Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Duncan on May 04, 2023, 01:23:54 pm
Title: Uneven/unbalanced heater voltage
Post by: Duncan on May 04, 2023, 01:23:54 pm
Hey guys,
I’m in the last stages of getting a new build up and running (sort of a unique take on a jcm800 circuit) and I am noticing on my heaters, I’m getting about 3.4 VAC on one side and about 6.5 VAC on the other.
Has anyone seen this before?
From what I can tell, everything is wired correctly, and I am at a loss.
Thanks in advance!
Title: Re: Uneven/unbalanced heater voltage
Post by: shooter on May 04, 2023, 02:04:05 pm
are you using resistors to make a CT with the filament supply?
if so, verify both R's are the same value----with a meter
Post by: Duncan on May 04, 2023, 02:06:57 pm
Nope. The PT has a centre tap that I’m currently running to ground.
Post by: sluckey on May 04, 2023, 02:17:36 pm
To correctly measure heater voltage measure from pin to pin on the tube socket, not from pin to ground. IOW, one probe on pin 2, the other probe on pin 7. Or, one probe on pin 4/5 and the other probe on pin 9.
Post by: Duncan on May 04, 2023, 03:22:36 pm
Measured pin to pin, got about 3.5 VAC
Post by: pdf64 on May 04, 2023, 03:37:32 pm
Maybe the CT has somehow been mixed up with a winding end?
Post by: Duncan on May 04, 2023, 03:55:47 pm
Well shoot. I just reviewed the wiring diagram for the transformer and that’s exactly what I did. Turns out the winding leads are black and orange, and the CT is brown.
Facepalm central.
Thanks!!
