Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: TIMBO on May 04, 2022, 03:18:03 am
Title: 5F1 Motorboating
Post by: TIMBO on May 04, 2022, 03:18:03 am
Hey guys,
I've had some 5F1 PCBs made and having a problem with motor boating sound when the volume is maxed with no guitar plugged in.
Thought it might be the power valve plate wire needing to be reversed, no joy
Pulled the 12ax7 and the volumed maxed and no motorboating
So I narrowed it down to the 12ax7.
Replaced the 12ax7 with 12au7 and volumed could be maxed with no problem.
Replaced the 12ax7 and put a 100k grid stopper between the pot wiper and the grid of the second triode, worked great no motorboating.
Thinking the second triode was getting hammed so removed both 100k grid stopper and 25uf bypass cap on the first 12ax7 triode, this also worked great.
The PCBs followed the layout and schematic of Rob Robinetts 5F1 which has a 25uf bypass cap on the first triode
Fender schematics don't have this cap.
I know many have built Robs 5F1 with no problems
(https://i.imgur.com/coXdwcq.jpg)
Any thoughts...
Title: Re: 5F1 Motorboating
Post by: Latole on May 04, 2022, 03:41:13 am
Motorboating (amp sounds like a boat engine) is usually caused by a weak or damaged power supply filter cap.
 You can temporarily alligator-clip an extra filter cap in parallel with the caps, starting with the first filter cap. If the temporary cap fixes the problem then replace the original cap. Also verify the power supply voltage dropping resistor values.
https://robrobinette.com/Tube_Guitar_Amp_Troubleshooting.htm#Weird_Noises
Post by: tubeswell on May 04, 2022, 04:10:13 am
Usually the smoothing cap
Post by: sluckey on May 04, 2022, 04:18:47 am
Are  your switching jacks wired correctly?
Hoffman's 5E1/5F1 also shows a 22µF but he qualifies it with a note that says "5E1". The original 5E1 does have a 25µF bypass cap. I bet that if you just lower the value of that cap to something like 1-5µF that the motorboating would go away.
Personally, if I were building a 5F1 I would not use the bypass cap.
Post by: TIMBO on May 04, 2022, 02:43:17 pm
Thanks for the reply's
I'll check it out
