Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: davidb on February 28, 2023, 09:59:59 am
I just saw a post from an amp tech talking about how he replaces most center taps with virtual center taps, especially in vintage amps with expensive PTs. The logic here is that if a short between pins 2+3 occurs, it will burn out the PT. I have a Sunn and a Laney that use center taps and I want to preserve them as best I can, is it worth making this modification? I also have a Music Man that grounds one of the 6.3V windings, and I think it would be worth converting this as well since the same problem could occur.
Thanks for the help, I’m still learning here and appreciate the input.
David
Can't you just fuse the CT if you're worried?
/Max
Protecting things with a fast acting HT fuse will mitigate numerous failure modes, including this one.
Bear in mind that if the heater circuit gets pulled up to anode voltage, eg by the pin 2 to 3 short described, the heater to cathode insulation of all valves in the amp is likely to be damaged.
I think better mitigation for a pin2 to 3 short by ensuring the integrity of the OT secondary circuit would also a good way forward. eg use of dedicated output sockets for each tap rather than a load impedance selector switch, safety resistor hardwired across the OT secondary in case all else fails.
... The logic here is that if a short between pins 2+3 occurs, it will burn out the PT. ...
In my limited experience, this doesn't happen.
I had a power tube short Pin 2 to Pin 3, and it popped the mains fuse instantly when I turned on the Power switch. New fuse, new tube, and the amp was 100% again.
We are not protecting the heater winding, because its thicker wires support more current than the high voltage winding. And the high voltage winding already has a mains fuse to pop in the case of excessive current draw.
