Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: 100decibels on December 14, 2022, 08:43:27 pm
Hello.
I built a Hoffman Stout TMB for a friend and put a switch on the NF and it makes noise if I remove the NF. I previously built a few Fender Champ clones with variable negative feedback with good results. Anyone try it? Regards.
Many people have put a variable NFB control on their amps. Works OK.
Try this... Put your NFB switch across R19. Open = NFB. Closed = no NFB. Any noise with this configuration?
Or you may be interested in a NFB switch and presence control like this...
http://sluckeyamps.com/november/november.pdf
Removing NFB increases gain and as a result adds some noise.
What kind of noise and how much?
I had it on an 18 watt plexi and it didn't make any "bad" noise when the NFB switch was off. Or on. When I started to play guitar through it, it didn't always sound that good but it wasn't the amp. :dontknow:
Finally I put in a 39k resistor with a 100k pot, the original NF resistor is 82k so in the middle I have this. A little hiss at maximum and not at minimum. Me too when i play the guitar it doesn't sound good but it's not the amp or the guitar.
Slucky's schematic had a list of suggested resistors based on OT tap. Not sure this will fix it but good to know.
