Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Bieworm on October 25, 2021, 02:19:41 pm
Title: 6G3 build: oscillation solved?
Post by: Bieworm on October 25, 2021, 02:19:41 pm
Hi fellas!
I have a question about oscillation.  When I dimed the tone or volume on the bright channel I got this loud buzz.  It was clearly oscillation of some instability problem. I tried a lot of chopsticking, changing ground points  ..
I finally got rid of it by bridging a 10pf cap across the plates of V2. It's totally gone. And this solved another strange problem.. I found this 20W 6G3 a lot less loud than my 18 watt amps and my cathode biased deluxe reverb. This made no sense.. even when I swapped the jensen P12Q for a Celestion Alnico Cream it still wasn't loud. Now it is!!!
Can I call this case closed or is the problem now masked, but still there?
Title: Re: 6G3 build: oscillation solved?
Post by: SILVERGUN on October 25, 2021, 02:30:58 pm
added schematic
Post by: Bieworm on October 25, 2021, 02:37:59 pm
added schematic
Sorry.. and thanks
Post by: shooter on October 25, 2021, 03:27:37 pm
if it's loud as expected then;
if you see no problem, hear no problem, measure no problem, there is no problem  :icon_biggrin:
Post by: Bieworm on October 25, 2021, 03:35:04 pm
I wonder if a grid stopper isn't the better solution...
Post by: pdf64 on October 25, 2021, 03:51:05 pm
… got rid of it by bridging a 10pf cap across the plates of V2. It's totally gone…
So V2 not V3?
If V2, do you mean 10pF between terminals 1&6?
Post by: Bieworm on October 25, 2021, 03:56:17 pm
So V2 not V3?
V2.. so across the plates of the 2nd preamp stage and the trem oscillator. Trem is stronger now too.
Should I rather be trying a grid stopper on V2A? That's the standard first step in troubleshooting oscillation when chopsticking changes nothing, no? 😃
Post by: pdf64 on October 25, 2021, 04:15:38 pm
Whatever works, works, I suppose  :icon_biggrin:
If you want to carry on tinkering, I suggest to move the 220k mixer resistors to the V2 socket terminal, with some heatshrink or tagstrip. Then they can properly act as grid stoppers.
Grid stoppers for the output valves seem a good idea too.
Photos of the build would be useful.
Post by: Bieworm on October 25, 2021, 11:39:47 pm
Forgot to take photos of recent changes.,but I'll have to open it up anyway, since I haven't checked voltages now the oscillation is over. Iran imagine they changed since the volume increased substantially.
BTW, I added 8k2 grid stoppers and 1k G3 resistors on the 6V6 tubes from the start.
Post by: pdf64 on October 26, 2021, 06:06:36 am
... I added 8k2 grid stoppers and 1k G3 resistors on the 6V6 tubes from the start.
1k g2 resistors  :icon_biggrin:
But bear in mind that g2 is a grid, has gain, and the resistors may act as grid stoppers as well as current limiters. So are better mounted at the valve socket terminal.
But looking at your build, with all that screened cable, oscillation seems to be well mitigated. So in the absence of scoping it for a verified diagnosis, who knows what's going on  :dontknow:
Post by: Bieworm on October 26, 2021, 07:53:54 am
Thx. I meant G2... typo😉
When I have the time I will put my Siglent on the bench and scope the circuit to find the oscillation
Post by: glass54 on October 26, 2021, 09:37:53 pm
Hi Bieworm,
In regards to your photo, that's really impressive, ie almost every lead/wire is dressed  :laugh:
I fuss a little (too much) but you must have had a bit of time on your hands (Covid??)
Seriously, that's impressive  :headbang:
Kind regards
Mirek
Post by: Bieworm on October 26, 2021, 11:00:05 pm
Hi Bieworm,
Kind regards
Mirek
Thanks?😉 I do my best to make it look good. Build time was ok.. 2 weeks of evenings and weekends,  including the cab build.
Post by: Tone Junkie on November 08, 2021, 09:57:05 pm
Dumb question but we’re did you get your unused socket whole covers from. Thanks Bill
Post by: Bieworm on November 09, 2021, 01:06:34 pm
Those are simple electricians supply grommets for (more or less) rain water resistant cable-throughs.
