and with this removal I heard the crackle in full bloom.
This must be the PI, so is that common if PI is removed?
Post by: pbman1953 on March 27, 2021, 04:42:26 pm
Here's a side question about heater wire connection. I've noticed on the schematic that one wire connects all the pin 2's and & 9's . the other wire feeds the 7's and the 4/5's. If they cross, does it matter? Meaning if the leave  a pin 2 and goes to the next tube's 7.
Post by: HotBluePlates on March 27, 2021, 04:50:31 pm
... I removed v2 ... zero noise. ...
Which seems like the noise must be at/before V2, right?
... I removed v3 ... I heard the crackle in full bloom. ...
Remove the tube and the noise is there.  Seems like it must be plate resistors for V3 or something after the phase inverter, where there is still a continuous circuit all the way to the speaker.
If I understand your tests/results, you have multiple noise sources.
Simplify:
Remove the phase inverter (V3) and make sure the amp is quiet.  If it isn't, find/fix the reason it makes noise.
Reinstall V3 but remove V2.  Find/fix any noise problems (which must be between V2B's plate & V3).
Reinstall V2 but remove V1.  Find/fix any noise problems, which could be anywhere from Input jack to V2B's grid (as stuff attached to V2A up to V2B grid couldn't be evaluated with the tube out of the socket).
... heater wire connection. ... If they cross, does it matter? ...
IMO, no.
Some people will tell you yes, but when I've tried to swap/fix-swap in heater wires I never heard a difference.
Post by: pbman1953 on March 27, 2021, 04:56:59 pm
I have to cap to understand the fixes-
V1 removed- no noise
V2 removed- no noise
V3 removed- plenty of noise- Are you saying to replace r23 & r22?
Post by: pbman1953 on March 27, 2021, 05:07:53 pm
Plus I just found a mistake . When I went through the amp years ago, in the r22 position, I used a 82k instead of 52K. Is that an issue?  The 5 on the print out was weird so I just enlarged it to compare another 8 on the schematic and it's really a 5.
Post by: HotBluePlates on March 27, 2021, 05:09:36 pm
When V1 is out of the amp, V2 and V3 are still in the amp?  And able to pass sound to the output tubes?
I'm not understanding a fault mechanism where "all the tubes in the amp" = "no noise" but removing only V3 causes noise to appear.
Post by: pbman1953 on March 27, 2021, 05:12:36 pm
yes,
with v1 removed all other tubes are still in- no noise
with v2 removed, v1 and v2 are in- no noise
with v3 removed v1  & v2 are still in- noise
Post by: shooter on March 27, 2021, 05:19:25 pm
maybe we go back to OP  :dontknow:
you have noise, it changes with volume
with V1 out the noise goes away;  "no noise"
NOW;
after changes you made;
with V1 in...  Do you still have the original noise?
Post by: pbman1953 on March 27, 2021, 05:22:46 pm
after the v1 the plate resistor replacements (for pins 1 & 6) , it seems to be a bit quieter with v1 in, and all other tubes in
Post by: HotBluePlates on March 27, 2021, 05:25:11 pm
And if you have all tubes in then remove only V2, there's no noise?
Post by: pbman1953 on March 27, 2021, 05:26:05 pm
And if you have all tubes in then remove only V2, there's no noise?   correct, no noise
Post by: pbman1953 on March 27, 2021, 05:49:25 pm
Does the phase inverter tube control the power tubes not to red plate? With v3 out they glow a bit , but I shut it down as soon as I saw that. I put the PI back in and they were better
Post by: shooter on March 27, 2021, 06:16:48 pm
see reply #6
EDIT:
Until you are happy with the noise V1 in creates, don't go downstream!
when you go down stream, do it 1 tube at a time
Post by: pbman1953 on March 27, 2021, 06:42:36 pm
You're right, up to v2 but not taking our v3, the hum is lower after replacing the plate resistors for v2. Should I replace the plate r's for v2?
Post by: PRR on March 27, 2021, 07:31:02 pm
This is clearly a 82k. 52k would be far too little gain. 3/4 of similar Fenders use 82k. You can do math and find an "exact" value to balance the stage, which is an odd value near 82k.
Post by: pbman1953 on March 27, 2021, 07:54:05 pm
You may be right but after finding clearer versions to look at, compared to other 8's on the page it looks like a 5. But an 82k is still in there, thanks for the heads up
Post by: thetragichero on March 27, 2021, 08:04:39 pm
i doubt you'll find a 52k resistor anywhere in most amps when 51k is a standard E24 series value
Post by: pbman1953 on March 28, 2021, 06:45:21 am
I took a close up of the schematic , do you think Traynor made a mistake on the schematic? You can see that it's a 5. Looking at r48 you can see the difference. Plus I took a picture of the 3A super which has the 82K. I think the 3 Custom schematic was wrong.
Post by: ac427v on March 28, 2021, 07:17:18 am
I was confused by symptoms that don't seem to match your troubleshooting steps. Then there is the mysterious 52k plate resistor on the pi. So I went back to look at the full schematic you posted near the beginning of the thread and now I am really confused. Clearly says 52k. PI grid leak resistors of 100k? 100k grid stopper on the pi input? 47 ohm plate resistors on two power tubes and none on the other two? Fed by 536 volts? The whole power section looks wonky to my no-formal-training brain. I hope some of the folks here who really understand theory weigh in the unusual aspects of the design and whether that may complicate your troubleshooting. I know it is way beyond me.
Post by: pbman1953 on March 28, 2021, 07:21:05 am
I think, because PRR, brought up the case that it should be a 82k. You can see from my last post that Traynor showed the 82K on YBA -3a super which is a close cousin but uses different tubes. Plus the 47's are now 1K's 5W per tube ( Sluckey's suggestion) so I could use 6550's
Post by: pbman1953 on March 28, 2021, 09:28:18 am
Well my friends I decided to bias to see where I was and a soar thumb stuck out, a bad JJ 6550. At first I thought there was a bad connection at the socket but I moved the suspect tube in 3 other locations and the issue followed it. By lightly tapping with a finger nail it exhibited noise, plus tapping the tube next to it exhibited noise though the bad one. Fortunately I had a Winged C 6550 , same dissipation of the JJ. I slipped that in and there's a slight crackling noise , which I suspect could be another JJ but all 4 remaining tubes are quiet to the tap.
The only item left is the hum which only comes up with increased gain or master volume. I've made many 12ax7 tube swaps with no change. But the v1 plate resistor replacements did help some. Maybe 10% or so
Post by: pbman1953 on March 29, 2021, 10:08:59 am
Any other ideas to help this hum?
Post by: sluckey on March 29, 2021, 01:47:19 pm
Filter cap for the node that feeds V1.
Post by: pbman1953 on March 29, 2021, 03:02:10 pm
The cap in that position now is 100 uf/ 500v. Should I change it to a lower value closer to the requested 10/ 400v?
I have a 16/ 475v and an 80/ 500v
Post by: pbman1953 on March 29, 2021, 05:46:14 pm
Anyone?
Post by: shooter on March 30, 2021, 10:00:20 am
If you have limited experience in troubleshooting amps, or don't have the equipment, find a competent tech in your area, maybe offer a few bucks extra to "sit-in" and learn directly.
you've been all over the board for your stated problem that goes away when V1 is pulled.  If you want to do it yourself, replace every component associated with V1(shot-gunning) then re-evaluate
Post by: pbman1953 on March 30, 2021, 01:15:33 pm
I will check the V1 with more attention.
As I discussed with Shooter, It seems that I've installed too many filter caps in this amp. I going back to his suggestion of 100, 100,47, 47 for the 4 stages.
Here are my questions-
1- for the 2 100uf's- should I use a 220k resistor
2- Should I rebias after all is back together?
Post by: shooter on March 30, 2021, 02:06:16 pm
NOT, what I said or suggested
Post by: pbman1953 on March 30, 2021, 02:18:50 pm
Now I'm confused because before I had 225uf/770v x 2, then 100uf/ 500v, 16uf/475v
Post by: pbman1953 on March 30, 2021, 02:40:12 pm
I have to say with the 100 100 50 50 , I didn't have 47's, it's much quieter.
Post by: proaudioguy on March 30, 2021, 09:58:53 pm
What did you swap the V1 plate resisters to?  What did you put in place of the originals?  Metal film?  Double the power rating?
Post by: pbman1953 on March 31, 2021, 06:39:20 am
All metal film closest to the originals.  Ed, from the forum , gave me a few changes value wise around the v1 (b) area
Post by: shooter on March 31, 2021, 07:38:49 am
100 at 500 volts is under what I see the transformer putting out at 550.
LOOK at the schematic, the designer put 2 cap rated at 450 in series, that = 1/2 the total cap value (50uF)of the 2,  AND twice the VDC (900vdc)
Post by: pbman1953 on March 31, 2021, 07:41:24 am
You're right, good point.
Post by: pbman1953 on March 31, 2021, 10:38:29 am
So I put back the first  2 stages
550/385v and 550/385v in series for the 1st and 2nd stage
Sadly with the 100 /500v most of the hum was gone. With the big caps some hum returned
Post by: pbman1953 on April 01, 2021, 10:21:54 am
Since I'm working in the v1 area, I want to report the changes I made years ago. The changes suggested were to  resemble I think a Bassman preamp. I may be wrong on the brand but it's supposed to mirror another well known preamp.
Going left to right on the schematic-
r3- 1 meg
r4- 1 k
r12- 82k
c2- .01
c1- 220/50v
r43- 8.2k
second r4-off pin 7 of v1- 1.5k
c34- 16/475v
c9- 220/35v
r13- 15k
r15-130 ohm
r17 &r18- 220k
r24 & r25- 100k
r26, r27,r51 & r52- 4.6k
Is there anyone that wants to take a stab at this? :w2:
Post by: pbman1953 on April 02, 2021, 02:45:28 pm
no help for me?
Post by: sluckey on April 02, 2021, 03:10:56 pm
Put everything back to stock. Traynor is a good amp.
Post by: pbman1953 on April 02, 2021, 03:15:16 pm
Will do thanks!
Before I do a couple new things. There a pot control off the back panel as a mid range type control. I never really liked it so I removed it. The hum is gone!
But there's still some crackle. I think it's from one of the JJ's. Is there a test sequence to eliminate power tubes for issues?
Post by: PRR on April 02, 2021, 03:51:17 pm
> no help for me?
We can't see your amp from here. Who knew it had "changes"? Or a "mid type" pot? In back??
You know this amp better than anybody. I have to agree "Put it stock!!" And do GOOD work, work that Pete would be pleased to sell. Examine EVERYTHING for looseness and tarnish.
Post by: pbman1953 on April 03, 2021, 03:34:22 pm
Well I put everything back to stock and I have no sound. The power tubes are working because I can  hear them as I tap the chassis.
I went over things many times and I know it has to be something simple.
Can someone send me a check list what to check for first. I can say that the voltages at each point are correct. I swapped out all 3 preamp tubes too.
Post by: Gregwor on April 03, 2021, 04:15:05 pm
Use the half split rule. Input 1kHz. Use your scope to check for signal half way through the amp (between the preamp and power amp). If there is no signal there, scope half way through the preamp. Keep doing this procedure until you pinpoint where the signal stops. From there, check connections, component and voltage values. With that knowledge you can hopefully find the faulty connection or component(s)  :thumbsup:
Greg
Post by: shooter on April 03, 2021, 04:24:57 pm
9 outta 10 it's always the last thing you did.
verify values, a 46ohm isn't good if it should be 460k ohm
Post by: pbman1953 on April 03, 2021, 05:01:46 pm
You all make me think, I needed a voice of reason. But I'm an idiot. I had R3 off the input with a 41 ohm instead of a 470 k. Busted!
Need a suggestion because I don't have the value for c 21. for the bass expander. Plus conversion makes my head spin because I'm not used to it
All I have is  for small stuff is a .0018uf (measuring 1900pf)  and it's calling for a .02 pf.
Post by: sluckey on April 03, 2021, 05:31:23 pm
Somebody is messing with you. Ain't no such thing as a .02pf cap in the guitar world. If you look at all the other "PF" caps you'll notice they used capital letters for all... except this one. It's a mistake. Should be .02µF. Look at this schematic...
     https://el34world.com/charts/Schematics/files/Traynor/Traynor_customspecial_yba3a_manual.pdf
Post by: pbman1953 on April 03, 2021, 07:00:35 pm
     https://el34world.com/charts/Schematics/files/Traynor/Traynor_customspecial_yba3a_manual.pdf (https://el34world.com/charts/Schematics/files/Traynor/Traynor_customspecial_yba3a_manual.pdf)
You gave a good point. If you look at the schematic of the YBA 3 Super, which is the same design, but more power. That part is marked as. O2 with no letters after meaning it was microfarads after all.
Post by: pbman1953 on April 04, 2021, 08:46:56 am
Update- All's working but at one point I lost gain. The snap crackle pop is gone due to another bad JJ 6550. I'm using my back up set of EH el34's until I get new tubes. I'm thinking of going for another, used in the past tube, Tungsol 6550.
As far as the gain, that's back by comparing the YBA-3 Custom Special to the YBA-3A Custom Super. The 3 came out first and it seems that there were mistakes on the schematic. When I compared the 3 Custom's preamp to the Super's , which are the same, I saw slight differences in values. For the 3 Custom the r45 the value is 82k for the Super it's 4.7k, hence my gain returned with all the power.
Now I'm listening to this amp like when I bought it. This amp and the Super came out before the SVT. If you dig into some of the history, some say that Ampeg modeled the SVT sound after these amps. Which mean they are on the gutsy side. So I have one last question because the changes I came away from made this amp half way between that gutsy sound and a warmer amp. If I wanted to go back in that direction which parts would need the most attention. Which resistor or cap would have to be tweaked?
Thanks again for all the help!
