Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: bbmade on June 17, 2022, 12:00:50 pm
Hello - I've searched the forum for an answer here but...
I'm working on a 1970 Fender Twin Reverb and have replaced the bias cap and resistor. It has the original diodes.
My question is:
Do I want 1N4007 rated at 1000V 1A or would I be better off with the 1N5408 rated at 1000V 3A?
The 4007 diode is so much smaller than the originals but, I'm guessing it's because the technology is better now.
Any insights are welcome. Thank you
Here's the board:
Your choice. Either is a fine replacement. However, there's no reason to replace the originals unless you know one or more has failed. If your B+ is good then the original diodes are good too.
Thank you. Voltages are good amp sounds good but there's an oscillation when I crank the volume on the vibrato channel. I think I'll start another thread for that because the amp had mods done in 1972 and I thought they were the culprit but I'll explain what I can in a new thread.
