Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: fritz203 on March 20, 2022, 03:43:00 pm
I tried to search for this topic, but couldn't find anything relevant.
Is there a way to test a Fender output transformer but just measuring the input/output winding ohms(not impedance)?
Might this help?
https://youtu.be/WiH-l5wRGBA (https://youtu.be/WiH-l5wRGBA)
No.
Only if windings read open you'll know it is bad.
Why do you want to test it ? What's wrong with the amp ?
you'll want a good meter that can "zero" out probe errors since some of the readings will be in sub-ohms
Ok, thanks for all your help, that is what I was looking for.
Right DC resistors do not mean transformer will work / sound fine
I figured out the transformer is fine, that was just a part of the troubleshooting. I had a screen resistor burn out and that took out the output tubes, so I wanted to check the transformer also. It turns out I had the output tubes biased too hot. All is fixed now. Thanks.
Good news !
What is the amp we are talking about ?
Useful ?
A 'hard' fault on a push pull OT primary may be revealed by comparing the full primary resistance to the sum of the CT to anode resistances.
RG Keen has a transformer shorts tester.
(https://cdn.shopify.com/s/files/1/1091/4404/products/TransformersAutobotShortsfront.jpg)
Him ?
R.G. Keen
Cheif Engineer
Visual Sound
www.visualsound.net
Yes but no. His personal site Geofex. http://www.geofex.com/ http://www.geofex.com/ampdbug/outtrans.htm
Thank's
Ok, thanks again.
