Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: joesatch on February 24, 2023, 04:49:31 pm
Title: relay assistance
Post by: joesatch on February 24, 2023, 04:49:31 pm
i normally use 12v relays but in this case i'm using a 5V relay. The relay is powered (yellow wire, pin 1) with 5.38 VDC (running off the 6VDC heater circuit into a 1M dropping resistor).  the relay doesnt work. adding a ground to pin 16 doesn't do anything.  thoughts? do i need to add a cap with the 1m dropping resistor or something?
Title: Re: relay assistance
Post by: shooter on February 24, 2023, 04:52:14 pm
ohm pin 1 to 16, should have a coil there, shouldn't be open.
IF you have ohms, put a diode pin 1 anode, pin 16 cathode, retry
Post by: Bieworm on February 24, 2023, 05:36:49 pm
If my eye is right your diode is put the wrong way around. Look at the stripe on the pcb
Post by: sluckey on February 24, 2023, 06:20:17 pm
That relay needs 5V @ 100mA to operate. Since you are getting power from a 6V source, you need to drop 1V @ 100mA. That means you need a dropping resistor value of 10 OHMS, NOT 1 MILLION OHMS!
Post by: joesatch on February 24, 2023, 06:21:02 pm
you may be right but i used the diode this way in other builds without issue. I'll flip it and see. The coil measures 157ohm (powered off)
Post by: joesatch on February 24, 2023, 06:22:20 pm
using a small dropping resistor isnt gonna reduce the voltage. Can i run this relay at the full 6 volts?
Post by: sluckey on February 24, 2023, 06:24:33 pm
The band on the relay MUST connect to the positive voltage.
Post by: joesatch on February 24, 2023, 06:25:52 pm
  that's how i have it. These little boards are marked wrong imo
Post by: sluckey on February 24, 2023, 06:33:37 pm
6V can only push 6ľA through a 1M resistor. That won't do shit.
Sorry, I looked at the wrong part of the datasheet. You have the H1 (high sensitivity) relay. Voltage = 5V, current = 30mA, coil resistance = 166.7Ω. So, you need to drop 1V @ 30mA. Your dropping resistor will be 33Ω.
Post by: joesatch on February 24, 2023, 06:58:41 pm
success with the 33R resistor. coil is getting 4.93V which is close enough. Thanks Sluckey. :l2:
Post by: sluckey on February 24, 2023, 08:08:42 pm
I tried to present my replies in such a way that you could actually learn something. Hope you did.
Post by: EL34 on February 25, 2023, 07:20:56 am
I can see that you have the diode reversed from here in NC
Pretty simple to set up the coil
All you need is smooth 5vdc
The + and - hooked up correctly
And the diode put in the correct way.
Post by: joesatch on February 25, 2023, 10:19:39 am
is the diode in the right way?  please advise.
Post by: sluckey on February 25, 2023, 10:37:31 am
YES
The diode band must connect to the positive voltage. If it were connected wrong you would only have .6V across the coil and that 33Ω resistor would be very hot.
Post by: joesatch on February 25, 2023, 10:52:12 am
thanks , yes i see the coil isn't polarity sensitive. I have hooked the positive to the side that is most convenient (closest) to the energy source.
Post by: sluckey on February 25, 2023, 10:57:07 am
Yes it is reversed according to the markings on the board. But he also reversed the power connections. He has the positive voltage connected to the top side of the board. So, this is a case of two wrongs make a right.   :icon_biggrin:
The relay coil is not polarized. It doesn't care which side is positive or negative. But the diode does care and the cathode must connect to the positive voltage.
Post by: sluckey on February 25, 2023, 11:00:55 am
You do see that the diode symbol etched on the board has the stripe (cathode) on the bottom side in your pic? This means that you should have reversed the position of the diode ***AND*** connected the yellow wire to the bottom side of the board. Then Doug would be happy too.  :icon_biggrin:
Post by: EL34 on February 25, 2023, 01:02:12 pm
Why don't you just reverse the diode and + and - and do it correctly?
Post by: joesatch on February 25, 2023, 01:25:29 pm
because my + lead is right next to that eyelet
Post by: kagliostro on February 25, 2023, 06:10:10 pm
I was reading and ....
But to drop from 6V for a 5V relay will not be sufficent to use an in-series diode ?
That will avoid any math calculation, to me
Am I wrong ?
Post by: acheld on February 25, 2023, 10:19:28 pm
Yeah, we don't have a schematic, but "normally" a diode is placed in parallel with the relay coil.
You're assuming that a) you will be doing all the servicing of this amp, and b) you will remember how you wired it.
If I service it, I guarantee I will be confused by that diode and the board.   There will be words.
Post by: sluckey on February 25, 2023, 10:35:19 pm
Kagliostro is suggesting to use a diode in series rather than the dropping resistor. A forward biased diode will drop .6V. Close enough. However, the math ain't difficult.   :wink:
Still need the de-spiking diode across the coil.
Post by: DummyLoad on February 26, 2023, 02:50:42 am
Flip the board over, and everybody's happy! (solder mask down)  :icon_biggrin:
Post by: JPK on February 26, 2023, 08:45:37 am
Yep. A very good thing to have for switching [off] any DC inductive load. I learned this the hard way at a job many years ago.
Post by: acheld on February 26, 2023, 10:12:52 am
Thank you, I misunderstood Franco.
