Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Diverted on May 01, 2021, 08:31:37 am
Title: Traynor YBA-1 open power rail resistor
Post by: Diverted on May 01, 2021, 08:31:37 am
Hi all, I was given a Traynor amp to look at that was DOA. Owner had bought it (history unknown) and played it for about an hour or two. Loved it ... then it went silent. Nothing.
Opened it up, checked transformers etc, no obvious issues with caps or resistors I could see. So I powered it up at about 60vdc just to put some juice through it. Discovered straight off that V1 had no plate voltage, but first few nodes did. So I started checking resistors in the B+ line and discovered the 10K (R29) between nodes C and D open. I replaced the resistor and the amp is playing.
My question is about finding the cause of the resistor opening. It showed scorch marks underneath after I pulled it, so it saw some excessive current. Am I right to assume that there is a fault downstream of that resistor causing the high current draw that fried the resistor?
The amp's all original, never been touched. Original filter caps etc etc etc.
Title: Re: Traynor YBA-1 open power rail resistor
Post by: acheld on May 01, 2021, 09:26:59 am
I'm not real familiar with Traynor as a manufacturer, but wouldn't it be possible that the resistor was underspec'd?
Post by: sluckey on May 01, 2021, 09:31:04 am
Most likely suspect is C15.
Post by: Diverted on May 01, 2021, 09:44:22 am
It looked to be a 1/2 or 1w resistor. Definitely small.
Post by: sluckey on May 01, 2021, 09:51:22 am
Some schematics show 1 watt and that should be fine for the small load. I would replace with a 10K/3W MO resistor.
    https://el34world.com/charts/Schematics/files/Traynor/Traynor_yba_1_yba_4_bass_master.pdf
Post by: tubeswell on May 01, 2021, 09:54:11 am
^what Steve said in Reply#2^
(a shorted C15 will make the whole B+ drop across the supply resistor causing excessive smokiness)
Post by: 2deaf on May 01, 2021, 11:05:14 am
Can you post the whole schematic?
Post by: Diverted on May 01, 2021, 12:19:10 pm
Sure, here's the full schematic. Not the best resolution but good enough.
Post by: thetragichero on May 01, 2021, 12:20:53 pm
there were a few variations on the same theme, but you should get the general idea: https://www.thetubestore.com/lib/thetubestore/schematics/Traynor/Traynor-Bassmaster-YBA1-Schematic.pdf
look familiar? certainly not too complexi
Post by: 2deaf on May 01, 2021, 12:56:19 pm
Thank you for your prompt attention.
Can you post the rest of the schematic that you posted a piece of in your original post?  Also, I would love to see some gut shots of this amp.  I've never seen that particular variation in the flesh.
Post by: Diverted on May 01, 2021, 02:13:00 pm
Here you go 2deaf. Photo size limitations on this site so I posted high-res shots here. Click on them to enlarge.
https://imgur.com/a/tTh7HSM
Post by: dwinstonwood on May 01, 2021, 02:24:25 pm
A question: should those little tan rectifier diodes be replaced, too? I'm just curious whether diodes go bad over time.
Post by: sluckey on May 01, 2021, 02:35:17 pm
Those diodes should be fine. I've seen a lot of those in the military and FAA. Silicon diodes don't just fade from good to bad. It's like a switch... one moment they're good, next moment they're bad. No half-bad weak inbetweeners. Same goes for silicon transistors.
Post by: 2deaf on May 01, 2021, 03:29:08 pm
Here you go 2deaf.
Thank you very much.
Post by: 2deaf on May 02, 2021, 12:32:31 pm
I drew up a schematic looking at your pictures.  If you see any discrepancies, I would appreciate your pointing them out.
