Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: markmalin on June 28, 2021, 02:10:12 pm
Hello, all!
This is kind of a funny question, but someone was asking me about a way to have individual power tube sections for a dual channel amp. So you'd have 2 preamps each with their own power amp, but into a single speaker output and have it switchable. I'm not sure this can work because you have a specific impedance requirement on an OT for a given set of power tubes into a given impedance for the speaker. But the idea would be:
[preamp 1] -> Phase Inverter 1 -> [Class A/B power amp section 1] -----\
-------> [single speaker load]
[preamp 2] -> Phase Inverter 2 -> [Class A/B power amp section 2]------/
In theory you could, as long you don't run both amps together but instead switch between them (and provide dummy load to the unused "channel". In practice, no.
It appears that you intend for only 1 power amp at a time to be connected to the speaker. Assuming the power amps are tube amps, the disconnected amp should be switched to a dummy load, at the same time that the other amp is switched to the speaker. I think some years ago PRR proposed a circuit based on an automotive hi/lo beam floor switch. There are more sophisticated A/B amp switches for this purpose; or it could be a DIY project.
For impedance matching: if a power amp does not match the speaker's impedance rating, a matching transformer could be used. Weber sells them.
sounds very inefficient partswise
