Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Jalmeida on October 08, 2022, 02:40:51 pm
Hey guys! I don’t post here, but read here often. I recently built a Vox JMI period AC10 with scratch built chassis to fit into a trainwreck Cambridge reverb 30 amp cabinet that also uses it’s speakers.
I also incorporated a direct coupled single 12DW7 reverb circuit. I am admittedly have alot to learn about circuit design and have been getting some advise from a local tech who gave me some tips for the mixing resistor network. I built the circuit using smaller daughterboard using tagboard. I set it up to be able to be removed from the circuit using jumpers on a small TB. The reverb works, but when I integrate the circuit the normal channel volume drops by almost half.
Here is a poorly drawn diagram I put together showing where the new circuit interfaces with C11 of the normal channel.
Perhaps Swap the 40k and 180k resistors- putting 180k between the coupling cap and the tube seems like it would drop alot of current to the Phase inverter.
Perhaps go from the 40k/180k to 120k/100k. Or in 100k/120k order
Playing with these resistor values should be easy to experiment with as long as I make sure I have the total 220k in series to the V2A tube plate. I must admit I am also curious what playing with the 220k mixing resistor values may do also. Any thoughts?
More pics
And..
Bump
Why did you split the 220K plate load for V2A? You lost a tremendous amount of normal dry signal by doing so. I would use a 220K just like the original circuit and reevaluate.
It was advised by the guy helping me with integrating the circuit in the wet signal to have resistance between the where the circuit drive signal picks off and where it gets reintroduced. I have no experience designing amp stages. I have alot to learn. So forgive me.
So I put C11 coupling cap back at pin 1 of the tube and left the 40k and 180k in series seeing they are the same plate resistance value. Volume is back to where it was. But integrating my reverb back into the circuit does not drive the reverb circuit. Curious if it’s due to the impedence between V1 and the 12DW7? I also tried tying in the between the 40k and the 180k with a .0022 cap and no reverb. The only way I have been able to get the reverb to drive is wire per the diagram. But the normal channel is then too quiet.
Give a look to the VOX Cambridge schematic and see you can find inspiration
https://el34world.com/charts/Schematics/files/Vox/Vox_cambridge_reverb.pdf (https://el34world.com/charts/Schematics/files/Vox/Vox_cambridge_reverb.pdf)
In your schematic the reverb goes to the wrong side of the mixer. Maybe wrong is not the right word but i think it may be worth a try if you split the driver because reverb is to weak.
Try this...
Thanks for all the help, guys! So to get this straight….
Go back to standard dry signal resistor as factory plate resistor C11. Then integrate as shown above?
Integrate as shown above and revaluate. You haz reverb? Enough reverb? Reverb souds good?
I predict you will need one more triode.
Drive or recovery?
Recovery.
Meant to ask this earlier... Which tank are you using?
Recovery.
4FB3A1B
Recovery.
So your suggestion worked. I can get alot of reverb, but I also get a feedback squeeze the gradually grows to unbearable if the reverb level is above 5/10. Click off the reverb and it’s gone. So originally there was a 10k resistor between the reverb level pot and C6(.0022uf) coupling cap that was advised I remove. Curious if putting that 10k resistor may help the squeal? I am merely spitballing.
May be V1B has too much gain. Replace R8 with 100K. Any joy?
What is connected to the cathode of V1B?
22uf cap and 470R resistor.
Possible phase issue from the reverb circuit?
Too much gain.
Replace the 220K plate resistor with 100K.
Replace the 470Ω cathode resistor with 1.5K.
Too much gain.
Feedback squeal was fixed by that, but now what sounds like a 60hz hum is present in the reverb channel. Don’t have an O-scope at home. I rechecked and reflowed the solder to ensure no resistive solder joints. Odd. I’m trading problems. I am guessing that this was present before and changing other things brought it forward. Perhaps changing the 22uf cathode bypass caps for another value may be a good thing to try?
Worth double checking layout and grounding at this point?
True. Good point. I will say that it is odd that the hum started adter changing the gain on the 12DW7 revovery stage. Before I had no hum. Just a squeal when the reverb was turned above 50%. The hum goes away when the reverb level is all the way down or switched off. So I retraced all of the reverb circuits and reflowed the solder connections. No wire strands shorting. No change there.
Has me curious if I need to change my cathode caps to another value? 22uf is what they are currently. Perhaps they got damaged changing out the cathode resistor? I did probe both sides of the caps checking for voltages and all seemed normal. Perhaps a 1.5k cathode resistor paired with a 22uf cap isn’t filtering out frequencies as they were with the 470R cathode resistor?
OK, put the 220K and 470Ω back in and we'll try to lower the reverb signal another way.
Put that resistor back between C6 and the reverb pot, but rather than a 10K, use a 100K or even larger. Experiment with different values until you get a usable reverb level without squealing.
Sounds good. I did try putting the 10k in past night and the hum remained. But that was with the 100k/1.5k resistors. Curious what current numbers I should expect on that resistor near C6? I have a decade box I can pipe in and play with real time. But it is not made for significant current. But eould make for easy testing. Definitely wouldn’t want it for the plate resistors.
Good idea. Decade box will do fine. You're putting a reverb circuit into an amp that never had that circuit before so there will have to be a bit of experimenting. You're getting close to the joy. :thumbsup:
I could be wrong, but I don't think your hum is due to using that 100K/1.5K to lower the gain of the recovery stage.
I agree. It was likely already there and just brought forward.
Okay, original resistor values back in with 10k resistor, and have less squeal than without the 10k. So pulled the resistor and jumpered in a decade box and dialed values until squeal was gone. 220k to be precise. The hum was still present, so I tapped around with chopsticks and found my TB jumpers that allows me to remove thereverb circuit all together had a jumper that was resistive and would crackle and hun would come and ho. The terminal block clamp screw was not precisely on the wire so folding the jumper ends corrected that mostly. Still have some reverb hum. About on par with my AC15C1 hum so not gonna chase too much. All else seems good. Thanks for the helps guys. I’ll play it a bit and see how the hum translates with use not hyper focused in troubleshooting brain. Then re-address latter if needed.
That said, curious if the remaining noise is heater noise? The heaters are AC 6.5v. I could install a pot hum eliminator setup.
Your schematic does not show a center tap on the heater winding so you probably are geting some filament induced hum. A humdinger pot or artificial center tap with two 100Ω resistors in series across the heater winding with junction of resistors connected to ground or the cathode (pin 3) of the EL84s will reduce filament hum.
However, if this reverb circuit is just temporarily connected to the amp using long jumper wires and no shielded cable, this is a great way for hum to enter the circuit. The output of the reverb tank is the lowest signal level of the entire amp and requires shielding and neat layout/wiring, especially to the grid of the recovery tube.
Post a hi-rez pic of the amp with the circuit jumpered in.
I will get pictures later.
Thanks for the thoughts on the heater wire. I will clip in some resistors to my heater TB temporarily to see if that helps.
For the integration, i use shielded wire for the reverb tank signals to and from.
Where I tie in for the recovery at the normal volume pot 220k resistor is not shielded. Nor is drive portion. That is what I have connected to the TBs. So if I wanted it out of circuit I would pull the jumpers and tube.
So tonight I had band practice and tried out the amp at appropriate volumes. The permanent hum was fixed.
However the feedback I had prior that was a higher pitch is now a lower pitch and takes longer to start. Like after being on for say 30mins you cycle on reverb and in about 30 seconds it comes on gradually as a lower frequency feedback building. My kneejerk is a capacitor it damaged and leaking.
Make that 220K larger, even 1M if necessary. Use the smallest value that kills the oscillation and still yields enough reverb. You may consider using a 250KA reverb pot. If so you'll need to experiment with this resistor again.
I did some digging since my last post and came across some very sulimilar symptoms. So before I go down that path again I am going to play with the reverb tank shock mounting a bit too. It is mounted on dampeners, but they are rather thin. Maybe just power up and then pull the reverb out of the cabinet to see if it does the same. I want to rule out feedback loops created by speaker magnet interference and/or speaker cabinet vibrations.
It may be wishful thinking at best. But I am hoping to not crank down the recovery stage levels with a hogher resistor as I am already loosing a ton of reverb wet signal versus dry now with the 220k in there. I may also get another 12DW7 to rule that out too. So I will try a few things and then circle back as you suggested, Sluckey. I can’t thank you enough for your help.
Put the reverb tank in a bag and mount in the bottom of the cab if possible. Keep the sensitive output jack far away from the power and output transformers.
Okay, i feel like I am going backwards.
:BangHead:
I have along the line got this odd low frequency noise now. Not sure how to describe. I have checked reverb circuit forwards and backwards.
Here is what I have done so far:
1. Rewicked all solder connections
2. Checked for DC voltages at both sides of the capacitors against the drawing.
3. Checked all connections for stray wire strand connections or solder shorts
4. Installed humdinger pot and adjusted listening for noise.
5. Installed 100R resistors between filaments and EL84 cathode.(initially done for other noise)
6. Re terminated and verified reverb circuit wire and integration terminal block(screw type)
The noise DOES goes away when:
1. I remove the phase inverter tube
2. Turn the reverb level down
3. Pull the input and output sign of the reverb circuit where it integrate into the factory amp curcuit. As soon as I plug it back in the noise returns.
The noise DOES NOT go away when:
1. I unplug the reverb tank
2. Change phase inverter tubes
3. Change rectifier tubes
4. Utilize elevated(EL84 cathode) filaments
5. Remove 12DW7 reverb drive/recovery tube
6. Unplug instrument.
7. Turn either channel volume down
The noise is not effected or changed by manipulating the shielded reverb tank drive or return cables or solder connections. I triple and quadruple checked all solder connections for resistive connections and resoldered every integration point for good measure. I have put the reverb tank in a bag.
Based on the fact the noise goes away when I turn the reverb all the way down can deduce that the issue is between the normal preamp tube and the driver side of the 12DW7. The one thing on my list I haven’t ruled out is to replace the 470pf coupling cap C1. I will get another of those and rule that out. Beyond that I am truly at a loss at this point. I have walked away from it at this point as I am not getting anywhere. Any ideas would be appreciated.
Here’s some videos.
Okay, so my noise is called motorboating. Didn’t know that. Add to the long list of things to learn about tube amps.
So, reading a bit more and researching my schematics I see a disparity between the three different and common AC10 schematics I have. The presence of a 200R 4w B+ decoupling resistor. My amp does not have the decoupling resistor installed. So if my motorboating is due to the pack of decoupling reaistor, that would be an easy fix. However I am admittedly skeptical as the noise is only present on the reverb part of the circuit. But given the inclusion of the resistor is not difficult, that is easy enough to rule out. I will also replace the 470pf reverb coupling capacitor while I am at it.
However I am curious about noise being phase related
> 100R 4w
Where do you see that?
Do we have a complete As-Built schematic? I see factory plans and your snippets but not a complete plan? (I may be blind.)
> 100R 4w
That was a typo. I corrected the post. Sorry. The three schematics shown above are two different years of Vox factory schematics and one from Stephen Grosvener’s Service engineer’s guide for the AC30(covers multiple AC models).
As far as how it was actually but, I doubt they were all the same. Here are two pictures of original AC10 with different resistors between the 16uf can cap and pin 3 of the EZ81 rectifier. One can be read as 300ohm. I am betting that the earlier drawing that shows the lack of a resistor was something added latter to remedy a design issue. Or it’s anyone’s guess on what different values it may have had.
That said, I installed a 200R 5w resistor and it did not remedy the motorboating. I changed the mixing resistors to 470K from 220K and no difference. Changed the 470pf reverb coupling capacitor out for new 500pf.
As of right now, i know that when I probe a DMM to check voltage between the .01uf C15 capacitor and the 12AX7 Phase Inverter, the motorboating goes away. And seeing I have already swapped in another PI I believe my issue is design related.
I've had motorboating issues in one amp due to 2 stages sharing K bypass caps. Might be worth a try to split the cathodes and give them each a dedicated resistor and cap. Double the resistance to maintain the same bias.
/Max
/Max
Thanks for the recommendation. The reverb circuit has their own separate cathode bypass caps. The vibrato and oscillator and the 2x EL84 are the tubes that use a shared cathode capacitor. Not sure I can do anything about either of those though. Do you think these would cause this?
Couldn't tell for certain, but I guess it's possible. Motorboating is (correct me if I'm wrong) a form of oscillation. So signal is probably leaking into or being pickuped up, somewhere it isn't supposed to.
Someone who knows this stuff might be able to help you more than I can.
The EL84 cK can be split into two 250Ω resistors, for what it's worth.
/Max
You're working with an unproven circuit so you should expect some adaptation challenges.
I don't think you will ever solve these issues as long as that sensitive reverb recovery circuit is just dangling outside the chassis.
Agreed. Alot to sort out, experiment with and learn. I do appreciate allthe help. So forgive my misunderstanding and learning curve.
Not sure what you mean dangling outside the chassis. Which part dangling were you referring to. The chassis is out of the cabinet, but all of the reverb recovery is attached to the same chassis as the rest of the amp circuit. The only part not affixed and dangling is the footswitch jack plate and tank send and return which are all shielded and get their grounds in the chassis. They are plate mounted and screw to wood for mounting, so no ground there missing. The reverb tank cable is all shielded cable. Where the dry signal for the reverb circuit picks up in the chassis. And where the wet gets back in to the mixing resistor network is also in the chassis.
Do you think the chassis being out of the cabinet would cause the motorboating?
Keep in mind that I have reassembled the amp at numerous stages to rule out outside noises and have had the same noises. I truly think after everything I have gone over that I have a design issue. But I am far from an expert and hopeful to learn.
Here is a cleaned up and updated schematic showing integration.
Motorboating is very often through the power supplies. Despite requests, you are not showing a fully integrated signal and power path. Maybe if/when you do, it will be clear.
Pictures of the wires? Circuit? What specifically would help? Are we trying to determine the wire routing? Wire type? I have been updating schematics for exactly how my amp is currently to try and get a complete picture. I am not trying to be reluctant to provide info. I just am not sure exactly what it is you want to see. Or what will help?
Here is the entire print updated…
Now we see relationships. V2b plate is throwing huge DC into V1A grid. Just a drawing error or in real life? The plate output of V1 is ignored, signal is taken from the cathode bypass cap. The reverb pot wiper is unemployed.
Are there two "V1"s? Whatever...
Now I see how the power runs. Taking so many stages on the one "255v" filter stage is, not surely bad, but risky. I would at least make one more filter node called "250V" (it may be higher, just a name) for the V1B stage. Also in this day of cheap electrolytics I would like to see much more uFd at "225V", 50 or 100uFd.
Drawing error.. sorry. I will edit to replace. Here is the updated print correcting:
1. Missing 500pf coupling cap
2. Incorrect Reverb pot wiper
3. Added Reverb circuit TB tie points
4. Reverb circuit tagboard layout.
The V1 that is the 12DW7 is all the new reverb add-on circuit. I kept the original AC10 valve assignments in tact because the reverb add-on was an afterthought after the amp was mostly built. Hence the tagboard integration with TB in case I couldn’t get it working as desired.
As for the 255v usage, that is pretty much 100% orignal AC10 design. I left the 255v alone and picked off the 305V. Which has me suspecting that getting the dry signal feed to the 12DW7 from the ECF82 that gets 255v and then driving the tank and recovery from the 305V is where the oscillation is rooted as a phase disparity. But I am so far from being in my wheelhouse with valve amps. So, I may just try the revovery stage on the 255v to see if the motorboating changes in any way. Luckily I have a 100uf Big ass cap if I need to add another node.
I have a ton of pictures showing the build here and some recents with circuit mods.
https://drive.google.com/drive/folders/10GvpZVH9rkmf-pj42Q1SvLOgNtprsNCH
https://drive.google.com/file/d/1gYsQiXcAYDc2G_o4whjWgbYpysHUs0KE/view?usp=drivesdk
This shows the most recent of the circuit. Not as tidy given the recent mods and troubleshooting. But will be cleaned up once I get the final circuit figured out.
**Update***
Added a node to the power supply dedicated to the 12DW7. The motorboating went away. But I have a low frequency hum now. For the added node I place another 8uf cap to ground and a 1.5k resistor before the 22k resistor. Will play around a bit with the cap and resistor values to see how the noise changes.
Also, I was advised to remove a few un-need complexity in the circuit by recommendation of a tube amp engineer. Here’s where we are at now.
Another update…
I clipped in a 100uf capacitor to ground in temporarily at the R8 and my low frequency hum went away. I tried this also at the 305V B+ junction at the tagboard and the noise went away the same.
I have a couple things I want to try in this order. Let me know what you all think:
1. replace 8uf reverb power supply node with 16uf, 22uf and 32uf to see where/if low frequency hum for who drops off.
2. Possibly replace the double reservoir 16uf x 16uf cap for a 32uf x 32uf. Looking over the ac10SRT schematic, they have more power filtering added.
3. Possibly add another RC network between the new node and B+?
All those ideas are worth experimenting with. As for #3 also consider powering the reverb driver with the higher voltage node but use an additional node with bigger resistor to power the recovery circuit.
Thanks for the advise. Curious for my own understanding, what is the concept to separating the driver and recovery sides? And does playing with the value on my 1.5k resistor to a higher value seem worth evaluating? I admittedly don’t fully understand the correlation with the resistive values as far as how they effect power filtering/conditioning.
Okay, so I got the reverb dialed now. Played it for an hour tonight and the sound is great! Lots of reverb.
Along the lines of Sluckey’s suggestion, I added another node and split the drive and recovery power nodes. Ultimately I paralleled(instead using of cascading)the Reverb nodes and broke them into a driver and recovery node.
After all of the reverb woes, I got the reverb hum resolved but now have a ever present 60hz hum independent I have been chasing for a few weeks now. It was way worse than it is now. But still present.
Since I got the reverb fixed I have been working on the other power supply nodes to filter out the 60hz hum. What I have is a 60hz hum(verified by spectrum analyzed) that does not change with instrument plugged in or not. Does not vary with instrument volume. As soon as the amp comes on with the volumes all the way down it’s present. Here’s what I have done:
1. Changed reservoir capacitor to 32uf+32uf(like AR10SRT)
2. Changed filter caps C13 and C16 from 8uf to 16uf.
3. Added 10K/16uf RC network at V1(similar to AC15)
4. Swapped out V3, V6, V1 and V2 with new.
5. Put reverb level pot ground to be on same groundplane as rest of reverb circuit.
6. Corrected Reverb tank send/receive shielded grounds and isolated connectors(tank has grounded send and receive)
7. Replace signal wire between R45 and reverb pot with shielded wire.
8. Disconnected reverb circuit to rule that out all together.
9. Added ground between OT secondary and preamp ground screw(dedicated ring terminal). Was floating off of connected to C1.
10. With clip terminal lead grounded preamp to numerous chassis points to see if ground point for tagboard better suited for other ground source. No change.
All of the above besides #4, 7 and #9 made improvements. But I have an amp that is too noisy to be useful for anything besides furniture. And I out of ideas at this point.
60hz hum is present with chassis out of cabinet.
I have read quite a bit about grounds on tube amps and know that had I to do all over, i’d stick to the diagram shared here many times. But I stuck with bits I could piece together from the Stephen Grosvener book and what I could find was done on the original AC10. I am fairly certain at this point that it is ground related because touching my instrument strings makes the hum level drop significantly, although not disappear. I am missing something. Looking for last ditch efforts to quiet this thing down before it turn into a boat anchor.
:dontknow: :cry: :cry: :cry: :cry: :help:
You have a very nice looking amp! My advice is do NOT give up! Keep working on it until you have an amp that you can really enjoy. Yes, you may have to change something to get it where you want it to be. However, that's way better than giving up on it and not using it at all. Your build is not boat anchor material, IMO.
The first amp build I ever did literally took my over 2 months of trouble shooting over weekends to get it fixed. It still stands as the most time consuming problem on a build that I resolved. It was a brand new resistor with a break inside the enamel that would be intermittent when playing. When I would "test" it, it showed good but with bass notes being played it would open and close with vibration. UGH!
My "best sounding" amp ever took about a year of working on it to get it dead quiet at idle. I probably opened it up maybe 4 or 5 times during that year and experimented with different approaches.
Don't give up! :thumbsup: With respect, Tubenit
Add two 100Ω resistors to the filament winding as shown...
I will give that a go. Currently I have 100R going to the EL84 cathodes instead of ground with a adjustable pot(humdinger style). Admittedly the pot does not change the noise level at all when adjusted.
Some oddities in the Grosvenor book were the addition of an erroneous jumper and ground right at the ECF82. Those at first power on caused all sorts of issues and were omitted. So right now the only filament ground is to the cathode of the EL84s and are otherwise directly to the transformer.
Would be nice to show that on the schematic.
All of the grounds on the tagboard are daisy chained and exit the tagboard at C1 that ground to a chassis bolt. There is a ground connection that connects this daisy chained groundplane to the pot/input jack ground bus. I did clip that and clip on to a dedicated control pot ground and the noise level remained unchanged. Part of me suspects the daisy chained groundscheme on the tagboard being suspect. There area some EL84 screen resistors and the tone circuit sharing the same groundplane. But all of the plate and cathode for the EL84 are in the lower chassis power section like the original and have their own ground tagstrips.
After all of the reverb woes, I got the reverb hum resolved but now have a ever present 60hz hum independent I have been chasing for a few weeks now. It was way worse than it is now. But still present. ...
If it makes you feel better, my 1965 AC10 Twin also hums.
It happens as soon as the power is applied & before any tubes warm up, so cannot be cured without modifying the layout (which won't happen).
Good point. I’m at revision 8 of my schematic haha.
Thanks for your encouragement. I was pretty frustrated last night and at my witts end.
I’d love to hear your AC10 if you have a recording.
Here are a few of mine with hum:
No volume idle hum and normal chan
EF86 hum
Both channels bridged
Other lessons learned along the way….
I used 600V rated teflon insulated solid core hookup wire because it was suggested and keeps shape where it is placed. In hopes of keeping a clean build. The wire is great for that one reason alone. But if you chase issues or have to tweak and modify it is horrible. I have had wires break constantly. Lots of fixes with every repair or tweak. Sonif you have a proven amp design and layout proven, the wire is awesome. But I won’t use it again. So chock that one up for lesson learned.
Next is LED power pilot lamp. So I used a 110V LED power lamp right off the mains switch because the indicators were easy to find and I figured why not? Well along the way I have had noises all over and going away and come back. Today playing around with more reverb integration tweaks and playing with mixer resistor values I fins I have a hum back. Or more a buzz… hmm. So the coupling capacitor that connects the normal channel off the volume pot to the PI is where the mixing resistor solders to. And I have been working in this area since I first got the amp powered on. Some while poking with a chopstick I found that if I move C15 one direction the noise gets louder. Towards the pilot lamp. Pop the lamp from the bulb holder and find it is spraying out noise like crazy. Not sure if that is the nature of using a AC mains lamp or LED. But definitely replacing with adifferent lamp and powering off the heaters. How many times I have been down the noise road? It is A problem but I am apprehensive that it is THE problem. Anyways, for anyone wanting to know where this stands… 🤦🏻♂️
eature=share
As for the reverb circuit, i have the reverb working and have tried pilling the dry signal the reverb drive from the other side of the reverb so that the drive is goes up and down with volume. I have tried multiple suggestions to try to get the reverb so that it doesn’t start the slow and perpetuating feedback induced with the reverb level above 1/2 up.
Here’s what I have tried and the results:
1. Changed C11 from 500pf to .022uf
2. Changed C24 from 1uf to .22uf.
- These two cap changes made the howling feedback to a squeeling feedback.
3. Moved C24 dry signal from V2 plate over to between Normal volume wiper and R45.
- The reverb drive was very weak. Feedback squeel starts immediately.
4. Temporarily clipped in resistors to ground at R37 around the existing 1M varying from 750K all the way down to 330K.
-Feedback starts slower each resistor value down I go, but is still present.
5. Replaced R45 with 3.3M(ala Fender).
- extremely weak reverb drive (almost none at all)
6. Tried a 750K for R45.
-still weak reverb
7. Moved C24 dry signal feed back to plate.
- feedback seems to be gone with reverb. Need to fix a few other things before I am certain of the reverb being fixed. The dwell also seems better likely due to the capacitor changes not piping so many lows to the tank.
In summary…
I believe that the Swart style reverb circuit is a compromise. If I had a cascaded gain stage I believe I would be able to tie the dry signal drive after the volume and would be good with another gain stage before the PI. But because I go right into a PI from the reverb re-integration, I needing all signal I can to drive this with one tube.
So I will keep the reverb integrated at the plate and it will function like a stang alone reverb where I mix dry and wet signals. The nature of scabbing on a one tube reverb like I am I suppose versus adding another recovery tube. 🤷🏻♂️
Attached schematic is prior to temporary mods.
