Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Leevi on October 01, 2022, 06:59:59 am
Title: Gibson GA-8
Post by: Leevi on October 01, 2022, 06:59:59 am
I'm wondering the missing grid stopper from the first power tube. The second tube has 470R. Is there some idea or is it just a fault in the schematic?
Furthermore I thought to replace the 500R voltage drop resistor with a choke.
/Leevi
Title: Re: Gibson GA-8
Post by: shooter on October 01, 2022, 07:25:02 am
can't recall if there was an error, The couple I worked on matched up like the schematic though
as to the 500R vs choke;
If you ask most players that have used that amp, it has mojo, NOBODY ever wanted me to do anything but the minimum required to fix it, even then they were afraid i'd mess up the mojo  :icon_biggrin:
Post by: Latole on October 01, 2022, 07:25:32 am
Schematic is all wrong
Post by: shooter on October 01, 2022, 07:28:16 am
wrong version, that's the PP, NOT parallel single-ended
Post by: Latole on October 01, 2022, 08:03:16 am
There are many GA-8  :BangHead:
Post by: Latole on October 01, 2022, 08:07:35 am
Gibson and Epiphone owner manuals and schematics:
https://jt30.com/gibson/index.html
https://jt30.com/gibson/pg_0106.jpg
Post by: Leevi on October 01, 2022, 08:12:43 am
There are many GA-8
Yes there are. This model is 1959 GA-8 Gibsonette. The first GA-8 models are from late 40's. There are also models from early 60's
/Leevi
Post by: Leevi on October 01, 2022, 08:22:55 am
I tested it with a choke and the ground hum level is lower with it. Furthermore the choke drops the voltage less. 5Y3 is weak to keep the needed voltage and the tubes operate with low dissipation.
And I don't like hot resistors.
/Leevi
Post by: PRR on October 01, 2022, 05:45:34 pm
You sometimes have to isolate the two grids from each other. That does not always mean resistors everywhere.
I would not mess. It has the feel of try-and-see, that someone came to this plan after some testing (for minimal cost).
Why would you remove the choke? 10 Watts is not enough but 11 Watts is fully satisfying? Or your arms need the work-out? If you truly wanted More Power and Less Hum, you would do push-pull. The OT might even be cheaper, but the PI driver is a buck more.
Post by: Leevi on October 01, 2022, 10:28:24 pm
I ended up to replace the 500R with a choke, otherwise I kept the circuit as it was planned.The 5Y3 rectifier can be replaced either with GZ34 or SS-rectifier plug and no bias change is needed.The SS rectifier increases the B+ by 55V.
/Leevi
