Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Sonny ReVerb on June 20, 2021, 10:20:34 am
Title: Lamington reverb tweaks
Post by: Sonny ReVerb on June 20, 2021, 10:20:34 am
So I built a version of the Lamington Reverb (https://valveheaven.com/wp-content/uploads/2016/10/The-Lamington-Reverb.bmp) into one of my amps. It is underwhelming overall. There is reverb present, but the levels of the send (dwell?) and return need to be 7-8 to hear it. I would like more. Maxing the levels doesn't add much and is a less pleasing sound.
Did my circuit changes lower the reverb level somehow? The bypass caps C15 and C19 are not installed yet. Install one or both? Any idea what signal levels I should look for by scope at the various tube outputs?
Any help is greatly appreciated.
Title: Re: Lamington reverb tweaks
Post by: Bieworm on June 20, 2021, 11:22:43 am
Did you manage to get it Hum free? I never did... but it sounded awesome!!!
Post by: sluckey on June 20, 2021, 12:03:38 pm
Need to post a complete schematic. That reverb circuit should produce more verb than you need. But improper interface with your other circuitry may be killing the reverb.
Post by: Sonny ReVerb on June 20, 2021, 12:27:01 pm
No hum. The amp is nearly silent at idle.
Just plug my Lamington fragment into this schematic:
https://el34world.com/Forum/index.php?topic=23894.msg257236#msg257236
The Ampeg reverb variant also had somewhat weak reverb. Maybe there's a fix to get more reverb out of both of these amps!
Post by: sluckey on June 20, 2021, 12:36:52 pm
Your gain pot also controls the reverb send level. Is that intentional?
Post by: Sonny ReVerb on June 20, 2021, 12:51:50 pm
Yes, that's from the original design. A friend played the amp at a local blues bar. He ended up with the gain maxed and the master dialed back. I think he was looking for more drive, not more reverb. Sounded great, though.
Post by: sluckey on June 20, 2021, 01:27:12 pm
The 4EB2C1B tank you show only has a 600Ω input. The 4FB3D1B has an input of 1475Ω and would be better suited. Should give more reverb.
Why did you choose the 4EB2C1B?
Post by: Sonny ReVerb on June 20, 2021, 01:29:29 pm
The Lamington used an 8EB2C1B...
Post by: sluckey on June 20, 2021, 02:18:08 pm
Well, assuming your circuit is correctly wired IAW that schematic, I'd want to hear another tank in the same circuit.
     https://www.tubesandmore.com/products/reverb-tank-accutronics-4eb2c1b-medium-decay-2-spring
     https://www.tubesandmore.com/products/reverb-tank-mod-4fb3d1b-long-decay-2-spring
Post by: Sonny ReVerb on June 20, 2021, 02:28:11 pm
I have a 4FB3D1B on hand. I'll give it a try.
Post by: Latole on June 20, 2021, 02:53:32 pm
Wrong reverb tank could be a issue, impedances are different
Post by: Sonny ReVerb on June 20, 2021, 03:31:42 pm
The 4FB3D1B does sound much better. I know Ampeg used that tank for their tube driven circuit, but I was trying to stick close to the Lamington example.
Chalk up another success, Mr. Luckey!
Post by: Keppy on June 20, 2021, 03:36:02 pm
What's with the values of C18/20? Any signal that makes it through the 1n cap ought to pass right through the 10n to ground. I don't see how you're getting anything at all with that arrangement.
Post by: sluckey on June 20, 2021, 04:05:10 pm
Good question. That certainly did not come from the original Lamington.
Post by: Sonny ReVerb on June 20, 2021, 04:10:29 pm
No clue.
It comes from the Amplified Nation Wonderland (https://ampgarage.com/forum/viewtopic.php?t=29774), which is the basis for this amp. It does work.
Post by: sluckey on June 20, 2021, 04:19:32 pm
Humor us. Disconnect one end of the 10nF across the pot. What happens? I'm betting you'll get happy.   :icon_biggrin:
Post by: Sonny ReVerb on June 21, 2021, 07:35:57 am
I swapped the cap for a 1000pF. It has more reverb, but it's not night and day. The genesis for these amps is the John Mayer Sig. One clone shows a choice of caps from 470-2200pF, so 10,000pF might be a bit large.
Post by: sluckey on June 21, 2021, 08:16:49 am
Try it with ***NO CAP*** across the reverb pot.
