Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on August 29, 2022, 12:07:21 pm
Title: JMI Secrets - Circuit Borrowed from Hammond Vibrato ???
Post by: kagliostro on August 29, 2022, 12:07:21 pm
Does someone knows which is the Hammond circuit that was stolen ??
(https://i.imgur.com/NL7cuPA.jpg)
Title: Re: JMI Secrets - Circuit Borrowed from Hammond Vibrato ???
Post by: sluckey on August 29, 2022, 01:34:57 pm
That Vox vibrato circuit was copied from a Wurlitzer organ, not a Hammond organ. See
     http://sluckeyamps.com/misc/Dorf_TheWurlitzerVibrato.pdf
Post by: HotBluePlates on August 29, 2022, 03:05:18 pm
     http://sluckeyamps.com/misc/Dorf_TheWurlitzerVibrato.pdf (http://sluckeyamps.com/misc/Dorf_TheWurlitzerVibrato.pdf)
100%
Sluckey doesn't need me to second-guess his statements, but I agree this is an error in Elyea's otherwise outstanding book on JMI amps.  The circuit was lifted directly from Wurlitzer organs.
Post by: kagliostro on August 29, 2022, 03:58:48 pm
Many Thanks Friends
At the moment I'm not able to read the PDF because I'm on the phone and seems I must be on the PC to open the file
Thanks again
EDIT: Problemi solved, I can read the whole text
Post by: Willabe on August 29, 2022, 08:34:41 pm
I've read that Gibson got it from Wurlitzer and Vox took it from Gibson.
Post by: DummyLoad on August 29, 2022, 11:56:08 pm
IIRC, the early Hammond pitch shifting scheme was electromechanical, with a later scheme that was all electronic employing saturating core inductors.
Steve, wasn't your warbler project based on the saturating core inductor type?
--Pete
Post by: sluckey on August 30, 2022, 06:24:41 am
--Pete
Yes. And the earlier Hammonds did use a motor driven rotating scanner type vibrato.
Post by: kagliostro on August 30, 2022, 06:54:32 am
Something that rensambled a circular saw ?
Post by: sluckey on August 30, 2022, 07:22:14 am
Scanner looks like this...
     http://theatreorgans.com/hammond/faq/a-100/fig-28.jpg
Theory of operation. Scroll down near the end of page...
     http://theatreorgans.com/hammond/faq/a-100/a-100.html
Post by: kagliostro on August 30, 2022, 09:54:43 am
This is what I was remembering
(https://i.imgur.com/WpLpl8Z.gif)
(https://i.imgur.com/JaYcFap.jpg)
https://www.quora.com/What-exactly-is-making-the-sound-in-a-Hammond-organ-if-not-air-through-a-pipe-or-reed (https://www.quora.com/What-exactly-is-making-the-sound-in-a-Hammond-organ-if-not-air-through-a-pipe-or-reed)
Post by: sluckey on August 30, 2022, 10:22:50 am
That is the tone wheel. It generates the sine wave tone you hear when you press a key. For example, pressing the middle C key activates a switch that selects the proper tone for a C note. Quite different from the vibrato scanner. The vibrato circuit occurs farther down the signal path. When that C tone passes through the scanner circuit, the frequency is shifted a little bit below C and a little bit above C, producing the vibrato effect.
That's a very simplistic explanation and may not be totally accurate, but should give you an idea of what's going on.
Post by: kagliostro on August 30, 2022, 12:03:40 pm
Oh, I understand
Post by: HotBluePlates on August 31, 2022, 05:44:04 am
We may never be sure how something got swiped.
However, it's worth pointing out that before Dick Denney enters the scene that Tom Jennings is in business selling keyboards/organs.  We might guess Wurlitzer's vibrato was swiped directly on the basis of JMI's business-focus before the AC-amps enter the picture.
