Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: pbman1953 on March 29, 2022, 01:52:21 pm
I know some guitar players that like and use the Brown Box attenuator. But do any tube amp bass player use line regulators?
Is that something that should be considered?
line regulators?
Do you mean voltage regulators?
(And if so, where do you mean to use this? Schematic Please)
no, more of a wall unit for stable power
Skip to about 9:40 to hear how Angus uses one:
... a wall unit for stable power
Like everything else, the good ones are fabulously expensive.
You might be able to get by with a Kikusui that costs only $2500-3000, but the ones highlighted by AC/DC and Bonamassa are more like $5-7000.
Meanwhile, folks will praise their Furman line voltage "regulators." These things are basically a transformer with multiple discrete taps, about 5v apart. A sensing circuit detects the voltage being sent to the outlets and switches to a different ta if that voltage is too high/low.
That means voltage is allowed to rise/fall within a ~5v window, unchecked. Only when it goes beyond that does the unit switch to a different tap. In a worst-case, this means a 1v variation of wall voltage from 1/2v below a switching-point to 1/2v over will result in a -4.5v change in the outlet voltage.
See the saw-tooth shape of the "Regulation Range" on Page 2 of Furman's data sheet (http://resources.nortekcontrol.com/products/P-1800-AR/pdf_P-1800-AR_datasheet.pdf). At a price of $1500, buyers don't like it when you point out it can be worse than "no regulation at all" under the wrong circumstances.
