Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jordan86 on April 24, 2023, 04:56:38 pm
Hey guys!
I still love my Princeton Reverb that I built back in 2020, which so many of you helped me on. I did add eventually a "RAW" control on the back of the chassis - in the "ground switch" hole. It's just a 500K pot that sits in series between the fixed 6.8K mid resistor and ground. As I crank it up, things get more "tweedy". Rough schematic attached. I like the varying levels of midrange on the raw pot but I'd love to add a complete bypass of the tonestack. You know, for when you just need a little "extra" :icon_biggrin:
Could that be achieved by replacing the 500K pot with a switched pot or push pull pot? Would prefer to not drill anymore holes in the chassis if possible, just not sure how to implement that with a pot. I don't have much experience with push pull pots.
I'd be fine with anything from 25K-250K on the raw control if I could implement the bypass. Basically something to just break the ground connection on the tonestack. Unless I am thinking wrongly.
Remove the ground from the bottom of your raw pot. Now put a switch between the raw pot and ground.
He's not wanting another hole in his head - er, chassis. Would this pot work?
https://www.amplifiedparts.com/products/potentiometer-alpha-audio-spst-rotary-switch-500k (https://www.amplifiedparts.com/products/potentiometer-alpha-audio-spst-rotary-switch-500k)
Push/pull switched pot would be better.
So I think I know how to do it. I would need a push pull that is closed in the stock position and switch open in the pulled position. Is that normal? Or are they always open in / closed pull?
The pots with a SPST switch are usually closed in the pull position. But if you get a pot with a DPDT switch you can wire it either way.
https://www.tubesandmore.com/products/potentiometer-bourns-audio-knurled-shaft-push-pull-mini
Isn't at least some resistance to ground necessary at that point?
Is that EQ after a cathode or anode follower?
Only if you want the tone controls to work. By disconnecting the tone controls from ground, it takes the tone stack out of circuit, giving a huge volume gain boost. Hence "raw" or direct sound.
I see, there's a volume control there in the Princeton reverb.
I think I'd plan on switching in a 3Meg resistance to ground under the raw control lug to ground point.
Minimize a possible "pop" from the switch?
I don’t plan to hot swap it or use it live on the fly. Just studio and home use.
I like it better to install a mini pot in the #2 input and wire it to the bass pot as described as a variable tone stack bypass. Some of the intermediate positions of the pot are useful to me.
YMMV
