Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: texwest on April 01, 2021, 04:58:23 pm
Hey guys, since Classictone went under I'm looking at different options.
I bought at Hammond deluxe reverb OT. Whenever they come in a just test them to make sure nothing is wrong. I can test from the blue to red and the brown to red and get about 200ohms on both, but if I measure from blue to brown I get an OL with a - sign. I tried this with the classictone and I can get the ohms from blue to brown. I also tried it with a heyboer and can measure from blue to brown.
Is this a problem? Should I send it back before I even try loading it into an amp?
Autoranging meter?
Yes it's auto ranging. It's funny that it works on the classictone which measures nearly the same. Around 200ohm for each push-pull side.
Haha showing my ignorance here. When I shifted to manual range it worked. I've never had to move my meter over to manual ranging before. If you care to enlighten me why it wouldn't work, I would be appreciative.
It’s due to the inductive kick back, when the meter switches range.
Thanks PDF! You respond to so many of these threads. I want to thank you for your extensive knowledge and sharing it.
Short the secondary to kill the inductance which is (as said) confusing the autorange.
I do think that 10 or 20 Henries is about the limit for these auto-meters, and the inductance at VERY low current (such as meter-test) is very different from working inductance at normal current, so it does not even hint at which iron may be "better".
