Amp Stuff => EZ Board postings => Topic started by: Geezer on June 18, 2005, 05:44:45 am
> Deluxe w/ BF and tweed preamps advice needed
<< Prev Topic | Next Topic >>
Author Comment
bluesbear
Hey get your own solder
(3/27/04 4:05 pm)
Hi. I'm starting my next amp and need any advice that may be available.
This amp is going to have a 4-6V6, cathode bias power section; basically a double 5E3 Deluxe. I want to do 2 discrete preamps, a 5E3 and an AB763 (no reverb or trem) with relay switching. The only problem I see is how to handle the phase inverter situation. I guess it all breaks down to 2 questions:
1. Can I (or should I) put the relay after the phase inverter and before the master volume? If this is a bad idea, why? and....
2. If I should switch before the phase inverter, which should I use, the 5E3 or the AB763? Why?
Or, is the whole idea of the AB763 side stupid? I have a gutted Bandmaster chassis to put this in and I have plenty of extra spaces for pots and tubes. I'm just looking for more versitality but maybe this isn't the best way. Any opinions before I get started would be appreciated.
Dave
Tiny Daddy
I will work on all amps
(3/27/04 10:28 pm)
Re: Deluxe w/ BF and tweed preamps advice needed
I would put the relay before the phase inverter because it's simpler that way. And add some extra de-coupling and 1M bleeder resistors to be sure you are not switching signals that are riding on some DC voltage. That's the only way to avoid a POP when you switch.
And I would use the 763 phase inverter because that's what is used on the larger amps, no other reason.
Topic Commands
jump to: Tube Amp Building - Tweaks - Repairs (New)New Product Suggestions (New)Praises - Complaints - Suggestions (New)Buy - Sell- Trade (New)Archives (New)
Powered By ezboard® Ver. 7.32
