Other Stuff => Guitars => Topic started by: W1Jrv on August 25, 2021, 02:50:36 pm
Title: guitar wiring harness mini-terminal splice blocks
Post by: W1Jrv on August 25, 2021, 02:50:36 pm
i'm looking for some mini terminal blocks to act as splicers so i can minimize soldering when changing pickups. i have quite a few pickups accumluated over the years i want to start experimenting with and not interested in soldering with each swap.
you see the pre-wired kits, like mojotone and artys-custom-guitars, etc., that have the mini terminal blocks but they usually have some sort of circuit board attached with their designs.
i'ld like similar mini terminal blocks as splicers without circuit board that i could adhere to the control plate. whether screw in or clamp in would be ok.
i've done a lot of searches but they are either for mini pcb board, too large, etc. i have a SD liberator but it's a bit bulky for me.
anyone know of such a product(s)?
Title: Re: guitar wiring harness mini-terminal splice blocks
Post by: shooter on August 25, 2021, 04:09:50 pm
try this
25-B300-02 NTE Electronics, Inc | Connectors, Interconnects | DigiKey Marketplace (https://www.digikey.com/en/products/detail/nte-electronics-inc/25-B300-02/11653669)
Post by: Willabe on August 25, 2021, 05:19:18 pm
Look in the electric section in a big box store, Home Depote, Lows, etc. They sell reusable little clamp type splice gizzmos.
Post by: acheld on August 27, 2021, 10:39:24 am
Seymour Duncan "Liberators" pots may work for you.   I've used them in the past.   To tell the truth, once I get a setup I like on a guitar, I usually leave it alone nowadays.
Post by: Latole on August 28, 2021, 03:25:48 am
try this
Link do not work, the 25-B300-02 Is for a printed circuit ;
Post by: Latole on August 28, 2021, 03:29:43 am
For good job AND for a long time ; solder, solder and solder
What I use in many electronics projects ; easy to cut in piece and well insulated
Scroll down to the middle ;
https://www.nteinc.com/terminal_blocks/pdf/barrier.pdf
Order from Digikey or Mouser or.....
