Other Stuff => Cabinets-Speakers => Topic started by: sll on May 09, 2021, 07:54:10 pm
Does anyone know what the difference is between the Altec 418 and 418B 15" guitar speakers? Thanks in advance for any help you can provide.
maybe a start
Altec Lansing 418: Frame Variants & Cone Numbers (hostboard.com) (https://www.hostboard.com/forums/f700/270683-altec-lansing-418-frame-variants-cone-numbers.html)
google: Altec Lansing 418 specs & Altec Lansing 418b specs. There is more than one 418 model. See also:
http://alteclansingunofficial.nlenet.net/ especially Thiele-Small Parameters
http://www.lansingheritage.org/html/altec/catalogs/altec-cat.htm
Thanks but I still can't find any information regarding the plain 418 model, only later versions such as the 418B and 418-8H.
guessing the B came out when Altec found an improvement for the non- B :icon_biggrin:
Out of curiosity, since none of us can find a reference to the 418 model, what is the context of your question? Do you have a 418? Pictures would be nice.
Sure, I should have thought of that earlier. I thought that I was purchasing a 418B but received this 418 instead. I'm trying to figure out just what it Is that I have and if it is suitable for my application.
Contact Great Plains Audio. They bought out all the tooling, and records and should be able to tell you what you have based on the SN# if it hasn't been re-coned at some point.
https://greatplainsaudio.com/wp-content/uploads/2016/06/418-8H_lfspkr_spec_sheet.pdf
https://greatplainsaudio.com/wp-content/uploads/2016/06/418B_lfspkr_spec_sheet.pdf
