Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: BOWMusic on September 16, 2021, 07:41:03 am
Finally I decided to use hybrid approach, turrets on PCB. It turns out well good, it's like a 3D surface mount for big components, don't need a service window or remove the board to repair and modify. Everything is on the top.can't wait to put some resistor sand caps on it.
(https://i.ibb.co/gJNDR7b/IMG-6899.png) (https://ibb.co/BBbgCPH)
(https://i.ibb.co/fSfvg3c/IMG-6900.png) (https://ibb.co/VNRm1FK)
Very cool. I always felt this was an underutilized approach. I've got a pcb for a more complex amp project on the bench right now that I wish had been designed like this. There are a few components on the power rail that there's a high chance that I'll have to swap out and tweak as I'm modifying the original design. Unfortunately, the holes present aren't the right size for turrets.
Makes changing components later a breeze and far less damage to the substrate and runs. I would be a little concerned with the swaged part of the turrets being a little close to the conductive runs.
