Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Kev01 on December 14, 2022, 09:34:33 pm
Title: Stop channel interaction on modded bassman
Post by: Kev01 on December 14, 2022, 09:34:33 pm
 Hello , I rebuilt the bass channel of a silverface bassman aa371.  I give it a Marshall voice and used the untapped half of the tube . I also installed a post phase inverter master vol . All the mods turned out great , but I have a lot of channel interaction between the stock and modded channel.  I wanted to be able to A/B switch the channels with one amp , but when I get the gain up on the hot channel there is a lot of bleed over into the other . These mods I did are documented and also freshened up the caps . I'm not an engineer I build guitars so I'm not sure where to start at to stop or reduce the interaction be it mixing resistors or what . Any help greatly appreciated,  thanks in advance Kev
Title: Re: Stop channel interaction on modded bassman
Post by: sluckey on December 14, 2022, 10:02:08 pm
My crystal ball is in the shop for a good buffing.
Post by: Platefire on December 14, 2022, 10:37:19 pm
Those mods you say are documented, does that mean you have a schematic???
Post by: bmccowan on December 14, 2022, 10:39:54 pm
A schematic, layout, and hi-rez pics are very useful for troubleshooting your amp. Don't wait to be asked. JUST DO IT!
Post by: PRR on December 15, 2022, 12:36:46 am
That won't buff out.
It's worn out. Needs rings and valves. Maybe a new turboencabulator.
Post by: Esquirefreak on December 15, 2022, 05:38:00 am
Don't forget the needle valve and float adjustment before startup. Haha.
As for OP - It sounds like the channels are sharing K resistor/bypass cap. In that case try and split those (give each triode its dedicated cathode C/R). At least that's where I'd start. But without a schematic it's really a guessing matter.
/Max
Post by: JPK on December 15, 2022, 07:11:17 am
Please document the mods in this thread. You have some of the smartest amp guys on the planet here (not talking about me).
Post by: Kev01 on December 15, 2022, 11:19:30 am
I'm having some internet issues so I did try to upload . It's an aa371 bassman and I'm wondering if upping mixing resistors might help without messing with the impedance.  Sorry I'm doing this from my phone and not trying to sound pitiful I'm loosing sight in left eye due to a brain tumor so the last month has just been fun .
Post by: sluckey on December 15, 2022, 11:26:59 am
It used to be an AA371. Only you know what it is today.
Post by: Kev01 on December 15, 2022, 11:35:39 am
 I converted the bass side to a Marshall tone stack and and tapped into the unused half of a preamp tube , other than that everything else is still aa371 other than converting it to a real bias control . No mods to feedback or power section . When I get the gain up I have more interaction on the clean channel than I want . I'm sorry I can't get a schematic up right now .
Post by: sluckey on December 15, 2022, 11:46:08 am
You said all that previously. But that short description does not provide enough clues to even guess. Hence my crystal ball comment earlier. We're all willing to help but you just haven't provided enough information.
Post by: Kev01 on December 15, 2022, 11:55:28 am
Again I'm sorry , I will get them as soon as I can . I actually made my living repairing guitars and started on tube amps of my own to educate myself because the nearest place for any type of good work is 4 plus hours away . I have been doing the easy stuff , filter caps ,bias and bad caps . My close friend was an incredible amp guy ,but passed away a few years ago , so I kinda feel lost without my Yoda .
Post by: bmccowan on December 15, 2022, 12:08:04 pm
Well I'm no Yoda, but I am sorry about the eye issue Kev. Agree that without a schematic advice is difficult/worthless. So I will only suggest where to look. In looking at that standard schematic the mixing resistors feed into that tube that has the unused stage. So the changes you made, undoubtedly change that - so, first place to look. Also, that amp has unequal mixing resistors it seems - 220K and 470K - up the other to 470K? I think common wisdom (not Yoda wisdom) is to not go higher than 470K. As I said, that may be worthless, but easy enough to change back.
Post by: sluckey on December 15, 2022, 12:25:18 pm
And the mixer is hot, ie, plate voltage on the mixing resistors.
Post by: Kev01 on December 15, 2022, 12:53:51 pm
This it guys
Post by: sluckey on December 15, 2022, 01:02:03 pm
There's a much better schematic in Hoffman's Schematic Library. We all know what the original looks like. But yours has been heavily modified. Only you know what you have now.
Post by: Kev01 on December 15, 2022, 01:03:23 pm
This it guys
Sorry the schematic is no longer available and i would be here 10 hours trying to draw it out . my issue with schematics is the straight line can double with my vision now and the sucks big time so been using layouts more and that is taking time . this is a CBS lets fix what wasn't broken amp and the lead dress was a spaghetti monster and i got that sorted out first . i apologize for my ignorance  and feel your pain with me as i get the same with guitars all the time .
Post by: Kev01 on December 15, 2022, 01:10:29 pm
 What would be the best fix for the different mixing resistors and is that my issue ? This poor amp was abused when I got it and brought everything to factory  before the mods. Like I said im trying to get amp smart after 40 years of repairing and building guitars. They say ignorance is bliss , but no its not
Post by: sluckey on December 15, 2022, 01:27:07 pm
Or, we could all try to guess what you have. Probably take more than 10 hours though.
Oh wait, my crystal ball is back and it looks brilliant. And it says...
   Assistance is futile!
Post by: bmccowan on December 15, 2022, 01:38:32 pm
:laugh: so true.
Only two ways I know of to get at "your issue." Have the Yoda's here (Sluckey, PRR, etc) look at your as built schematic. Or trial and error. My choice would be the former, even if it does take hours to draw up. Trial and error could take one hour or 100. :dontknow:
Not blaming you, but the information is getting more complicated with a spaghetti mess in the mix. Its a fairly complex amp that has been made more complex. No need for Fenders to be spaghetti messes - that's Gibson's job. You are not likely to do this, but I would remove all that is not standard and then rebuild to one of the more liked Bassman circuits. And I'd likely have Doug make up a turret board for the circuit you choose. At the conclusion you will have both an amp and a schematic.
Post by: Kev01 on December 15, 2022, 02:00:58 pm
I was hoping it was a poor design by CBS mixing the channels and would be and easy fix I have all the wiring sorted out and I'm actually pretty anal about wiring , but my expertise is in passive guitar wiring .
Post by: Kev01 on December 15, 2022, 06:45:34 pm
It was the mixing resistors . I bumped the other to match and much much better .
Post by: bmccowan on December 15, 2022, 09:00:25 pm
I'm glad it's better - best of luck with all.
