Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on January 03, 2023, 05:27:50 pm
Title: Pentode with local feedback - is it the way for the Tone Control that follows
Post by: kagliostro on January 03, 2023, 05:27:50 pm
To see a Tone Control that follows a pentode is something that happens really not frequently
surely it is due to the fact that a Tone Control is a too heavy load for a pentode
But I've seen this Fylon BK30 schematic and ... there is a Tone Control that follows the pentode
(https://i.imgur.com/MENPiTO.png)
(https://i.imgur.com/8yohyfc.jpg)
the unusual thing is that there is a 1M8 resistor that (to me) acts as a Local Feedback taking the signal from the output coupling cap and feeding the G1 of the tube
Is this a trick to permit to the pentode to have a Tone Control as load ?
Title: Re: Pentode with local feedback - is it the way for the Tone Control that follows
Post by: HotBluePlates on January 03, 2023, 05:38:58 pm
the unusual thing is that there is a 1M8 resistor that (to me) acts as a Local Feedback taking the signal from the output coupling cap and feeding the G1 of the tube ...
That's not a"pentode" it's an "operational amplifier" (opamp)!
Now that there is negative feedback and a series resistor to the input, the opamp's gain (https://www.electronics-tutorials.ws/opamp/opamp_2.html) is Rf / Rin = 1800 / 68 = ~26.5.
Others see "EF86" but we see "single-section 12AY7 with too many parts."
Why don't they use an actual 12AY7?  Probably because they only needed the 1 section, not 2 sections.
Post by: kagliostro on January 03, 2023, 05:49:21 pm
Why are they using an actual 12AY7?  Probably because they only needed the 1 section, not 2 sections.
No mojo on the use of a pentode ??
Thanks HBP
Post by: PRR on January 04, 2023, 11:25:20 pm
> the unusual thing is that there is a 1M8 resistor that (to me) acts as a Local Feedback taking the signal from the output coupling cap and feeding the G1 of the tube ... Is this a trick to permit to the pentode to have a Tone Control as load ?
Yes. The pentode gain is over 100. With the resistors it is less than 1M8/68k or 26. At least 4:1 of gain given-over to NFB. The Pentode's ~~200k output now looks like ~~50k. Hey, that is a lot like the ~~40k of a 12AX7 with 100k plate resistor. The 12AX7 tone stack will work well enough.
Post by: kagliostro on January 05, 2023, 02:14:43 am
Many Thanks PRR
I was thinking something like that
yes, there is poor gain but load can be higher
perhaps it would be worth checking out if it wort's the effort or, as HBP say, better to use a 12a*7 tube to obtain the same result
Thanks Again
Post by: pdf64 on January 05, 2023, 02:44:34 am
Additionally, the inverting opamp configuration throws away the normal high input impedance of a common cathode stage, and it becomes roughly equal to the 68k series input resistor.
So the guitar input gets loaded down a bit, and so won’t sound as trebly.
Of course if a buffered pedal is used, eg a tuner, the guitar then sees a high input impedance, and responds accordingly. But that can be confusing for a user.
Regarding pentode mojo, it may be seen that NFB applied an active device acts to linearise its operation, and by that, perhaps reduces whatever mojo it might otherwise impart :icon_biggrin:
Post by: kagliostro on January 05, 2023, 06:39:23 am
Also this info are useful to me
Thanks pdf64
